Old 01-29-2007, 10:23 PM   #1
acatlin
acatlin is on a distinguished road
Default Which fuse is ABS? (see pic)
I want to disable my ABS. I have read in one thread that removing the ABS fuse under the hood will do the trick. I am comparing the diagram in the repair manual with the actual box and it doesn't seem to match up.
Can anyone look at the photo attached and tell me which fuse is for the ABS? I have attached the diagram as well for comparison.
Also, the ABS and traction control work as they are supposed to right now. If I remove the fuse, and am not happy with the results, do you think the system will still work fine if I reinsert the fuse at a later time?
Thanks for any insight on this issue.
Adam
http://64.141.135.11/relaybox-n-diagram.jpg
Add to acatlin's Reputation
Rate the quality of this post and help acatlin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acatlin is offline   Reply With Quote
Old 01-29-2007, 11:31 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Which fuse is ABS? (see pic)
Well I don't know where you got that diagram. There should be one in the cover of the junction box though. I looked at a one for a '98 and it looks a lot more like your box. However, according to that diagram the ABS fuse goes in that empty socket by the fuse puller. It looks like yours is already out.
Add to BarnOwl's Reputation
Old 01-29-2007, 11:43 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Well I assume you still have the cover for the fuse box since its clean and the surrounding area is dirty. Why not look on the bottom of the cover?? Or even the owners manual?
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 01-30-2007, 12:07 AM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Yellow 5amp fuse, top row, second from the end.
Mike
-2000 Saturn SC2
Old 01-30-2007, 07:14 AM   #5
acatlin
Thanks Mike, I will give it a try after work today!
Adam
Old 01-30-2007, 07:32 AM   #6
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: Which fuse is ABS? (see pic)
The only thing is with doing that, your ABS light will be on.. I did a test with my 94 to see what stops better to have the ABS or not to have the ABS.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-30-2007, 08:46 AM   #7
acatlin
I also noticed another large 30A fuse (#8) labeled ABS, along the bank on the right. Should both of these be removed? Just the 5A?
Old 01-30-2007, 08:46 PM   #8
1994Saturn
1994Saturn's Avatar
1994 SL1
When i did the braking test, i only took out the 5A, and the ABS did not activate, how ever there will be a ABS light on. So if the light doesn't annoy you, that should be the fuse to remove.
Current:
Past:
94 SL1 Sold @134K.
Old 02-05-2007, 05:09 PM   #9
acatlin
Thanks, I tried it, and it worked. ABS light and Servie Engine light both remain on, but ABS is disabled.
Thanks for all the info.
Old 02-05-2007, 11:04 PM   #10
tarsun
tarsun is on a distinguished road
why do you not want the abs.
Add to tarsun's Reputation
Rate the quality of this post and help tarsun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tarsun is offline   Reply With Quote
Old 02-05-2007, 11:10 PM   #11
eRic 02sc2
eRic 02sc2's Avatar
I'm guessing the relay marked "GM ABS VI" is the ABS relay?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
can you replace abs master cylider with non-abs hobbs S-Series General 3 09-29-2008 04:34 PM
rear disk conversin. ABS to non-ABS =, also suspenion ? fetchitfido S-Series Mods 10 07-05-2006 12:40 PM
2001 SL2 ABS fuse photograph4 S-Series Tech 0 06-19-2006 09:37 AM
Supply Spare Fuse in Fuse Box mazzmn Suggestion Box 3 12-05-2004 10:14 PM
ABS fuse missing? Heartbeat - '95 SL2 Miscellaneous Tech 6 04-03-2001 11:43 AM
