what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 05-13-2002, 08:54 AM   #1
DAC94SL2
DAC94SL2 is on a distinguished road
Default Installed rear air deflector on VUE?
Has anyone installed a rear deflector on your VUE yet?
It's the last thing I need to get, and have not seen one at the dealer to see how it it is on. Any help would be greatly appreciated!!
Oh, and why is it when you do not need something, you see thousands of them, and then when you are looking for one, you could not find one to save your life. Had the hitch put on, and now I can't find a hitch cover!
Add to DAC94SL2's Reputation
Rate the quality of this post and help DAC94SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DAC94SL2 is offline
Old 05-13-2002, 12:09 PM   #2
Qlara
Qlara's Avatar
Question
Curious: Is the rear deflector a bolt-on type or clip-on type? With body color (I doubt!) or just smoke-black plastics like the front?
Anyone know better?
Add to Qlara's Reputation
Qlara is offline
Old 05-13-2002, 12:12 PM   #3
DAC94SL2
Default
It appears to be plastic, at least that is my impression from the book.
I was just wondering if it is a bolt on from the outside, or if it attaches some where on the inside of the gate.
DAC94SL2 is offline
Old 05-13-2002, 12:59 PM   #4
maynardf1
maynardf1 is on a distinguished road
maynardf1's Avatar
Default
It's smoke-black plastic.
I had the dealer install it, so I can't rate the ease of doing it yourself, but it's attached to two large brackets that you can't see once it's in place. The piece itself is attached to the brackets with four screws (two on each side) that are the same colour as the deflector.
It's well worth it. I drove around for almost a month before getting it, and I couldn't believe how dirty the back window got. It's much better now.
Add to maynardf1's Reputation
Rate the quality of this post and help maynardf1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
maynardf1 is offline
Old 05-13-2002, 01:04 PM   #5
Qlara
Qlara's Avatar
Happy
Haha, if it's so good why it's not built as stock.....
Another way to rip people's money by leaving out something effective and functional.
Qlara is offline
Old 05-13-2002, 01:32 PM   #6
Badger_Vue
Badger_Vue is on a distinguished road
Default
I installed mine. Not too hard if you follow instructions and dry fit the whole set up first and mask off the areas where the brackets go. They just have stick on adhesive so no holes to drill.
Make sure you get the clip on the front of the bracket all the way on the leading edge of the lift gate before you press down the adhesive. I didn't on the first one and barely got it off to resituate it.
The hardest part is centering it on the back since there really are no square edges to reference from.
Good luck if you go for it.
Add to Badger_Vue's Reputation
Rate the quality of this post and help Badger_Vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Badger_Vue is offline
Old 05-13-2002, 01:36 PM   #7
DAC94SL2
Default
Exactly! We have had the thing a few weeks and can not believ how much dirt gets back there.
Maybe I'll have to roll up to the other dealer in town and see how that thing is on there.
DAC94SL2 is offline
Old 05-13-2002, 03:20 PM   #8
suxcess
suxcess is on a distinguished road
suxcess's Avatar
Default Rear Deflector Price
How much did the Deflector cost? Does it increase wind noise?
Add to suxcess's Reputation
Rate the quality of this post and help suxcess reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
suxcess is offline
Old 05-13-2002, 03:59 PM   #9
DAC94SL2
Default
Adhesive!? You gotta be kidding me. Oh well, thanks for the tip, I'll need it.
Last time I checked, they were between 60 and 70 dollars. I am not completely sure.
DAC94SL2 is offline
Old 05-14-2002, 01:10 PM   #10
Badger_Vue
Default
I paid $68 and don't notice any wind noise or whistling. I put it on right away, so I can't compare how effective it is. I was just going by other's posts stating how much dust there was without one.
Old 05-15-2002, 09:51 PM   #11
Body Man
Body Man is on a distinguished road
Body Man's Avatar
1992 SC2
Default
Actually the tape that holds it on it strong, it's the same stuff that holds on body moldings on most vehicles. It's a product made by 3M, and I certianly wouldn't worry about it coming off unless you don't clean the surface properly befpre installing it.
Personally I like the rear deflector, it adds a little bit of style to the VUE and it's functional as well, but it's not for everyone.
Add to Body Man's Reputation
Rate the quality of this post and help Body Man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Body Man is offline
Old 05-16-2002, 07:27 AM   #12
DAC94SL2
Default
Yeah, I understand that the tape holds well. Found that out with the bumper pad or cover. I thought there would at least be a bolt or two. I hope it works well when I get around to getting it.
DAC94SL2 is offline
rear window air deflector saturn3 Vue General 12 06-19-2004 09:07 PM
Rear Spoiler/Air Deflector cuda2004 Vue General 22 04-05-2004 06:41 PM
Broken rear air deflector help our1vue Vue General 10 01-12-2004 07:35 PM
rear spolier vs air deflector snowdog Vue General 14 01-12-2004 06:10 PM
VUE Rear Air Deflector loopylav Vue Tech 2 03-29-2002 07:16 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
