Old 03-23-2007, 05:18 PM   #1
red-vue
red-vue is on a distinguished road
Default cleaning floor mats
is it safe to put the floor mats in the washer machine? whats the best way to clean them?
Add to red-vue's Reputation
Rate the quality of this post and help red-vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
red-vue is offline   Reply With Quote
Old 03-23-2007, 05:22 PM   #2
Ritz
Ritz's Avatar
Default Re: cleaning floor mats
No.
Well, it might not destroy them, but it probably won't get them very clean and probably won't be kind to the washer.
I'm not sure which mats you have. If they are carpeted, you can vacuum them and then either:
Spray them with carpet cleaner (like Resolve or Woolite), brush the carpeting to remove the soil, then vacuum again after they're dry.
Buy one of those cheap mini steam cleaners for $60-70 (my preferred approach for carpeted mats). I used the Bissell Mini Green Machine.
Use a pressure washer with soap. Then let them dry in the sun.
If you've just got rubber mats, a pressure washer works wonders.
Cheers,
Add to Ritz's Reputation
Rate the quality of this post and help Ritz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-23-2007, 07:07 PM   #3
mellissam
mellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
While Ritz does it with flair I stick mine in the bathtub, use the shower nozzle to soak, then use a mild cloth detergent using a mild (soft bristles) scrub brush, then re-spray with shower nozzle to rinse and hang to dry overnight. Total time = 10 minutes for front carpets...they come out looking like new.
'Silven'
K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues
Add to mellissam's Reputation
Rate the quality of this post and help mellissam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mellissam is offline   Reply With Quote
Old 03-23-2007, 07:09 PM   #4
binkybaby
binkybaby is on a distinguished road
binkybaby's Avatar
i might try that.........i usually use Resolve............
-sXe for life-
Former Saturn owner but still a Saturn Fan~!
2010 Toyota Tundra SR5, 5.7L
Add to binkybaby's Reputation
Rate the quality of this post and help binkybaby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
binkybaby is offline   Reply With Quote
Old 03-23-2007, 07:28 PM   #5
ThePebble19
ThePebble19 is on a distinguished road
I know around here in central PA, you can rent those steam cleaners for 15 bucks or so at our local grocery store...It's nice if you don't have a need for a steam cleaner all of the time.
Add to ThePebble19's Reputation
Rate the quality of this post and help ThePebble19 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ThePebble19 is offline   Reply With Quote
Old 03-23-2007, 11:13 PM   #6
crj19
crj19 is on a distinguished road
crj19's Avatar
2004 VUE 3.5L
Try the dishwasher, it works well.
Former Saturn Salesperson....Out of autosales for good!
Add to crj19's Reputation
Rate the quality of this post and help crj19 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crj19 is offline   Reply With Quote
Old 03-24-2007, 06:08 AM   #7
Ritz
Ritz's Avatar
Uhm...sure. If you want to replace your dishwasher. Sand, little bits of gravel, and fuzz from carpet are probably not going to be terribly useful to have floating around in the water that has to go through the pump impeller in your dishwasher.
Cheers,
Old 03-24-2007, 07:59 AM   #8
sspeer
sspeer is on a distinguished road
sspeer's Avatar
Automatic dishwashing detergent is some pretty harsh stuff. It might bleach the carpet
I usually use an APC (or laundry detergent, or a dedicated stain remover) on bad spots, scrub it in with a brush, rinse.. and then a general cleaning on the whole thing with my little green machine.
Add to sspeer's Reputation
Rate the quality of this post and help sspeer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sspeer is offline   Reply With Quote
Old 03-24-2007, 09:08 AM   #9
def z
def z is on a distinguished road
The best way is professionally. There are car washes that do that sort of thing. Most would do your mats only for $10-15 and they'll be cleaner than you can get them.
The other way is with a good wet-dry vac, some car wash upholstery shampoo, a softish bristle nylon brush and some elbow grease. You may want to find a carpet safe degreaser (citrus type cleaner) for the oil stains. Rinse, hang.
Add to def z's Reputation
Rate the quality of this post and help def z reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
def z is offline   Reply With Quote
Old 03-25-2007, 03:39 PM   #10
golftango
golftango is on a distinguished road
golftango's Avatar
2009 AURA XE
No. The method I've been using for years works wonders. Take them to a high pressure self-wash. Usally they have hooks in the bay for clamping up your mats. Use the high pressure soap and rinse. Gets all mud / sand out perfectly.
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 03-25-2007, 03:54 PM   #11
nakman
nakman is on a distinguished road
nakman's Avatar
Thumbs Up Re: cleaning floor mats
After using one of the conventional methods to clean the mats, I'd recommend some after-market mats to go over the factory mats. At least for the winter but, I use them year round. I generally only have to vacuum the sand/dirt out of the factory mats. As others have posted, I spray the after market mats with a high pressure wash or even use the hose at home on a jet setting and scrub brush.
