Old 01-26-2007, 09:13 PM   #1
mathieuhouston2
mathieuhouston2 is on a distinguished road
Default 92 dohc no spark and no clue
so here it is, the car is 1992 1.9l dohc manual trans sl2. the problem started a few days ago. i was leaving work when the car died like the battery was dead and the alternator was not charging. i jumped the vehicle with another car and it ran fine for a few blocks and died. during that time my dash lights would not turn on. the car was completely dead. the next day i replaced the alternator and the battery with brand new parts. after they were installed the engine turns over but not start. i pulled a spark plug from all four cylinders one at a time to check for spark and nothin from any of them. so i replaced the coil packs. nothing. so i replaced the pcm, still nothing, so i replaced the dis module under the coil packs. guess what nothing. no spark. i've cleaned grounds and i tested the obd1 and it came back with zero fault codes. i tried to short the terminals manually and it did nothing the fan came on, and the coolant light lit up, but ses light is nowhere to be seen i replaced the cps, also the temp sensor. i tested the original parts for the proper resistance and they turned out fine, including the coils. my ses light is not coming on at all. i have two dif pcms, one refurb, one original, neither made a dif. i checked the timing chain, ok. it just cranks and cranks. theres no arc anywhere between the coils and the plugs. im am truly dumb founded, and i feel like im takin crazy pills. PLEASE HELP ME
Add to mathieuhouston2's Reputation
Rate the quality of this post and help mathieuhouston2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mathieuhouston2 is offline   Reply With Quote
Old 01-26-2007, 10:16 PM   #2
harsha
harsha is on a distinguished road
harsha's Avatar
2006
Default Re: 92 dohc no spark and no clue
Wav!!! Sorry to hear about your problem.. Looks like you have done your homework more than required and still you are failing..
Anyways. Pull the plug wires #1 and #4 at the coil pack. Let someone crank for few seconds. Normally, You should see sparks between the towers of the coil pack. I understand you checked for spark by removing one wire at a time. But this would confirm, "no spark" status and trouble shooting the problem.
Add to harsha's Reputation
Rate the quality of this post and help harsha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harsha is offline   Reply With Quote
Old 01-26-2007, 11:04 PM   #3
westwind999
1999 SW1
Kinda sounds like you're replacing parts until it runs. Do you have a volt meter? Do you know you are getting power to the coils? It might be a broke wire/bad fuse?
Perhaps the Crank Sensor has failed. If it doesn't detect that the engine is turning it won't send a spark.
Old 01-27-2007, 01:55 AM   #4
mathieuhouston2
well ive done the 1 and 4 arc check, nothing. ive ordered a new pcm but the guy sent me the wrong part. i have a volt meter and chiltons manual has some of the trouble shooting in it for this situation. ive tested the coils the cps, while i was going thuogh the schematic, the est ignition wire coming from the pcm is supposed to carry a 5 volt signal; however its less then a volt. my main concern is that something shorted out the pcm, and even if i order a new one its going to short out too.
Old 01-27-2007, 02:23 AM   #5
Ding-ding-ding, Don PARDO, tell 'im what he's won!
(BTW, if the CPS were a unit of currency, a PCM, coil packs, ig module, etc. would cost about 100 CPSes).
Add to madpogue's Reputation
Old 01-27-2007, 07:15 AM   #6
kthane
kthane is on a distinguished road
1999 SL1
Not to cut the victory party short here, but he said here replaced the CPS already.
Add to kthane's Reputation
Rate the quality of this post and help kthane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kthane is offline   Reply With Quote
Old 01-27-2007, 11:00 AM   #7
mathieuhouston2
the cps is brand new from murrays. still doesn't start
Old 01-27-2007, 01:44 PM   #8
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
With the ignition switch turned to the "ON" position,the "SERVICE ENGINE SOON" light should be on.This means there's ignition and battery supply to the PCM...................Did you check your fuses.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-27-2007, 04:11 PM   #9
mathieuhouston2
the ses lights not coming on but all the fuses are good and the rest of the dash lights come one. also i've checked to makes sure that all the fuses are getting voltage to the point of the fuse. im pretty sure ive got a short some where in there and im willing to bet its between the pcm and the cps. but that doesnt explain why my charging system failed.
Old 01-28-2007, 01:22 AM   #10
Assuming the following items are good replacement parts,
-battery
-alternator
-coil packs
-dis module
-cps
-ects
that leaves the vehicle wiring as a possibility. By replacing the battery and alternator together there isn't any way to know if the original battery/alternator was faulty according to your posts. That is one issue while the inability to get the engine to run is another issue more important at this point.
You may have to check the wiring that connects all the above but where to start? Since you've been posting all your troubleshooting steps along with observations there are some areas to start with if I may suggest. Not having any spark, either at the plug wire or between coil towers points back to the cps, since replaced, but didn't solve the ignition issue. This may require you to check the connector, wires and possibly power from one of the wires. That originates from the ignition module, dis module, or engine control module (not familiar with the s-series specifics). The cps must generate signals and may need power, either 5v or 12v. A wiring diagram would help here.
Re-check the connections to everything that was replaced, going over each connection carefully and observing for dry, cracked, brittle insulation that may have chafed against a sharp edge shorting some part of a circuit. Make sure the male/female pins and sockets fit together correctly for positive electrical conductivity.
93 SL2 DOHC no spark on cyl 2 and 3 FrstrtdStrnOwnr S-Series General 21 07-06-2009 06:54 PM
DOHC Spark Plug Wires acman S-Series Tech 5 01-02-2007 02:09 PM
3 or 4 bolts near spark plug holes on DOHC aluminum valve cover David 93 SL2m S-Series General 2 04-01-2006 05:44 PM
'02 DOHC Spark Plug Question 20VUE06 S-Series General 11 01-06-2004 02:06 AM
FS: SPS Spark Plug wires 91-95 black DOHC SLeepr Classifieds 0 05-17-2003 10:21 PM
