Old 06-19-2002, 12:19 PM   #1
SyNNeR
SyNNeR is on a distinguished road
SyNNeR's Avatar
Default What are the difference between SL/SL1/SL2
I have an 92 SL1 and i was wondering....
What are the key differences between earlier model saturn SL/SL1/SL2. If anyone could help that would be great....and pictures are a plus!
Add to SyNNeR's Reputation
Rate the quality of this post and help SyNNeR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SyNNeR is offline
Old 06-19-2002, 12:36 PM   #2
ptolbert
ptolbert is on a distinguished road
Default
SL1 has black bumpers.
Add to ptolbert's Reputation
Rate the quality of this post and help ptolbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ptolbert is offline
Old 06-19-2002, 12:37 PM   #3
SyNNeR
SyNNeR's Avatar
Default
That i knew, but there has got to be much MORE than that.
SyNNeR is offline
Old 06-19-2002, 01:18 PM   #4
radioouman
radioouman is on a distinguished road
radioouman's Avatar
2002 L-Series 2.2L Sedan
Default
What's New for 1991
Featuring an underpowered 1.9-liter engine and uninspired ergonomics, first Saturn sedan isn't all it's cracked up to be. The SL is very basic, with manual steering and transmission. Variable-effort steering, adjustable steering column, tachometer, and remote fuel door and trunk lid releases are standard on SL1. SL2 adds more powerful engine, sport-tuned suspension, alloy wheels, body-color bumpers, and speed-rated tires. All body panels except hood, roof and trunk lid are made of plastic composite materials on all models, and ABS is optional.
What's New for 1992
New engine and transmission mounting system supposedly cuts down on noise and vibration. Passenger compartment gets added acoustic insulation. Leather and a rear deck spoiler are new for SL2 models. Alloy wheels are redesigned.
What's New for 1993
Driver airbag added. SL2 gets new front fascia and optional fog lights. Cars with ABS and automatic transmission can be ordered with traction control. SL2 suspension provides softer ride.
What's New for 1994
CFC-free refrigerant is added to air conditioning system. Automatic transmission's Performance mode is recalibrated to give smoother shifts. New central unlocking feature on power door locks allows all doors to be unlocked with a twist of the key. New alloy wheels are optional on SC1.
What's New for 1995
Dashboard is redesigned and now contains two airbags. Base engine is rated at 100 horsepower, up 15 from last year. With the automatic transmission, traction control is included with optional ABS. Styling is cleaned up front and rear. Manual three-point front seatbelts replace automatic type.
What's New for 1996
New bodywork and interior improvements make the SL an excellent value in the compact sedan class. SL's meet 1997 side-impact standards for the first time. A five-speed and traction control are no longer mutually exclusive items. The back seat is actually livable this year. Daytime running lights are standard, and rain water won't leak all over your stuff anymore when you open the trunk.
What's New for 1997 - SC
Saturn restyles its sport coupe, moving it to the SL/SW platform in the process. The result is a larger, roomier and heavier car. Dashboard is carried over, but interior trim is new. Newly optional is an in-dash CD player. More steps are taken to reduce noise, vibration and harshness.
Pros
Larger interior, larger trunk, optional traction control, optional ABS, composite dent- and rust-resistant side body panels
Cons
Heavier, uglier
What's New for 1997 - SL
Once again, Saturn attempts to quell noise, vibration, and harshness (NVH) with improved engine mounts, revised torque struts, thicker dash mat, and non-asbestos organic front brake pads. Other changes are limited to new colors, an optional in-dash CD player, a panic mode for the security system, and a low-fuel indicator.
Pros
Dealer service, dentless plastic body panels, optional traction control, optional ABS
Cons
Front styling, comfort, flimsy interior materials, low seating position, engine noise
What's New for 1997 - SW
Once again, Saturn attempts to quell noise, vibration, and harshness (NVH) with improved engine mounts, revised torque struts, thicker dash mat, and non-asbestos organic front brake pads. Other changes are limited to a new color, an optional in-dash CD player, a panic mode for the security system, and a low-fuel indicator.
Pros
Cons
What's New for 1998 - SL
Minor trim modifications, reduced force airbags, and hardware improvements to stifle unwanted noise, vibration and harshness are on tap for 1998.
Pros
Dealer service. Dentless plastic body panels. Optional traction control and ABS.
Cons
Seat comfort. Flimsy interior materials. Low seating position. Engine racket.
What's New for 1998 - SW
1998 brings fresh colors, revised fabrics, redesigned wheels, reduced force airbags and more attempts at reducing noise and vibration levels.
