Old 04-16-2007, 07:45 AM   #1
tomhammond
tomhammond is on a distinguished road
2002 SL1
2004 ION-1 Sedan
Default How to remove driver airbag?
Hello,
Does anyone know how to remove the driver-side airbag that is on the steering wheel? Looking at the replacement airbag & cover, there are four metal posts with notches that clip into the steering wheel somehow.
I am not trying to re-connect the replacement airbag, as that takes a skilled technician. But I do want to replace the cover so that I can get the horn working again. That way my car can pass inspection and be on the road again.
Does it take special tools to remove the airbag cover? Hopefully I don't have to remove the steering column to do this.
Thanks for any advice you can give!
Tom Hammond
Proud Saturn owner
Add to tomhammond's Reputation
Rate the quality of this post and help tomhammond reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomhammond is offline   Reply With Quote
Old 04-16-2007, 09:02 AM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: How to remove driver airbag?
The 2nd gen airbags connect with two little screws that come in "from behind". Look behind the spokes of the steering wheel. IDK about your 3rd gen. Look for female thread on your replacement bag for clues.
Add to eljefino's Reputation
Old 04-16-2007, 01:41 PM   #3
BarnOwl
BarnOwl's Avatar
I don't know about the skilled technician part for hooking up an airbag. It's just a wire harness. I took mine off and put it back on my 2000 to change out the steering wheel for cruise control. On the 3rd gen there are clips in each corner that hook into slots in posts on the air bag. To remove the bag you rotate the wheel to expose the hole the clips are in, insert a screwdriver and turn 1/4 turn. You can feel when it has the clip pulled back. Then pull on that corner. Do that on every corner and viola. To go back on, hook up the wiring, line the posts up with the clips and push. It just snaps in.
Add to BarnOwl's Reputation
Old 04-16-2007, 01:46 PM   #4
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
I assume it would be advisable to have the battery disconnected when removing an air bag...
Add to alleninpa's Reputation
Old 04-16-2007, 02:00 PM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
I posted instructions here:
http://www.saturnfans.com/forums/sho...9&postcount=10
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
92 SC... removing driver airbag, how do i disable the SIR system? DJboozeAlot S-Series Tech 14 10-28-2010 05:50 PM
How to remove airbag? Raysp30 S-Series Tech 5 06-30-2009 10:07 PM
Airbag Powder--but NOT Airbag--Deployed During Theft Attempt Bob K S-Series Tech 29 10-07-2008 10:40 PM
quad driver & quick quad driver Dianne S-Series General 1 09-22-2007 03:02 AM
How do I remove the airbag? cryalsjr Vue Tech 6 03-19-2007 11:01 PM
