Old 04-24-2007, 08:37 PM   #1
frereagle
frereagle is on a distinguished road
Default Battery Dies on crank
Ok, i have all the timing all set. I have an Optima hooked up with full battery power. I also have a 2nd battery hooked up in parrallel just in case thats my issue.
When i start to crank the engine, just as it goes to spark, it stops cranking. Then it slowly starts again and everything comes back on. Has anyone experienced this before
"Well me and my Splattern will just have to run circles 'round ur rustang"
Add to frereagle's Reputation
Rate the quality of this post and help frereagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
frereagle is offline   Reply With Quote
Old 04-24-2007, 08:45 PM   #2
Default Re: Battery Dies on crank
1-Flooded engine? Pulling the plugs will tell you if you have raw gas filling up the cylinders creating a hydraulic lock; fluids are incompressible.
2-Maybe a worn starter?
Old 04-24-2007, 09:00 PM   #3
frereagle
its possible to be the starter except that i drove the car here, so unless i broke it in the process, but its possible. And i cleared the engine of fluid.
Old 04-24-2007, 09:02 PM   #4
mkuz13
mkuz13 is on a distinguished road
2009 AURA XE
Check to see if all your connections at the starter are tight.If they are,hook up a volt meter where the battery cable is hooked up at the starter to see if your getting 12 volts.
Want more gun control? Then use both hands.
Add to mkuz13's Reputation
Rate the quality of this post and help mkuz13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkuz13 is offline   Reply With Quote
2000 SL2 Cold Starting Issues [Crank crank crank...] RarestRX S-Series Tech 8 02-12-2012 11:58 AM
93 sl2 has battery won't crank zigstarre S-Series Tech 1 01-08-2009 06:08 AM
Key FOB went through the wash.....battery dies!!! tskaling Astra General 26 10-29-2008 08:33 AM
98 SC2 idles funny, dies, oil in spark plug well, fixed that, still dies, etc. Kpendrgn S-Series Tech 18 02-03-2007 09:58 PM
Battery dies, but Alternator OK adeltaman S-Series General 5 07-31-2005 09:40 AM
