Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Tech
Old 02-05-2007, 03:18 PM   #1
my98SL1
my98SL1 is on a distinguished road
Sad Differential Oil Leak ( Huge puddle )
Hi,
Just want to update all the SKY owners here-- Had noticed some oil from the under the car in the drive way - took it in today and when they hoisted the car .. there was huge puddle of oil just oozing out from the differential.
Hoping it is not gonna be fatal to the tranny.
Only have bout 5K on the car and was bought in July 06.
Disappointed ?? Not yet, but if the tranny goes.. I would like to have a word with the quality control guys at GM ( See the superbowl AD ?? )
Add to my98SL1's Reputation
Rate the quality of this post and help my98SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
my98SL1 is offline   Reply With Quote
Old 02-05-2007, 03:57 PM   #2
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
Default Re: Differential Oil Leak ( Huge puddle )
Originally Posted by my98SL1 View Post
Hi,
Is this a manual or automatic? If it's a manual, it's an Aisin, so you can blame Toyota.
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Old 02-05-2007, 04:14 PM   #3
my98SL1
Its an automatic transmission : - ((
Old 02-06-2007, 03:19 AM   #4
burnout
burnout's Avatar
Uhm, the differential isn't a part of the transmission.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-06-2007, 08:11 AM   #5
K-1
K-1's Avatar
2008 Astra XR
My brain is hampered by FWD cars. Stupid me.
IIRC, the differential is the same as was used in the CTS. I do remember hearing about diff leaks back when it first came out. You'd think they would have that worked out by now.
Old 02-07-2007, 09:00 AM   #6
JPDucketts
JPDucketts is on a distinguished road
we have seen a few cases here of the leaking rear diffs. most with low mileage (under 10,000 miles.) I recently serviced a Solstice and noticed the diff leaking. it had only 5500 miles on it.
Add to JPDucketts's Reputation
Rate the quality of this post and help JPDucketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JPDucketts is offline   Reply With Quote
Old 02-08-2007, 01:58 PM   #7
my98SL1
OK. So got the car back from the dealership today. The service tech told that there is a bulletin out from GM to fix this issue ( similar to the "Water intrusion into transmission" bulletin ).
So - SKY owners lookout - call and ask your dealership to bring the car in and get this fixed ( i am thinking that oil leaking from the differential is not a good thing )
But here is the catch or issue:
when trying to make a tight turn the rear passenger side tire seems to grind and skid - kind of make a metal-metal rubbing noise, like its being pulled ( the sound is like gears grinding or something trying to turn in the wrong direction ). Does anyone know what could be the problem ? Please advise. Want to make a complete report to the dealership this time - lest they blow me off.
Thanks
Old 02-09-2007, 12:01 PM   #8
my98SL1
Updates:
Took the car back to the dealership to check out the "rubbing" noise described y'day. Was told that the tech who serviced the car for the differential oil leak -forgot to top off the oil in the differential well - so basically I drove the car around for almost a day and half without enough oil - don't know what kind of damage it could have done.
Lesson learn't - if there is a oil leak or whatever make sure that they top off the oil. Do not assume that these guys would do it for you.
Question: How do i rate/describe the visit to the dealership ?
a: "Oops my bad"
b: "we will ask you to work with a diff service rep each time"
c: "Does not matter - we will screw you over again"
Old 02-12-2013, 07:25 PM   #9
luciano
luciano is on a distinguished road
Thumbs Up Re: Differential Oil Leak ( Huge puddle )
Hi,
Add some ATP 205 reseal you will be amazed worked on a rack pinion stopped the leak for 2 years now
Add to luciano's Reputation
Rate the quality of this post and help luciano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
luciano is offline   Reply With Quote
Puddle of oil spork L-Series Tech 4 02-12-2009 09:56 AM
91 SC HUGE oil leak please help. SWargy S-Series General 22 09-14-2008 10:25 AM
Leak in Differential berls1955 Sky General 4 09-14-2007 08:33 PM
Water leak = HUGE need solution for damage SL2Dreams S-Series General 5 10-04-2003 12:45 PM
Huge trans leak 2000sl2s S-Series Tech 1 07-15-2003 10:13 PM
