Old 04-15-2007, 10:27 PM   #1
erick295
erick295 is on a distinguished road
erick295's Avatar
Default Rear wheel bearing & hub removal?
I'm about to replace my rear bearings, so I searched around for some info and found this thread, but nothing else. I know the process is easy, but evidently it's a b***h to remove the original hubs
I want to make sure I get everything I need before I actually do this, because this is my only car and I do NOT want to have to put everything back together to go get something, lol. I guess I need a small sledgehammer and some PB Blaster... do I also need something like a chisel to pound with? Also, what size socket do I need for the hub assembly bolts, and will a 1/2" drive fit in there or is it too tight? Is that pretty much all I need?
One last question... where can I buy jack pads? I've looked around a bit and haven't been able to find any, except online. I'd especially like a pair I can use around the pinch weld, if I can do that. I'm getting tired of repairing my undercoating every time I jack up the back
Add to erick295's Reputation
Rate the quality of this post and help erick295 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
erick295 is offline   Reply With Quote
Old 04-16-2007, 12:31 AM   #2
Low Saturn
Low Saturn's Avatar
2008 AURA XE
Default Re: Rear wheel bearing & hub removal?
Whenever I have ever had to remove rear hubs, I just remove the four 10mm bolts and the hub falls out into my hand. I actually have to remove the final bolt and hold onto the hub at the same time so it doesnt fall on the ground.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
Old 04-16-2007, 03:56 AM   #3
Sky King
Sky King's Avatar
Actually the hardest part of this job can be getting the old hub out if it is rusted or corroded in. The PB Blaster or other good penetrant will help but I wouldn't go at it with a chisel. You definately don't need anything as robust as 1/2 in drive. 3/8 drive is more that adequate.
As for the jack pads, I don't have pads. If you are using jack stands, you can take a piece of 1x4 cut about 4 inches long and put it between the stand and the underside of the car if you are jacking it in an area that is suseptable to damage.
Here are a couple of links that show jacking locations:
http://www.saturnfans.com/photos/sho...21846/size/big
http://www.autozone.com/servlet/UiBr...3d80199897.jsp
I tried the first one but right now the Saturnfans photos are down. That one is actually a drawing from the Saturn service manuals.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-16-2007, 08:06 AM   #4
tarsun
tarsun is on a distinguished road
jack locations = look where your spare tire is in the trunk. no dont put them there. ha ha. ok not funny but seriously, look under the carpet in the trunk. it should tell you right where to jack the car up...
Add to tarsun's Reputation
Rate the quality of this post and help tarsun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tarsun is offline   Reply With Quote
Old 04-16-2007, 09:41 AM   #5
erick295
erick295's Avatar
Oh, are they only 10mm? I figured they'd be bigger.
I know where the jack points are, but the undercoating always gets scraped off by the jacks (not the stands). If anyone knows where to buy the pads, let me know. Otherwise, I guess I'll just keep looking around.
That should be all the info I need. Thanks guys
Old 04-16-2007, 11:54 AM   #6
Greg1
Greg1 is on a distinguished road
Greg1's Avatar
1997 SW2
You are using a floor jack? I always use a piece of wood to distribute the load.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-16-2007, 12:52 PM   #7
S3aturnR
S3aturnR's Avatar
1999 SL1
i wish i had that problem. mine took 2 days soaking in pb blaster, an hour of hammering and many cuss-words...
s3aturnr
Add to S3aturnR's Reputation
Old 04-16-2007, 01:05 PM   #8
'Nuff said.
Add to madpogue's Reputation
Old 04-16-2007, 01:52 PM   #9
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
s3aturnr
Michigan....
Well into the salt belt...
Nuff said.
Erick should be good, atlanta doesn't get much salt...
Add to alleninpa's Reputation
Old 04-16-2007, 02:52 PM   #10
erick295
erick295's Avatar
Well, I drove it for four years in Tennessee before moving here, and it got some salt there... but it spent most of its life in Florida before that, so I have high hopes. I still want to be prepared, though
I didn't think about using wood... I'll just do that if I can't find any pads. Thanks. I assume that doesn't compromise the stability at all...
