Old 03-22-2007, 09:29 AM   #1
Dubhlachan
Dubhlachan is on a distinguished road
Dubhlachan's Avatar
1998 SW2
Question Diesel Oil -vs- Gas Oil ?
What's the difference? I understand the diesel oil is made for the higher temperatures and generally dirtier conditions inside a diesel engine. Can the diesel oil be used in a gasoline engine for 500 miles or so to clean up deposits? Could a gas engine actually lose compression due to being "too clean" ? What do you folks think?
If I got along with people half as well as I got along with machines...
Add to Dubhlachan's Reputation
Rate the quality of this post and help Dubhlachan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dubhlachan is offline   Reply With Quote
Old 03-22-2007, 01:10 PM   #2
zukgod1
zukgod1 is on a distinguished road
zukgod1's Avatar
Default Re: Diesel Oil -vs- Gas Oil ?
Diesel oil will work fine in your car. it has some extra additives but that's about it. It will not clean out your engine.
Diesel oil is designed to hold deposits/soot suspended in it to prevent the soot from settling and clogging things up.
I've been running Delo 400 in all my gassers for years.
No such thing as a "Too clean" engine.
dan
98 SL2. A work in progress!
Add to zukgod1's Reputation
Rate the quality of this post and help zukgod1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zukgod1 is offline   Reply With Quote
Old 03-22-2007, 01:17 PM   #3
jjsk8r85
jjsk8r85 is on a distinguished road
jjsk8r85's Avatar
1992 SC
I used to run delo 400 in my old probe, simply because I could swipe it for free from the place I Was working at at the time. I never had any problems with it. I think it was 15w40.
92 SC 5-speed 239k miles
Add to jjsk8r85's Reputation
Rate the quality of this post and help jjsk8r85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjsk8r85 is offline   Reply With Quote
Old 03-22-2007, 05:58 PM   #4
westwind999
1999 SW1
If you look at most diesel oil it has an SL rating for gas engines too. I just bought some Valvoline Premium Blue Extreme 5W40, I'm going to use it for the summer. Like the other poster stated Diesel oil can keep the soot suspended better than gas engine oil. I probably is a bit better to bring deposits to the oil filter but I don't think it will clean the engine. Auto-rx is a good engine cleaner, recommended at bobistheoilguy.com.
Old 03-22-2007, 07:23 PM   #5
97coupe
97coupe is on a distinguished road
It does have a higher detergent base because diesels tend to be a lot dirtier in crankcase area and the oil has to have the ability to combat this.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Old 03-22-2007, 09:56 PM   #6
FrozenPilot
FrozenPilot's Avatar
I used Rotella T 5w40 for several oil changes in my S. I gave it a shot based on it being a quality synthetic with HDEO robust properties, something I felt I needed to free up the oil control rings, control consumption, and maybe have a cleaner engine. Without having an oil analysis done at every change, i didn't really know what was going on.
I started trying Havoline 5w-30 based on Bobistheoilguy, and also had what seemed like great results, 1/2-1 qt used between changes. But, SM-rated oils have come out, and it seems no matter what I use, my Saturn has been using it at that rate. I like Havoline on a price/performance scale.
Since I am a professional pilot flying piston engine aircraft, seeing how they use oil, and how long they last before an overhaul, I feel it is far more important to have motor oil at the proper level in the crankcase than weight, brand, or any other factor. Whatever you decide to use, just make sure to "CHECK YOUR DAMN OIL!"
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline   Reply With Quote
Old 03-22-2007, 10:23 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
check this out http://en.wikipedia.org/wiki/Motor_oil they mention the Saturn S-Series
The 3000 Mile Fact
There are still vehicles that need 3K oil changes, but it's not because the oil goes bad after 3K miles. One example is the Saturn S series. These vehicles have a timing chain system that is very sensitive to clean oil because oil pressure is used as hydraulic fluid to ratchet up the timing chain tensioner. If varnish forms in the timing chain tensioner bore then this system can fail and the chain will become loose and eventually break. Dealers have gone as far as tearing out the normal service schedule (6000 miles) and leaving only the severe service schedule. If an engine is destroyed by a failed timing chain while under warranty, then the dealer will legitimately request evidence of oil changes from the owner.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 03-26-2007, 11:29 AM   #8
Dubhlachan
Dubhlachan's Avatar
1998 SW2
Checkered Flag Re: Diesel Oil -vs- Gas Oil ?
Thanks for all the replies. I'd suspected what seems to be the general consensus, that it's not that much different than regular motor oil.
Interesting about the timing chain tensioner, I hadn't thought about that.
I've read an article about various manufacturers going to a higher service interval because "today's oils are more robust and car engines are designed better" but after reading that blurb from Wiki I think I'll stick to my regular schedule.
Thanks all.
Is there any reason I should get oil changes if im burning oil and put fresh oil in. AtlanticBeach S-Series Tech 12 08-01-2009 06:52 AM
pao? explaine and diesel oil search irondiezl3 General Saturn Discussion 1 01-18-2009 12:50 PM
Amsoil Heavy Duty Diesel 5-30 synthetic oil ScottSaturn83 S-Series Tech 6 10-19-2008 12:51 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 11:25 AM
gas vs diesel filler necks saturnsctwo S-Series General 11 09-14-2005 11:19 PM
