Old 03-31-2007, 11:19 AM   #1
Psyclone07
Psyclone07 is on a distinguished road
1996 SL
Default Saturn SC2 Auto PCM swap
I dont know if this is true or not. It says it brings up the horsepower to 124 but would that also be the same for a SOHC. If i recall a DOHC HP is 124 so would putting this chip in a SOHC make it equal HP??? im a very confused noob. and would this work in a 96 SL1 manual.
Add to Psyclone07's Reputation
Rate the quality of this post and help Psyclone07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Psyclone07 is offline   Reply With Quote
Old 03-31-2007, 11:30 AM   #2
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1997 SW2
Default Re: Saturn SC2 Auto PCM swap
A while ago Low Saturn hinted that the Auto PCM is designed to prepare the engine for stopping anytime the gas pedel is lifted/reduced which may decrease gas mileage
All swapping in an auto SC2 PCM might do is remove the speed limiter. Want DOHC power? Get a DOHC engine. Oh, it'd also put the SES light on because the manual is "missing" 1st->4th + R gear (not really, just the sensors).
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 04-01-2007, 12:23 AM   #3
quiksc2
quiksc2 is on a distinguished road
quiksc2's Avatar
2002 L-Series 3.0L Sedan
It doesn't have anything to do with horsepower. With a single cam, after a certain speed, the governor kicks in and you can't go any faster. I don't remember what it was, something like 109. With the DOHC PCM, the speed limiter kicks in at 124. It will cause some other problems, so there really isn't any reason to do it. Unless you live on the salt flats or something, but if you want to go super fast there are a lot better choices than a Saturn.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 04-01-2007, 05:38 AM   #4
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
1991 SL
a sohc wouldn't even run with a dohc pcm. regardless of that some people belive the auto pcm makes them faster cuz it has no rev limiters. well saturns stop making power at the top of their power band, and make their most power around 4500rpm so theres no point unless u have some serious work done. in which case its better to do a stand alone cuz the auto pcm will hurt performance.
the dohc has more hp cuz it has twice the cams and twice the valves
i think what ur confused about is people like to put the pcm from an sc2 (regardless of manual or auto) into their sw2 or sl2 cuz it brings the limited top speed up to 124 from 111. quick this is only the sc2 and no other that has the 124mph top speed.
mods i still need to do:
struts that can handle H&R race springs
rear sway bar
stiffer fstb (maybe)
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 04-01-2007, 11:17 AM   #5
quiksc2
quiksc2's Avatar
I couldn't remember if it was just the coupe, or all the Sx2's
DCS
Old 04-01-2007, 12:46 PM   #6
tarsun
tarsun is on a distinguished road
i do know a dohc engine will work work, i mean run, some what... with a sohc pcm. not verry good tho. and theres no point to it. but i know it as a fact.
Add to tarsun's Reputation
Rate the quality of this post and help tarsun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tarsun is offline   Reply With Quote
Old 04-01-2007, 01:52 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
NO. putting the PCM from a 124 horsepower DOHC SC2 into a 85 or 100 horsepower SOHC SL1 will NOT make it equal 124 horsepower.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
PCM Swap, Manual for Auto? Saturndude82 S-Series Mods 27 10-13-2009 12:09 PM
97 sc2: Auto tranny swap DJboozeAlot S-Series Tech 8 11-25-2007 10:10 PM
PCM swap dragon370 S-Series Mods 2 12-04-2006 11:22 PM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 03:58 PM
Need PCM for '94 Saturn SC2 Automatic Magicman Old Classifieds 1 05-12-2005 10:41 AM
