Old 12-25-2006, 09:58 PM   #1
dracar
dracar is on a distinguished road
Default Wiring
Ok, i detached my stock 93 Saturn sl1's radio, cassete player and put in a new one, i snipped the old wires off the plastic connector that went into the back of the old radio and my dash lighs and the beep thing stoped working. For the new radio/cd palyer i have all the speakers hooked up, i need to know what color the old memory wire was, the old ground wire, and the old power wire were. After i hooked the speakers up, i have a tanish brown wire, a brown wire, a yellow wire, and an orngish wire left from the old radio, and a red(power), yellow(memory), and black(ground) from the new one. i had it once but droped the wires, i tried for 2 hours but couldnt get it right again. So basicaly wat would realy help would be, what wires do i splice to what other wires. Oh yea when i did have it touched were it worked, my memory didnt work and whenever i shut off my headlights or park lights, the power to the new radio got cut off...
Add to dracar's Reputation
Rate the quality of this post and help dracar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dracar is offline   Reply With Quote
Old 12-26-2006, 12:54 AM   #2
92[SL2]
92[SL2] is on a distinguished road
92[SL2]'s Avatar
1992 SL2
1992 SL2
Default Re: Wiring
The easiest way to do it would be to buy the wiring harness which hooks up to the stock Plug thing, and the colors are color coded to the same as most aftermarket stereo's. That's what i did, not to mention when you want to put another radio in you just unplug it... if you are unwilling to do that.
LF- Gry
LF+ Tan
RF- Dk. Grn
RF+ Lt. Grn
Ground Blk
Park Lps Brn
Dim Illum. dk grn
ign yel
B+ org
RR- lt blu
RRb+ dk blu
LR- yel
LR+ brn
hope that helps, straight from haynes service manual, you should invest in one....
Add to 92[SL2]'s Reputation
Rate the quality of this post and help 92[SL2] reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92[SL2] is offline   Reply With Quote
Old 12-26-2006, 02:50 AM   #3
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
Default Re: Wiring
Wow, just wow.
This is why places offer free installation. Im all for doing stuff myself, I do it all the time. They make wiring harness adaptors so bad things like you described dont happen. You should never, ever, ever cut the factory harness off. For a few bucks you can buy a harness that allows you to connect an aftermarket stereo without any cutting, splicing, crimping or thinking. Click, click, plug in the antenna, mount the radio, DONE..
BTW, today my brother gave his girlfriend a new Pioneer headunit for Christmas for her SC1. I had the old Blaupunkt out and the new Pioneer wired up, installed and working in under two minutes.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevy Suburban
-2008 Saturn Aura XE V6
Im out of EGR adaptors & ECTS connectors.
Old 12-26-2006, 10:46 AM   #4
Dimundave911
Dimundave911 is on a distinguished road
Dimundave911's Avatar
1998 SC1
Default Re: Wiring
Must have not been a third gen, took me a while to get my interior apart before i did mine. The second and third time i went in there was better but still takes me like 20 minutes to just get in there. jealous.
Dave
"Did you ever Dance with the devil in the pale moonlight?"
Add to Dimundave911's Reputation
Rate the quality of this post and help Dimundave911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dimundave911 is offline   Reply With Quote
Old 12-26-2006, 11:58 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Wiring
it seems that Saturn made it harder to remove the radio every time the interior was updated. my 92 SC was easy to pull out, the 96 SC2 was a bit more involved with the switches on top of the pod, then I looked in the service manuals for my 02 SC2 and decided that I'm leaving it alone it's got the CD and Cassette combo anyway. maybe I'll do the speakers. Those got harder too. the 92 SC rear deck grilles were removable. the 96 SC2 door grilles removed but you had to remove the entire package tray cover for the 96 SC2 and the 02 SC2 doesn't even have grilles on the rear deck so you don't even know if speakers are back there unless you look in the trunk.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-27-2006, 04:35 PM   #6
dracar
Default Re: Wiring
Hmm well is it possible that someone could like just post realy simple directions on teh way the wires need to be? like i said, i have 4 wires left, they have sumthin to do with the door dinger, not sure wat the real name is, and the dash lights. just need instructions like splice this wire with this one and so on, i can run the radio straight from the battery i just need to get my stuff working again, i dont understand the wiring braket stuff
Old 12-27-2006, 05:56 PM   #7
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: Wiring
This should show you every wire in the connector. Next time, just spend the $7 on a harness. They can be bought in walmart pretty cheap, and i hope you know you need an antenna adapter as well.
http://www.installdr.com/Harnesses/GM-Wiring.pdf
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 12-27-2006, 09:15 PM   #8
dracar
Default Re: Wiring
dont think i need an adapter, it seems to fit fine
Old 12-27-2006, 09:25 PM   #9
Low Saturn
Low Saturn's Avatar
2008 AURA XE
Default Re: Wiring
Are you removing a factory radio and installing an aftermarket or removing an aftermarket and installing another aftermarket radio?
Mike
Old 12-30-2006, 10:40 PM   #10
dracar
Default Re: Wiring
removing stock and installing aftermarket
help with wiring!!!! dsig18 Ion Tech 16 02-23-2009 09:28 PM
Wiring. brbachma Ion Tech 0 10-15-2007 02:58 PM
Wiring... dracar S-Series Tech 5 06-09-2007 10:30 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
Need some wiring help Campainger Vue General 8 05-29-2003 02:56 AM
