Old 02-13-2007, 04:37 PM   #1
Donny
Donny is on a distinguished road
1998 SW2
Default PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) This is the code I pulled from my 98 SWII with 158K on it. Which O2 sensor is this? I'm guessing it most likely needs to be replaced right? I have a couple of extra sensors from a 96 SL2 that I tore apart a few years ago. Will this work? Aftermarket? New?
Thanks
Don
Add to Donny's Reputation
Rate the quality of this post and help Donny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Donny is offline   Reply With Quote
Old 02-13-2007, 05:24 PM   #2
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Default Re: PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
The banks are relative only to V-type engines. All inline 4 cyl engines only have a bank 1. Sensor number relate to their position relative to the catalytic converter. Sensor 1 is always before the cat. Sensor 2 is always after the cat. Replace the sensor. It's dead. Personally, I'd use a new one. You don't know how old the replacement sensors are, but I guess you can always give it a shot.
Old 02-13-2007, 06:01 PM   #3
Donny
1998 SW2
Thanks Gerry, interesting we both signed up in Oct. 2002 and at the time of the original post I had posted a total of 24 times and you had posted 1244 times. What does it all mean?
Thanks for your response. I'll probably pick up a new one. Just to clarify then, the one I need to replace is in the exhaust manifold right?
Don
Old 02-13-2007, 07:08 PM   #4
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Yes, the sensor in the manifold. And the post count means I need to find something productive to do.
Old 02-13-2007, 07:15 PM   #5
Donny
1998 SW2
Helping people is productive. You saved me the hassle of figuring it out myself. Thanks Gerry.
Old 02-16-2007, 12:21 AM   #6
Donny
1998 SW2
Just an update. I replaced the sensor with a Bosch from Kragen for $23 and everything seems to be fine.
DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1 ivymotorsports S-Series Tech 1 04-26-2009 12:29 AM
SES, Oxygen Sensor, Bank 1 Sensor 1 Shadowless L-Series General 3 09-03-2007 08:23 AM
Sensor 1 Bank 1 (O2 sensor issue?) jakearoo S-Series Tech 6 08-22-2006 03:43 PM
O2 Sensor slow response? SATILLAC1 S-Series Tech 19 09-14-2004 12:54 PM
SES again - Bank 1 O2 sensor slow. Red97sc2 S-Series Tech 15 08-07-2004 09:30 AM
