Old 04-01-2007, 01:53 PM   #1
dewermcd
dewermcd is on a distinguished road
Default 2003 Ion Turn Signal Problem
My right front (only, back OK) turn signal has stopped working. I get a "quick" indicator inside the car when I activate the turn signal; the right front (only) flasher doesn't work either. The bulb is OK and works in the running light mode. Left side operates OK as does the right rear. Sounds like a flasher unit problem to me but where is it located and woulod it only impact the right front? There's been nothing else happening with the car - no accidents or messing around with the electrical or anything - it just popped up. Any advice?
Add to dewermcd's Reputation
Rate the quality of this post and help dewermcd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dewermcd is offline   Reply With Quote
Old 04-01-2007, 01:59 PM   #2
young james
young james is on a distinguished road
young james's Avatar
2007 ION-2 Sedan
Default Re: 2003 Ion Turn Signal Problem
99.9% it's still a bad bulb. Change the front turn signal and it should solve the problem. The reason it blinks so fast is to tell you that you have a bad bulb. So swap out the front bulb and that should take care of it.
Pictures: http://www.ionforums.net/garage.php?mode=view_vehicle&CID=58
Add to young james's Reputation
Rate the quality of this post and help young james reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
young james is offline   Reply With Quote
Old 04-01-2007, 02:36 PM   #3
Welcome to the Board.
Have you ever has the DRL campaign done on the car?? If not then get it done at your local Saturn. That should fix things unless the bulb socket is so far gone thatit is melted and you have poor contact to the bulb.
Add to ssicarman's Reputation
Turn Signal Problem mikey109ca S-Series Tech 1 01-06-2010 07:08 PM
Turn signal problem-PLEASE HELP!! mac99sl2 S-Series Tech 3 02-19-2008 09:31 PM
Turn signal Problem wolly6973 S-Series Tech 6 05-11-2007 11:14 AM
2003 Vue Turn signal cancel problems majacoby Vue Tech 0 04-01-2007 08:40 PM
2003 Ion turn signal RICH Ion General 16 07-29-2004 01:26 AM