Pros
Cons
What's New for 1998 - SC
Refinement is the name of the game for 1998. Improvements to the suspension, transmission and engine blocks are designed to smooth the ride, reduce noise, increase durability and provide slick shifts. Second-generation airbags deploy with less force than the old ones. A child seatbelt comfort guide has been added in the back seat, and SC1 models have a new wheel design. Dark Blue is the single new color.
Pros
Optional traction control. Optional ABS. Composite dent- and rust-resistant side body panels.
Cons
Questionable styling. Ultra-cheap interior materials.
What's New for 1999 - SC
Saturn continues on its refinement theme for 1999. Refined powertrain performance, interior upgrades and new wheel selections top the list of changes for SC1 and SC2 models. New later this year on all coupes is a standard driver's-side third door to improve access to the rear seats. Improvements to both the single- and dual-overhead cam engines (including new pistons, connecting rods and crankshafts) are designed to reduce noise, vibration and harshness while improving fuel economy about one mpg across the board. The SC2 gets redesigned standard wheel covers and new optional 15-inch aluminum wheels. Interior cloth fabrics have been revised, the capacity of the windshield washer solvent bottle has been increased to one gallon, and there's a new Green exterior paint. In a move backward, all Coupes will revert to rear drum brakes, replacing the once-available rear discs on SC2 with ABS.
Pros
Composite dent- and rust-resistant side body panels, standard third door, optional ABS, optional traction control.
Cons
Questionable styling, ultra-cheap interior materials, weak standard equipment list.
What's New for 1999 - SL
Powertrain components in both the single- and dual-overhead cam engines (such as pistons, connecting rods, crankshaft and timing chain) have been revised to reduce noise, vibration and harshness, while returning an increase of about one mpg across the board. Three new exterior colors debut: Dark Blue on SL, Green and Blackberry on SL1 and SL2. Front seatbelts have been repositioned, and the windshield washer solvent bottle's capacity has been upped to one full gallon. Sadly, Saturn has moved to rear drum brakes on all models, replacing the rear discs that had been available on SL2s with ABS.
Pros
Dealer body, dentless plastic body panels, optional traction control and ABS.
Cons
Low seating position with flimsy cushions, cheap interior materials.
What's New for 1999 - SW
As with the rest of the 1999 Saturn line, SW models are sure to benefit from revised powertrain components in both the single- and dual-overhead cam engines. The pistons, connecting rods, crankshaft and timing chain in these motors have been redesigned to reduce noise, vibration and harshness, while returning an increase of about one mpg across the board. Wagons have a new Green exterior color. The only other changes are repositioned front seatbelts for easier access and increased windshield washer solvent bottle capacity, which is now one full gallon.
Pros
Dealer service, dentless plastic body panels, optional traction control and ABS.
Cons
Poor seating position and comfort, flimsy interior materials.
Add to radioouman's Reputation
Rate the quality of this post and help radioouman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
radioouman is offline
Old 06-19-2002, 01:21 PM   #5
SyNNeR
SyNNeR's Avatar
Default
Wow thanx, now could i say, take items off a 92/93 SL2 and put them on my SL1? The 93 SL2 front fascia and body colored bumpers seem appealing to me.
SyNNeR is offline
Old 06-19-2002, 01:57 PM   #6
toeachitsown
toeachitsown is on a distinguished road
Default
go for it...(body work)...
Add to toeachitsown's Reputation
Rate the quality of this post and help toeachitsown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
toeachitsown is offline
Old 06-20-2002, 01:12 AM   #7
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default Idiots
First off, the SL has all of the trunk releases and crap too, and the SL1 does not have varialbe effort power steering, only the "2" cars have that. Where did you cut and paste that from?
~D.J.~
OhioVueBoy is offline
Old 06-20-2002, 10:04 AM   #8
blackandwhite
blackandwhite is on a distinguished road
blackandwhite's Avatar
Default
I know some of the options for the SL1 weren't available on the SL, like the sunroof. Between those two and the SL2, the engine is different, the gear ratios are different, the suspension is squishier, it's all geared more towards the "economy" side of things.
Add to blackandwhite's Reputation
Rate the quality of this post and help blackandwhite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackandwhite is offline
Old 06-20-2002, 11:53 AM   #9
dano92
dano92 is on a distinguished road
Default
Radioouman,
Thanks for an excellent summary of the yearly differences! Is 96 the year they switched to the new PCM?
Add to dano92's Reputation
Rate the quality of this post and help dano92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dano92 is offline
Old 06-20-2002, 12:42 PM   #10
lexington01
lexington01 is on a distinguished road
lexington01's Avatar
Default
Originally posted by radioouman
What's New for 1991
Featuring an underpowered 1.9-liter engine and uninspired ergonomics, first Saturn sedan isn't all it's cracked up to be. The SL is very basic, with manual steering and ...
