Old 03-02-2007, 11:32 AM   #1
BelleBenn
BelleBenn is on a distinguished road
2002 VUE 3.5L
Default Oil leak 2002 VUE
I had my car in for service - replaced the crankshaft sensor. The dealership told me that I have an oil leak and need the oil pressure regulator replaced. The cost is $450.00. They did not have the part in stock and told me to bring it back to have the work done. The car is running ok so I am hesitant to have the repair. I am afraid that if I don't have the part installed I will end up with bigger problems. I have checked the oil several times and it seems fine.
Any advice would be appreciated.
mileage 68,000
V6/AWD
Add to BelleBenn's Reputation
Rate the quality of this post and help BelleBenn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BelleBenn is offline   Reply With Quote
Old 03-02-2007, 09:06 PM   #2
Default Re: Oil leak 2002 VUE
The oil pressure regulator would be more internal to the engine and coul dnot leak externally.
Oil pressure sending unit perhapps????? If so it would not be 450$ to replace. Are you actually getting an oil leak onto the ground?
If nothing else make asure that you keep a close eye on the oil level. Check after each fuel fill.
Add to ssicarman's Reputation
2002 Vue Power-Take-Off / transfer case leak nil5 Vue Tech 10 10-07-2013 07:43 AM
2002 SL1 Oil Leak dplemmons S-Series Tech 5 11-05-2009 12:25 PM
SUNROOF leak on 2002 VUE Wayne Smith Vue Tech 5 04-13-2005 06:17 AM
Oil leak in 2002 V6 RushVUE Vue General 8 01-09-2004 10:23 PM
Oil Leak on a V6 Vue skiboutins Vue General 2 11-04-2003 08:16 PM
