Old 01-19-2007, 03:53 PM   #1
hc803
hc803 is on a distinguished road
hc803's Avatar
1997 SW2
Default OBD Code: P0301 Cylinder 1 Misfire Detected
So right after my last post the other day regarding my rpm revs, I'm now "shuddering" my way down the highway. Did some research on here regarding Ox sensor, EGR, & ECTS replacement, then took it to Advanced for a scan:
P0301
Cylinder 1
Misfire Detected
Is this something as simple as new plugs and wires? Or one of the 3 issues above?
Thanks!
-Matt
.::'97 SW2::.
Add to hc803's Reputation
Rate the quality of this post and help hc803 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hc803 is offline   Reply With Quote
Old 01-19-2007, 04:07 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: OBD Code: P0301 Cylinder 1 Misfire Detected
If you have a high idle.This could be your problem.
http://www.saturnfans.com/forums/sho...ighlight=po301
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-19-2007, 04:17 PM   #3
hc803
hc803's Avatar
1997 SW2
No high idle (other than when I first crank up in the morning, but settles down after a minute).
The problem is during acceleration: hesitating, buck-ing, whatever you want to call it where the car feels like it's not getting gas and shuddering.
I'm thinking I'll start with new plugs and wires, since I probably need those anyway. The dealership said most likely the ECTS is bad and that they "fix those all the time on older models". Only issue is the sensor is $20 and the "harness" the guy said I'd need is $23, and probably minimum 1.5 hrs of work so I'm looking at a $200 minimum job for something that there is a DIY thread for on here.
Only other thing I can think of is a new coil.
.::'97 SW2::.
Old 01-19-2007, 04:19 PM   #4
Low Saturn
Low Saturn's Avatar
2008 AURA XE
Check for oil in the spark plug wells from a leaking camcover gasket. Just pull the spark plug wires out and see if theres oil down there. Thats the most common reason for a misfire.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
Old 01-19-2007, 04:23 PM   #5
hc803
hc803's Avatar
1997 SW2
Low:
Is that the same issue as the "intake manifold gasket" leak I've seen on here?
Sorry if that's a dumb question.
.::'97 SW2::.
Old 01-19-2007, 04:27 PM   #6
Low Saturn
Low Saturn's Avatar
2008 AURA XE
Originally Posted by hc803 View Post
Low:
Nope, completly different. THe camcover or valve cover sits on top of the engine, the intake manifold is on the back of the engine.
Mike
Old 01-19-2007, 04:35 PM   #7
BarnOwl
BarnOwl's Avatar
Just to add a correction here. This car is not one that is likely to get that manifold leak by cylinder 1. Those were the SOHCs. His sig says SW2. That's a DOHC. You can see Wolfman's guide to troubleshooting this problem here.
Add to BarnOwl's Reputation
Old 01-19-2007, 04:58 PM   #8
hc803
hc803's Avatar
1997 SW2
Low:
Good call, pulled the wire boot off #1 and there is oil down in there!
Now, is the leaky cam cover gasket something that's going to cost me out the wazzoo?
BarnOwl:
Wolfman's guide is correct in that it's only during accel and "hill climbing" (although around here, it's just exit/on ramps). My initial reaction was that the fuel injectors are clogged, as I had the same thing happen in my old GMC truck long ago (i.e. same herky-jerky engine). I hope it's not the EGR, since the Saturn dealer charges $172 for the part alone!
.::'97 SW2::.
Old 01-19-2007, 05:21 PM   #9
hc803
hc803's Avatar
1997 SW2
^^^to add to my above reply:
Just read Wolfman's how-to on cam gasket replacement.
Now my question is: is this something I can do with moderate skills?
Or should I just take it to the dealership?
.::'97 SW2::.
Old 01-19-2007, 05:25 PM   #10
Low Saturn
Low Saturn's Avatar
2008 AURA XE
I would say someone with less then moderate skill can do it.
The gasket is $20.48.
http://www.trademotion.com/partlocat...=4&catalogid=1
Mike
Old 01-19-2007, 05:49 PM   #11
Uzzy
Uzzy's Avatar
2002 SC1
Ya, it's not hard, just take your time, and make sure it's cleaner than clean.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 01-19-2007, 06:23 PM   #12
hc803
hc803's Avatar
1997 SW2
sounds good.
i'm going to pick up the gasket set from the dealership tomorrow ($38... eh, whatever) and some new plugs (NOT Bosch Plats, I know!) and wires from Advance and give it a go.
is it recommended i use RTV with the gasket? some say yes, some no.
(probably pick up a new ECTS while i'm there too.)
.::'97 SW2::.
Old 01-19-2007, 06:28 PM   #13
Low Saturn
Low Saturn's Avatar
2008 AURA XE
Only a small bead on the joint where the timing chain cover meets the head.
Mike
Old 01-21-2007, 01:59 PM   #14
hc803
hc803's Avatar
1997 SW2
how long should i wait to let the rtv set before i start her back up?
.::'97 SW2::.
Old 01-21-2007, 05:19 PM   #15
eljefino
eljefino's Avatar
1995 SW1
The longer the better.
Try for overnight.
Add to eljefino's Reputation
Old 01-22-2007, 11:13 AM   #16
hc803
hc803's Avatar
1997 SW2
Default Update: The Morning After
Let the car sit overnight before cranking and other than having to figure out the "LOC" code for my stereo, no problems I can feel.
Drove approx. 15 miles to school, 65 mph, and up 6 floors of an inclined parking garage w/ no hesistations! Knock on wood!
Thanks everyone for your help, I still think I'm going to replace the ECTS since I already bought it, but that will be another weekend.
Will post if any problems arise, of course
.::'97 SW2::.
Old 01-22-2007, 11:25 AM   #17
BarnOwl
BarnOwl's Avatar
Look in the How-To Library. There's instructions for unlocking that radio there too. Consider the ECTS preventive maintenance.
How is misfire detected on Saturn SOHC? Tommie S-Series Tech 2 05-07-2009 07:59 AM
# 4 cylinder misfire code chopfensperger S-Series Tech 2 09-09-2008 08:14 AM
L100 cylinder number 1 misfire code. kalmss L-Series Tech 1 11-27-2007 07:18 PM
P0303 - Cylinder #3 Misfire Detected d4rkf1ber S-Series Tech 2 11-30-2006 07:13 PM
P0301 cylander1 misfire machine_man S-Series Tech 4 10-15-2004 09:48 AM