I wish my car had an automatic steering system. That'd get me an extra 30 minutes of sleep on my way to work!
And who says my car has questionable styling?? I think the 97-00 SCs are the coolest of the bunch!
Add to lexington01's Reputation
Rate the quality of this post and help lexington01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lexington01 is offline
Old 06-21-2002, 03:03 PM   #11
freqency
freqency is on a distinguished road
Default
Update On 1996 SL1 :
In an update posted after the original article, upon opening your trunk after a rainstorm water still leaks all over your stuff.
Add to freqency's Reputation
Rate the quality of this post and help freqency reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freqency is offline
Old 06-21-2002, 03:20 PM   #12
lexington01
Default
Welcome to the club frequency!
I wouldn't know about rainwater/trunk issues since I NEVER use the thing. Subs eat up all useable space.
~Brandon
Old 06-21-2002, 03:29 PM   #13
SyNNeR
SyNNeR's Avatar
Default
Dont the SL2's have the rear lights that go all the way across the rear deck, while the SL/Sl1's only have corner tail lamps?
SyNNeR is offline
Old 06-21-2002, 03:33 PM   #14
ptolbert
Default
on the sl2 its a reflector not a light.
ptolbert is offline
Old 06-21-2002, 03:37 PM   #15
SyNNeR
SyNNeR's Avatar
Default
That seems retarded...., but i do think it looks better all the way across the rear deck. Can you just pop one off a Sl2 and put it on a SL1?
SyNNeR is offline
Old 06-21-2002, 03:44 PM   #16
Galileo
Galileo is on a distinguished road
Galileo's Avatar
2007 AURA XE
Default Re: Idiots
~D.J.~
About the variable effort power steering, the SOHC models came standard with this steering system from 91-94 (except for the SL, where it was optional). The '95 model year brought the basic power steering to the SOHC models that continues through to the '02 model year. The '01 model year brought standard power steering to the SL.
Now, in the early '92 model year there was a shortage of the manual steering gear so Saturn added the variable effort power steering gear at no charge until the shortage was over. I know this because my first new car, a 1992 blue Saturn SL, had this free feature.
Beautiful People First~
Add to Galileo's Reputation
Rate the quality of this post and help Galileo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Galileo is offline
Old 06-21-2002, 03:46 PM   #17
SyNNeR
SyNNeR's Avatar
Default
So what is so "Special" or "not So Special" about variable effort power steering. Is this a step up from power streering? Or a step down?
SyNNeR is offline
Old 06-21-2002, 03:57 PM   #18
radioouman
radioouman's Avatar
Default
I got that from edmunds.com.... they have an Overview for each for each model. THe overviews before the internet was big (95 or 96 and earlier) were the same for each line.. SC SL and SW... But then they changed to different overviews for each one.
Old 06-21-2002, 11:34 PM   #19
Nuke-Em
Nuke-Em is on a distinguished road
Nuke-Em's Avatar
Default Other differences...
SL/SL1/SC1/SW1's had 14 inch wheels/tires while SL2/SC2/SW2 had 15's.
SL/SL1/SC1/SW1's have a 110 MPH speedometer while SL2/SC2/SW2 have 130 MPH speedometers
Tachometer's are also different (obviously)
SL/SL1/SC1/SW1's had different upholstery designs
SL/SL1/SC1/SW1's had non-adjustable headrests
Since SL's don't have a foglight option, the openings in the bumper are non-existant
SL/SL1/SC1/SW1's have grey door handles
SL's had right-side mirrors as dealer installed accessories
That's all I can think of for now...
Matt
If God had intended driving to be boring, he would have given us all Toyota's
Add to Nuke-Em's Reputation
Rate the quality of this post and help Nuke-Em reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nuke-Em is offline
Old 06-21-2002, 11:58 PM   #20
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default Re: Other differences...
Matt
Early SLs and SL1s and SC1s had adjustable headrests too, they just weren't the articulating (tilting) design like the "2" cars had. The SL also had the same front black fascia as the SL1.. with foglight cutouts.
~D.J.~
SL1, SL2 Whats the difference? 1994Saturn S-Series General 15 01-22-2014 11:27 PM
Tire Size Difference Between SL1 and SL2 usa4624 S-Series General 3 03-18-2009 09:40 AM
Any difference in exhaust between SL1-SL2? Thermo1223 S-Series Tech 4 10-02-2008 08:09 AM
Difference btwn SL1 and SL2 Scaggs0101 S-Series General 25 07-11-2007 12:09 PM
Difference between SL1 and SL AKsaturn S-Series General 18 05-20-2005 02:51 PM
