Old 02-06-2007, 10:06 AM   #1
jjseiler13
jjseiler13 is on a distinguished road
Default High Idle Issue
Hello,
I have been having problems with my '99 SC2 DOHC idling at about 950-1000 RPMs in park and 850-900 RPMs in drive (after car is heated up). I have changed the Coolant Temp Sensor, Idle Air Control Valve, Checked the EGR, Changed the PVC and hose, can't seem to find a vacuum leak, changed the Plugs and Wires, and cleaned the throttle body. The car run like a champ now, except for the idle being a bit high. Any ideas would be greatly appreciated. I also have an issue with the tach, it seems to bounce very quickly, like the needle vibrates up and down, between 0 and ~100 for about ten seconds when the car is turned on or off, after this happens it acts normal. Again any help would be greatly appreciated.
Thank You in advance.
Add to jjseiler13's Reputation
Rate the quality of this post and help jjseiler13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjseiler13 is offline   Reply With Quote
2000 SL1 high idle issue huey graphite S-Series Tech 1 10-15-2009 01:39 PM
97 with high idle issue tiger saturn S-Series Tech 2 04-07-2007 09:14 PM
High Idle, AC/Compressor Issue SL1Joe S-Series Tech 5 02-28-2007 05:09 PM
Tranmission Issue and High Idle in park/neutral jamieg1984 Ion General 3 01-19-2007 03:40 PM
High Idle Issue... Neo Ion General 6 01-18-2005 01:51 PM
