Old 01-31-2007, 07:41 PM   #1
SaturnManiac
SaturnManiac's Avatar
Default The cylinder 4 misfire curse
Well my car's been having a cylinder 4 misfire for a while now, it's not all the time. The SES light comes on about once every tank of gas, and doesn't stay on for more than 1/8 of that tank. But, anyways, I'm almost running out of options here.
So far I've replaced:
Spark plugs with NGK coppers, gapped at .040"
Spark plug wires
Fuel injector on cylinder 4
Swapped out coilpacks and DIS module with known good ones
Cleaned EGR valve (Although that probably wouldn't case the misfire.)
Cleaned Throttle Body (Also, I doubt that would case a misfire, LOL.)
Also ran a compression test, and that turned out fine.
So I'm thinking the next step is to check the fuel injector wiring.
But I was also wondering, since I confirmed I have a junkyard engine in my car (Confirmed that when I swapped out the coilpacks and DIS module), what wiring would that have changed or touched that I might not be thinking about?! Come on Low Saturn, I'm sure you know every wire removed during an engine swap
And, yes I'm going to fix this, not going to do like some of my friends said and just put tape over the light. I won't give up!!!!
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-31-2007, 11:00 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: The cylinder 4 misfire curse
Two things to try. Listen to the fuel injector with a stethoscope or an ear against a long screwdriver and see if it's clicking. If it is, the wiring's probably okay. Then try swapping the injector to with one on another cylinder to see if the miss moves. If it does, the injector's bad.
Add to BarnOwl's Reputation
Old 01-31-2007, 11:22 PM   #3
mkuz13
mkuz13 is on a distinguished road
2009 AURA XE
I wonder if the intake manifold gasket is starting to leak air at the #4 intake port.
With the car idling,spray some brake or carb cleaner around the #4 intake port where its bolted to the cylinder head.If the idle changes,then that might be your problem.
Want more gun control? Then use both hands.
Add to mkuz13's Reputation
Rate the quality of this post and help mkuz13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkuz13 is offline   Reply With Quote
Old 02-01-2007, 01:27 AM   #4
ksion15
ksion15 is on a distinguished road
2003 ION-1 Sedan
2005 RELAY-3
my thoughts exactly. although, thats where the common coolant leak is on these plastic intake manifolds. you might just be getting coolant in with the intake air. there's a new two piece design gasket. it has a seperate coolant portion aside from the intake air side.
Add to ksion15's Reputation
Rate the quality of this post and help ksion15 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ksion15 is offline   Reply With Quote
Old 02-01-2007, 01:56 AM   #5
jerry dye
jerry dye is on a distinguished road
well, you seem to have checked all the obvious, now since you confirmed a junkyard engine, is it possible you may be having an intermittent floating valve, this would be noticable in a slight knock in the upper part of the engine, while the miss is happening.
Add to jerry dye's Reputation
Rate the quality of this post and help jerry dye reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jerry dye is offline   Reply With Quote
Old 02-02-2007, 02:08 PM   #6
SaturnManiac
Wouldn't that show up on a compression test?! We did a compression test and it turned out fine. But I don't hear a knocking.
As for the intake manifold gasket, isn't that more common on the SOHC's, as doesn't it usually seem to affect cylinder 1 (I can't remember, I've read about it several times here before.) But I thought with that you usually lost coolant, well my coolant level is fine.
The only other thing that comes to mind, is since the engine was swapped, not sure with what year engine, (I need to go look and get the year code off of it), could it be something like I just need my computer reprogrammed to work with that engine?! I don't know, I've never done an engine swap on these cars, haven't even seen it done.
I was just curious also if there was any other wiring I might be leaving out that could cause it that could've possibly not gotten connected properly or perhaps got pinched during the engine swap....I know these cars have alot of electrical stuff on them...so I just felt like double checking.
BarnOwl, it is so funny that you mention the long screwdriver trick, I taught that to one of my friends and he thought I was a redneck for knowing that, LOL.
Old 02-02-2007, 02:23 PM   #7
BarnOwl
BarnOwl's Avatar
lol You have seen my steering wheel puller (In my gallery.) for '99 and up steering wheels that don't have threaded holes, right? I actually do have a stethoscope but, that screwdriver trick is older than dirt.
Actually ksion15 may have something. I seem to remember ssicarman posting something about that too. The thing is, if that's what was going on, you wouldn't be able to find it with the usual carb/brake cleaner trick. Also didn't you mention that you were losing some coolant recently and couldn't find the leak? It wouldn't be a common thing but, you've tried all the common things and some uncommon things.
All of the above said, if someone swapped in an engine and kept the old PCM, it's quite possible that you need a crankshaft relearn.
Old 02-02-2007, 04:00 PM   #8
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
SSI, Madpogue and I have all told her that it is a possible intake gasket leak. She says no, and dismisses us. The plastic intakes dont really leak air like the SOHC, they leak coolant into #4 since it is right next to it.... It would explain your coolant light too!
http://www.saturnfans.com/forums/sho...ke+gasket+leak
Remember this? Does it not explain your issues to the letter? I would be shocked if it isnt it.
It is not common, but I have seen it more than once, they updated the design because the gasket would warp. It warped and leaked into #4 only as well as into the EGR port, thereby letting #4 get all of leaked coolant. Enough to cause a misfire condition.
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-03-2007, 12:13 AM   #9
SaturnManiac
The thing is I don't have a coolant leak anymore, that was a hose problem....that's why I said it probably isn't the intake manifold gasket leak.
Here's the thing though, wouldn't that get worse over time, say if I was leaking just air?! It hasn't gotten worse....actually it seems everything I do, it gets better for a while....or at least runs a little better, probably because newer and better parts.
I'm almost now into the theory that something is wrong with the engine even though it didn't show up on a compression test.
My friend told me if I send my oil off for an analysis, I might learn something, is that true?! I'm assuming they can tell you a little something about your engine by analyzing the oil.
I just need to do an MMO soak, it can't hurt, it can only help.....maybe do it next month before oil change.
Not saying it couldn't be the intake gasket, but I asked Saturn about it, and both retailers said that wasn't the problem.
Just curious, how much would Saturn charge me to install a new one?!
I'm not trying to be rude or anything.
Also, I was wondering could I just need a PCM reprogram for some odd reason?!
Old 02-03-2007, 08:18 AM   #10
BarnOwl
BarnOwl's Avatar
As I said previously, if you've got a junkyard engine in there, it's certainly possible that you need a crankshaft relearn.
As far as the oil analysis goes, it might confirm that it's the manifold gasket. We aren't talking air leaking in this case. The gasket is holding air. It's coolant leaking and probably not very much. I think it would show up in the oil if that's what's going on.
cylinder misfire srowley S-Series Tech 2 07-17-2009 02:43 PM
Cylinder Misfire again and again and again and again ! AAM S-Series Tech 2 07-04-2008 08:49 PM
Misfire in Cylinder 1 karty72 S-Series Tech 8 07-13-2007 05:09 AM
Misfire on cylinder 5 gtzman90 Vue Tech 0 02-17-2007 09:32 PM
3.5L cylinder 5 misfire bluesl2 Vue Tech 2 08-11-2005 10:14 PM
