Old 04-03-2007, 04:14 PM   #1
SaturnVue'03
SaturnVue'03 is on a distinguished road
Default Trouble Starting 2006 FWD V6
Does anyone else have the problem in which the key will not turn when you try to start your Vue? I've been having this problem since I bought the car in July of '06 and it only seems to be getting worse...is it a falty starter? A couple of times I've actually sat in my car for up to 10 minutes before I could get the key to turn. Someone told me they had the same problem in their old Camero. I have to really crank the wheel back and forth while turing the key and even then it can take a minute or so. It doesn't always do this, but it seems to be worse when the Vue has been sitting in direct sunlight, causing the inside to be pretty warm. If I take the car in for service what can they do about it?
Please help!
Add to SaturnVue'03's Reputation
Rate the quality of this post and help SaturnVue'03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnVue'03 is offline   Reply With Quote
Old 04-03-2007, 06:12 PM   #2
bigjimz28
bigjimz28 is on a distinguished road
Default Re: Trouble Starting 2006 FWD V6
That would be the GM wheel lock
1.) try not to hit the wheel getting in and out of the car
2.) when it happens remove the key and pull the wheel side to side
then try again
3.)it's camaro not camero
Add to bigjimz28's Reputation
Rate the quality of this post and help bigjimz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigjimz28 is offline   Reply With Quote
Old 04-03-2007, 08:24 PM   #3
SaturnVue'03
This happens whether or not the wheel is locked or not. It's just totally frustrating. I owned a 2003 FWD 4cyl. and never had this problem once in that car. I guess I'll just live with it until I take my car in for service when something else major goes wrong.
Old 04-04-2007, 04:27 AM   #4
kodak_jack
kodak_jack is on a distinguished road
kodak_jack's Avatar
I like the way the key doesn't want to come out any too easily also. It's like you have to fight with it to give you the key back!
Add to kodak_jack's Reputation
Rate the quality of this post and help kodak_jack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kodak_jack is offline   Reply With Quote
Old 04-04-2007, 06:33 AM   #5
greyhound bus
greyhound bus is on a distinguished road
greyhound bus's Avatar
My dealer told me that they DID have some problems with the Vue ignition switches. I don't think there was ever a recall , but there MIGHT be a TSB. I would check with a dealer. Maybe they can help you.
2007 Vue FWD V6- Storm Gray, GT velour seat covers, Trailer hitch, Saturn hitch cover, Cargo mat, Vent Visors, Rear air deflector, Splash guards, Custom Saturn front license plate, Chrome exhaust tip.
"Make a Fast Friend, Adopt a Greyhound!
Add to greyhound bus's Reputation
Rate the quality of this post and help greyhound bus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
greyhound bus is offline   Reply With Quote
Old 04-04-2007, 02:51 PM   #6
gstien
gstien is on a distinguished road
Uh-oh, I got that too.
It's like a catch when I try to put the key in, and start the car?
Then when I try to get the key out?
That's not good....
Add to gstien's Reputation
Rate the quality of this post and help gstien reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gstien is offline   Reply With Quote
Old 04-04-2007, 03:05 PM   #7
Ken Baker
Ken Baker is on a distinguished road
I had the problem developing with my ignition switch so I had them replace the ignition switch barrel after a new key failed to solve the problem.. Problem solved. The last thing you want is to break or damage the key. When the keys get old the groves for the tumblers wear and sometimes a new key will solve the problem.
Add to Ken Baker's Reputation
Rate the quality of this post and help Ken Baker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ken Baker is offline   Reply With Quote
Old 04-05-2007, 10:52 AM   #8
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
I had the opposite problem. I would take the key out, and it would not lock and it would ding as though I had left my key in the ignition. It didn't happen all the time, but luckily it happened to the service guy when I took it in. They replaced the cylinder I believe.
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 04-05-2007, 11:18 AM   #9
GearGuy
GearGuy is on a distinguished road
GearGuy's Avatar
Try a liberal squirt of graphite in the key slot and see if that helps.
A small tube doesn't cost too much. $1 - $2...
2006 Vue 3.5L FWD
Add to GearGuy's Reputation
Rate the quality of this post and help GearGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GearGuy is offline   Reply With Quote
Old 04-06-2007, 10:58 PM   #10
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
There is a TSB for it, where they remove the lock cylinder, clean and lubricate with a special grease, then reinstall. It usually fixes it the first time.
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-06-2007, 11:07 PM   #11
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
My Vue had a similar problem, twice. A new key cut by the Saturn of West 78 dealership using their own snipper tool solved it. Another time I could remove the key while the engine was running. New key solved that too.
The Saturn keys seem to be made of a soft brass which wears quickly. Better for the key to wear than the ignition lock/switch. After 124K miles and a zillion starts you could expect the key to wear out. Check it out!
Add to burlyvue2's Reputation
Rate the quality of this post and help burlyvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burlyvue2 is offline   Reply With Quote
Old 04-07-2007, 01:06 PM   #12
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Lubricate your keys with lock/key lubricant!
Add to BobbyP's Reputation
Old 04-14-2007, 07:43 PM   #13
Lhorn
Lhorn is on a distinguished road
My 12K 06 had the same problem. NOT related to having the wheel turned and NOT fixed with silicon lubricant. Dealer replaced the cylinder and it works perfect so far. I feel for you. I'd take it in.
Add to Lhorn's Reputation
Rate the quality of this post and help Lhorn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lhorn is offline   Reply With Quote
Just got a 2006 RL FWD jrad Vue Red Line 7 10-22-2009 02:36 PM
2006-07 VUE FWD or AWD V6? ScottSaturn83 Vue General 7 06-28-2009 08:30 PM
2006 Vue FWD V6 afjet243 General Saturn Discussion 5 01-10-2008 10:58 AM
Finally! My NEW 2006 V6 FWD Vue is HERE! GearGuy Vue General 23 11-01-2005 08:53 AM
2006 FWD V6 Vue rdljr1 Vue General 6 10-03-2005 05:56 PM
