Old 03-10-2007, 07:01 PM   #1
ThePlainsman
ThePlainsman is on a distinguished road
ThePlainsman's Avatar
Default What Octane Gas Are You Putting in Your Outlook?
The manual says it should be at least 89. So I've been using 89. However, I started to notice some low speed sluggishness appear, even after the tranny update. It wasn't lag; it was sluggishness, like it was driving through tire-deep mud. So I burned fuel down close to empty and filled the tank this time with the expensive stuff--93 Octane.
Improvement came immediately. The "mud" disappeared and I had my post-tranny update Outlook back. Forget that 89 Octane crap. From now on, I'm only filling up with the "good stuff."
2007 Saturn Outlook XR AWD, loaded, including HIDs and heated leather
2008 Acura RDX-Tech, loaded, including HIDs and heated leather
2002 Nissan Altiima V6, loaded, including HIDs and heated leather
Add to ThePlainsman's Reputation
Rate the quality of this post and help ThePlainsman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ThePlainsman is offline   Reply With Quote
Old 03-10-2007, 07:33 PM   #2
zielinab
zielinab is on a distinguished road
2008 Outlook XR
Default Re: What Octane Gas Are You Putting in Your Outlook?
That's odd. Saturn's website says 87 Octane required. I wonder if you just got a batch of bad gas previous to your 93 octane fill-up?
Add to zielinab's Reputation
Rate the quality of this post and help zielinab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zielinab is offline   Reply With Quote
Old 03-10-2007, 07:50 PM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
I saw 85 octane in Denver... The ION I was driving was a slug and gave only 20mpg.
Add to BobbyP's Reputation
Old 03-10-2007, 10:21 PM   #4
ThePlainsman
Could be, but there was a noticeable different in pick-up.
Old 03-10-2007, 11:27 PM   #5
Outlook IL
Outlook IL is on a distinguished road
Outlook IL's Avatar
2007 Outlook XE
87 with no problems (but mileage?)
Add to Outlook IL's Reputation
Rate the quality of this post and help Outlook IL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Outlook IL is offline   Reply With Quote
Old 03-11-2007, 09:40 AM   #6
MrBiz
MrBiz is on a distinguished road
MrBiz's Avatar
I have not tried anything other than 87 octane yet. And, on our 1K+ trip this week I got 23.8 MPG and did not have any sluggishness. Oh, I forgot to mention that mine is an XR with AWD. I'm not sure I want to change to 93 octane, even though something inside of me says give it a try. Are there any problems bouncing between the two?
Biz
___________________________________
2004 Saturn ION 2
1996 Saturn SL 2
1992 Saturn SL 2
Add to MrBiz's Reputation
Rate the quality of this post and help MrBiz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrBiz is offline   Reply With Quote
Old 03-11-2007, 01:21 PM   #7
zielinab
2008 Outlook XR
Other than the extra $.20/gal flowing from your wallet for the good stuff, nope!
Old 03-11-2007, 04:32 PM   #8
WopOnTour
WopOnTour will become famous soon enough
WopOnTour's Avatar
Actually the Outlook Owner's Manual states:
"Use regular unleaded gasoline with a posted octane rating of 87 or higher. For best performance or trailer towing, you could choose to use middle grade 89 octane unleaded gasoline."
Using a higher grade octane may result in the use of a "high octane" timing table that provides additional ignition advance and may result in improved throttle response and fuel mileage. There's no problem switching or mixing as the system automatically adjusts based on observed knock retard and estimated fuel volatility.
HTH
WopOnTour
Add to WopOnTour's Reputation
Rate the quality of this post and help WopOnTour reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WopOnTour is offline   Reply With Quote
Old 03-11-2007, 05:52 PM   #9
jrocco001
jrocco001 is on a distinguished road
HTH
WopOnTour
Sooooo....what are the horsepower and torque numbers based on? Low or high-octane? Does it matter? (seems like it would based on your note). I'm not sure how it could work both ways - either the engine develops 275 horse w/ normal gas, or more power w/ better fuel. (Or am I way off-base here...I know in older cars the power was still there regardless of fuel but you would be damaging the engine w/ knock...newer vehicles are able to compensate by retarding the ignition, but at the cost of power. I definitely noticed this on my supercharged Grand Prix - it ran like a champ on 93 octane, crap on anything else.). Will I get better economy and power w/ higher octane fuel in the Acadia (or Outlook)?
