Old 12-23-2006, 11:34 PM   #1
97sleeper
97sleeper is on a distinguished road
97sleeper's Avatar
Attention Need Urgent Help!!!!!! Suspension, Help!!!!!!!
I was trying to install a strut tower brace on my dads 2002 SC2 and I snapped one of the bolts for the strut mount
WILL A STRUT MOUNT FROM A 1997 SL2 FIT IN PLACE OF THE BROKEN 2002 SC2 STRUT MOUNT?????????
The reason I as is cause I can find a strut mount for the 1997 SL2, but not the 2002 SC2.
A good Saturn is a good sleeper -J. Beanan
97 SL2
-N/A sleeper build, check my profile the list
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
Add to 97sleeper's Reputation
Rate the quality of this post and help 97sleeper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97sleeper is offline   Reply With Quote
Old 12-24-2006, 12:19 AM   #2
Default Re: Need Urgent Help!!!!!! Suspension, Help!!!!!!!
http://www.trademotion.com/partlocat...=6&catalogid=1
http://www.trademotion.com/partlocat...02&catalogid=1
http://www.trademotion.com/partlocat....cfm?siteid=24
Apparently not.
Add to ssicarman's Reputation
Old 12-24-2006, 12:21 AM   #3
amazinghl
Yes, will work fine.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
Old 12-24-2006, 12:34 AM   #4
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: Need Urgent Help!!!!!! Suspension, Help!!!!!!!
1991-2002 Saturn S-Series suspension parts are interchangeable. Check your Saturn retailer parts counter to make sure nothing changed.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-24-2006, 02:22 AM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
Yeah, any year S-Series strut mount will work. But the bigger question is, how/why did you snap it in the first place? It only requires 21 lb ft of torque. Thats not very much.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 12-28-2006, 08:04 PM   #6
97sleeper
97sleeper's Avatar
Happy Re: Need Urgent Help!!!!!! Suspension, Help!!!!!!!
Thanks alot, everyone was a big help. I did not know that all it needed was 21 ft./lbs but it was also on the closer side to 15 degrees Fahrenheit making the metal even more fragile. I learned my lesson on last minute barnjobs but I wanted to surprise him for X-mas. I shoul'd have asked you "guys" here at the forum just to make sure that I was doin it right or consulted my mechanics at work but I didn't. Again thanks alot!!!!!!!
97 SL2
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
Urgent question 01SL1SATURN S-Series General 10 11-02-2008 10:57 AM
Urgent problem SC Saturn Owner Ion General 3 07-05-2008 08:11 PM
Anyone have a used valvebody? URGENT alec_b S-Series Tech 6 10-19-2006 08:55 PM
Two recall notices - RDM & suspension, then suspension - Anyone else? John223 Vue General 4 03-09-2005 06:27 PM
Urgent Girafro S-Series Tech 8 12-06-2004 12:43 PM