2007 VUE FWD 3.5L, Storm Grey
2008 Honda Accord, 2.4l, auto, Black
(Pic is the 03 VUE, 4 banger, 5 spd, gone but not forgotten)
Add to nakman's Reputation
Rate the quality of this post and help nakman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nakman is offline   Reply With Quote
Old 03-26-2007, 02:59 PM   #12
gstien
gstien is on a distinguished road
I use the Green Machine too.
Add to gstien's Reputation
Rate the quality of this post and help gstien reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gstien is offline   Reply With Quote
Old 03-27-2007, 12:00 AM   #13
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
For really dirty mats, I use Tough Stuff. I spray it on, let it foam up, scrub in with a wet cloth, then hose off. If you have a pressure washer, that will make it easier/faster to get all the cleaner out, but I don't like to hose them too hard, I'm afraid it will wear them out quickly, like washing your clothes on the scrub cycle. We use delicate cycle for almost all our clothes, so I take the same approach to my car mats.
You can also use Tough Stuff on the carpet inside the car, but you have to be sparing with it and "rinse" it out with damp cloths. It works, and you only need a rag and some elbow grease!
Tupperware cars FTW!!!
Add to Dante's Reputation
Rate the quality of this post and help Dante reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dante is offline   Reply With Quote
Old 03-27-2007, 07:40 AM   #14
mr weather
mr weather is on a distinguished road
I haven't had to. The day I got both the VUE and the ION I yanked out the factory mats and put in Pant Savers mats.
Add to mr weather's Reputation
Rate the quality of this post and help mr weather reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr weather is offline   Reply With Quote
Old 03-27-2007, 07:49 AM   #15
runerx
runerx is on a distinguished road
runerx's Avatar
2003 VUE 2.2L
Blue coral spray on dry clean fluid works well on stains. Spray,scrub/pressure wash,wetdry vac. I get it at wally world
Dave
Never let facts stand in the way of a good opinion!!
Add to runerx's Reputation
Rate the quality of this post and help runerx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
runerx is offline   Reply With Quote
Old 03-27-2007, 09:19 AM   #16
Tom92SCm
Tom92SCm will become famous soon enoughTom92SCm will become famous soon enough
Tom92SCm's Avatar
2004 VUE 2.2L
I use Mellissa's method- minus the bathtub- that's what a driveway is for.
2012 Ford Escape V6 Limited AWD
2004 VUE 2.2L 5 speed
1997 Ford Explorer XLT 4x4
Add to Tom92SCm's Reputation
Old 03-27-2007, 09:39 AM   #17
Speedy
Speedy is on a distinguished road
Speedy's Avatar
The day I got my new Vue home, I removed the carpeted floor mats. The Saturn rubber floor mats replaced the carpeted ones. Then some cheapo walmart rubber mats with a good lip for catching water, mud, debris and whatever, went on top of those. Carpeted mats are resting peacefully in a box in the attic waiting for a day when I want to show them off.
When I was staining carpeted mats every week, a steam cleaner with the hand attachment for upholstery, a stiff bristle brush, and any upholstery or carpet cleaner worked well for getting them clean in the driveway. A good rinsing with plain water in the steam cleaner after that, then some sunshine, made things all-good.
Now I just hose off the mats when washing the car.
2007 VUE 3.5L V6 Auto
2007 Mini Cooper S Auto
Driving in da hot humid bayou...
__________________________________________
If it doesn't have plastic doors, it isn't a Saturn!!!
Add to Speedy's Reputation
Rate the quality of this post and help Speedy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Speedy is offline   Reply With Quote
Old 03-27-2007, 02:32 PM   #18
Dorian
Dorian is on a distinguished road
Dorian's Avatar
Great advice. One other note: when I'm getting ready to sell one of my cars the first thing I do is buy new floor mats. It's amazing how much new floor mats improve what I get selling a car. $75.00 for the mats can often raise the selling price by $500.00 or more just because of perception (that, and detailing the engine).
http://www.touringmotorcyclists.com
Add to Dorian's Reputation
Rate the quality of this post and help Dorian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dorian is offline   Reply With Quote
Floor Mats LelandC Aura General 23 04-11-2008 12:33 AM
Floor Mats pepsikid Outlook General 13 11-27-2007 06:49 PM
my floor mats 06ion3 Ion General 0 09-07-2006 05:42 PM
Floor Mats Druce Vue General 10 09-05-2004 07:43 PM
Lesson learned regarding cleaning rubber floor mats... fgwinn Vue General 9 03-30-2004 02:09 PM