I'm proud of the GM "high-feature" 3.6 liter V-6...unlike the 3.5 VQ in a Nissan or the 3.5 in the Acura TL, it's pumping out comparable power without requiring expensive gas (93 octane required is both those vehicles). My Acadia manual is the same as the Saturn (87 is fine, 89+ "suggested" for towing).
Add to jrocco001's Reputation
Rate the quality of this post and help jrocco001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jrocco001 is offline   Reply With Quote
Old 03-11-2007, 08:47 PM   #10
Tumblerats
Tumblerats is on a distinguished road
We have XR FWD, and have only used 87 octane. I have not noticed any problems. We have 6700 miles on it thus far. Last trip I got 24.1mpg on highway doing 75mph.
Add to Tumblerats's Reputation
Rate the quality of this post and help Tumblerats reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tumblerats is offline   Reply With Quote
Old 03-11-2007, 09:04 PM   #11
ternst
ternst is on a distinguished road
I read somewhere once that while higher octane gas will get you more horsepower, it will also get you less MPG, and that lower octane will often give you the best MPG. I found that to be the case with the past four SUVs that I've had - two Mercs, an Acura MDX, and Volvo XC 90. They all called for 91 octane, but I normally just used regular 87. My MPG was always higher than sticker estimate, and when I had to use a higher octane I found the MPG did indeed go down. I put over 100,000 miles on nearly all of these vehicles (160,000 on one of the Mercs) and never had any sort of engine issues, and they all seemed to perform just fine to me out on the road, even when loaded down (I'm not a hot rodder though). So I was actually a little disappointed to see that when my new Outlook arrives in a few weeks from the factory I won't be able to use a lower octane fuel since it already takes regular!
The fact the Outlooks only need 87 octane is a feature I have not seen advertised much - really a big savings in the long haul vs. most of the rest that require 91 (unless you have always cheated like me)...
Add to ternst's Reputation
Rate the quality of this post and help ternst reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ternst is offline   Reply With Quote
Old 03-11-2007, 09:06 PM   #12
Tbonedawg08
Tbonedawg08 is on a distinguished road
Tbonedawg08's Avatar
2000 L-Series 3.0L Sedan
all i've ever heard about higher octane was that it burns hotter and that's it. i've always heard that using higher octane is bad in the long run and doesn't improve performance...
but i'll be willing to give it a shot...maybe once gas goes down...it raised 40cents in the last week!!
btw, it'll be in my SC2, so it's a little different...
I'm just a normal car-crazy 17 year old...who is an intern at the police station. Trust me. That's saved me more than a few times
2002 SC2- 1.9L I4
2000 LS2- 3.0L V6
1993 1500 Silverado- 5.0L V8
Add to Tbonedawg08's Reputation
Rate the quality of this post and help Tbonedawg08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tbonedawg08 is offline   Reply With Quote
Old 03-11-2007, 09:19 PM   #13
WopOnTour
WopOnTour's Avatar
http://www.sae.org/technical/standards/CPGM1_07LY7DUAL
The specifics of the fuel used for the GM LAMBDA can be found in this document. The fuel used will be from a Top Tier commercial source that specifically complies with new SAE J1349 standard which initated a much needed return to OEM honesty in the documentation supporting officially published HP/TQ numbers.
Using AT LEAST the fuel recommended in your owner's manual will provide the commercially expected performance levels. However, these days using higher octane fuel CAN result in significantly improved performance and even economy, due to multiple timing tables used that are somewhat dependant on the fuels being used. Old school was a single timing table or advance curve that "assumed" a fuel grade, now with these newer generation control modules the fuel itself will have a specific influence on the actual table being utilized to calculate your desired ignition advance throughout the entire range of temperature, RPM and load.
HTH
WOT
Old 03-11-2007, 09:38 PM   #14
farmasis
farmasis is on a distinguished road
farmasis's Avatar
I only use 87 octane. No sluggish at all.
Calculated MPG this tank at 21.2 mixed driving.
Add to farmasis's Reputation
Rate the quality of this post and help farmasis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
farmasis is offline   Reply With Quote
Old 03-12-2007, 07:32 PM   #15
ThePlainsman
HTH
WOT
Wow!! You've sold me. I'm sticking with the good stuff! I'm less concerned with 1 or 2 mpg than performance.