Old 04-16-2007, 04:24 PM   #11
S3aturnR
S3aturnR's Avatar
1999 SL1
Originally Posted by alleninpa View Post
Michigan....
Nuff said.
you are correct, sir. alas, if i were to unbolt the rear hub only to have it fall off in my hand, i would cry tears of joy...
s3aturnr
Old 04-16-2007, 05:24 PM   #12
Your tears of joy, being salty, would cause the hub sitting in your hand to rust...
Old 04-16-2007, 06:02 PM   #13
WingsOfSaturn
WingsOfSaturn's Avatar
A trick that I have used is using the bolt holes to press out the bearing. After removing the bolts that hold the bearing/hub on the knuckle, I then insert some longer bolts, two opposite each other will do. The studs that hold the upper motor mount or about the same length work real good. Then rotate the hub so the bolt heads press up against the hub. Start turning the bolts out a few turns at a time and the bearing/hub will come right off.
Of course a couple days soak with PB Blaster is always good.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 04-17-2007, 02:54 PM   #14
erick295
erick295's Avatar
That sounds interesting, but I'm a little lost because I don't know what this thing looks like. Are you rotating the hub so that its bolt holes no longer line up with the knuckle's holes, and then tightening bolts into them from the front, so they press against the knuckle and pull the hub out?
Do you know the thread dimensions of the bolts so I could get a couple? I don't have any extras.
Old 04-17-2007, 03:04 PM   #15
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
There are holes in the hub, for no apparent reason.
Use a long bolt and thread it into where you took the short on out from, going thru the hub mystery hole by the wheel studs.
After you screw in far enough you can rotate the hub, rotate the hub some so the mystery hole doesnt line up. Then back out the bolt, and it will jack against the hub, and maybe push the whole bearing assembly out.
On my montana, I did similar on the front, and the bearing came apart, leaving part of it stuck inside. Fortunately it was the front and I used the CV as a jack with the big cv nut.
Old 04-17-2007, 03:47 PM   #16
P'raps this is just what these holes are for, to create an ad hoc puller.
Old 04-17-2007, 04:19 PM   #17
WingsOfSaturn
Well the holes are there for access to remove the bolts. Guess you could say if you can't pull it then push it.
95 SL2 MT 220K+
Old 04-30-2007, 04:36 PM   #18
erick295
erick295's Avatar
I went ahead and replaced the bearings (they came off pretty easily with a hammer and some PB), and now my rear brakes are groaning when I release the pedal. They seemed to be adjusted properly, dragging just enough, but maybe not. Do I need to just wait a few days to see if they self-adjust, or is there something I should do to help the process along? Could it be something else? They seem to work fine... I can stop the car with just the handbrake.
In any case, the clacking noise went away, and the car coasts better now (which may or may not be because the brakes aren't properly adjusted)
Old 04-30-2007, 08:08 PM   #19
eljefino
eljefino's Avatar
1995 SW1
Probably where the drum sits in proportion to the shoes has shifted slightly with the tighter bearings.
Maybe try pulling the drums and sandpapering the rust ridges away. Hate to have that noise mask a bearing problem.
Add to eljefino's Reputation
Old 05-01-2007, 08:00 AM   #20
erick295
erick295's Avatar
If you're talking about the surfaces the shoes drag on, there's no rust on them. Also, this only happens when I release the pedal, not while stopping. It's just like the usual sound that happens if you release the pedal enough that the car starts rolling but the brakes are still tightly engaged, except louder... it almost sounds like they're wet or something.
EDIT: BTW, the car isn't rolling here... it happens even when I'm sitting still on flat ground and out of gear.
Rear Wheel Hub/Bearing Replacement uhlemd Vue Tech 22 06-12-2016 01:17 PM
2002 L300 Rear Axle Bearing and Hub Assembly Removal admiralbrown L-Series Tech 4 07-02-2012 08:06 AM
rear bearing/hub removal help blue92 S-Series Tech 2 07-18-2009 11:55 AM
Front Wheel Bearing & Hub job Tips & Part #'s. CND_SC1 S-Series Tech 5 05-13-2008 10:37 AM
Wheel Bearing/Hub Assembly-Front/Rear dildog S-Series Tech 3 05-23-2007 10:58 AM
