Old 04-24-2007, 05:53 PM   #1
Rapsack
Rapsack is on a distinguished road
1993 SC2
Default Cranks but doesn't start?
One of my buddies 93 SC2 134,000 miles cranks over but will not start. When the key is turned to the on position there are no lights that come up on the dash board and the fuel filter does not run for a few seconds. I have checked all the fuses and they are all good. Does anyone have any idea what else i could posibly check for?
Add to Rapsack's Reputation
Rate the quality of this post and help Rapsack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rapsack is offline   Reply With Quote
Old 04-24-2007, 06:05 PM   #2
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Default Re: Cranks but doesn't start?
Pull the IGNITION fuse(s) and check again to be absolutely sure then if they're good put them back and now trace the red positive wire from the battery to the fuse panel and check for loose/corroded cabling at the fuse box. It seems that one cable is fine, the one going to the starter terminal but the other main cable to the underhood fuse box may be in question if not the main IGN fuse(s) that supply power to the ECM.
Old 04-24-2007, 06:33 PM   #3
richpin06
richpin06 has a spectacular aura aboutrichpin06 has a spectacular aura aboutrichpin06 has a spectacular aura about
richpin06's Avatar
It very well could be your main feed is corroded at the fuse box.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-24-2007, 08:46 PM   #4
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Nice pic!
2006 Black VUE Red Line - iOS7 coming soon
Add to BobbyP's Reputation
Engine cranks but won't start Jayna Que S-Series Tech 7 06-27-2008 09:47 PM
cranks but no start kandjj S-Series Tech 13 02-15-2008 05:31 AM
NO START!!!! 3 Cranks and then nothing HELP!!! bryanmckinlay Ion Tech 2 12-17-2007 01:57 PM
Cranks but will not start..Help please loverboyred L-Series Tech 1 03-15-2006 03:11 PM
98 sl2 cranks but won't start scort_beater S-Series Tech 6 12-10-2005 11:13 PM