Old 03-12-2007, 11:19 PM   #16
BrightOutlook
BrightOutlook is on a distinguished road
BrightOutlook's Avatar
2007 Outlook XR
2001 L-Series 2.2L Wagon
... these days using higher octane fuel CAN result in significantly improved performance and even economy....
It is clear that some saturnfans believe this, and we might all like to, but..........
Where exactly did you get this idea? Is it supported by scientific data? If yes, under what conditions was it studied? What are the P values on the significances you cite? Saying "even economy" together with "significantly improved" seems suspect if this is supposed to be real science.
Thanks,
Skeptical Optimist
Add to BrightOutlook's Reputation
Rate the quality of this post and help BrightOutlook reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BrightOutlook is offline   Reply With Quote
Old 03-13-2007, 12:09 AM   #17
WopOnTour
WopOnTour's Avatar
Thanks,
Skeptical Optimist
LOL
This doesn't require empirical evidence or a study.It's pretty basic engine combustion theory- buy a text book if you like. If you've ever "power timed" an old prehistoric distributor ignition system, generally you want to maximize your ignition timing without getting detonation (ping) for your given fuel octane. This IS KNOWN to provide maximum power AND economy for THAT engine, with THAT fuel, under the EXISTING conditions.Have you ever retarded ignition timing a fixed amount? say 10 degrees? The result? reduced power output, and more fuel consumption.Pretty basic stuff.
In short using higher octane fuel will allow the E67 ECM used with the High Value V6 to run additional timing advance. The actual realized benefits of this in terms of improved economy will of course depend greatly on conditions and actual operation. Let's just say it HAS been observed.
I suggest you try it for yourself if you can afford it. But YMMV (literally)
WOT
Old 03-13-2007, 12:26 AM   #18
WopOnTour
WopOnTour's Avatar
Thanks,
Skeptical Optimist
LOL
In short using higher octane fuel WILL allow the E67 ECM used with the High Value V6 to run additional timing advance. The actual realized benefits of this in terms of improved economy will of course depend greatly on the conditions of actual operation. But let's just say it HAS been observed in "unofficial studies" LOL
I suggest you try it for yourself if you can afford it (tougher since the recent fuel price increases- I know) The difficulty will be weighing any observed MPG gains against the additional cost. depending on the price differences between 87 and 93 in your area, there will be a point of course will it might be of little or no economic benefit. But YMMV (literally)
WOT
Oops, sorry for the duplicate post, I wasnt finished editing the original- forgot about Charlie's penchant for 15 minute time limits
Old 03-13-2007, 10:17 AM   #19
FalconXR
FalconXR is on a distinguished road
FalconXR's Avatar
2007
Thanks,
Skeptical Optimist
Well I don't really believe all the numbers until I do some testing myself. I have never had a vehicle get the sticker stated MPG's, maybe because of the hilly terrain where I live and commute through, or maybe it's the quality of fuel.
I'd like to know the type of fuel being used for their MPG testing and the terrain; average elevation changes, elevation over sea level, type of gas (87,89,93) and the amount/types of additives in the fuel.
My XR AWD does perform better with 89 vs 87 and does get a little better mileage. Through my calculations there is a 1 to 2 MPG increase using the 89 octane fuel. But when calculating the cost per mile it comes close to being the same. With the fluctuating prices in fuel it gets harder to track but I have calculated from $.01 to $.02 savings per mile using 89 over the 87. Granted, it is only 1 or 2 cents per mile but over 100,000 miles its a savings of $1000 to $2000.
Just my $.02 worth,
Falcon
Outlook XR AWD
Charcoal Gray
Black Leather w/ 2nd row Captain chairs
Loaded w/ everything but DVD and Nav
Add to FalconXR's Reputation
Rate the quality of this post and help FalconXR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FalconXR is offline   Reply With Quote
High Octane Gas Urespa1 L-Series Tech 8 03-21-2008 10:23 AM
Car makes a weird sound, but only with 87 octane gas??? bryank930 S-Series General 29 05-11-2006 02:41 PM
Gas Octane and milege speaker S-Series General 21 04-01-2005 08:18 AM
What Octane Gas Do You Run? SL1Joe S-Series General 33 11-02-2004 10:46 AM
Any difference 87 octane gas to 93 octane gas in a Saturn 98greenSC2 General Saturn Discussion 21 05-20-2004 08:40 AM
