Old 12-21-2006, 06:55 PM   #1
mtown
mtown is on a distinguished road
Default 2003 Ion Radiator Replacement
I ran over a raccoon the other day, and it managed to crack my radiator . Since the dealership charges an astronomical amount to replace it, I ordered one online and am going to try to tackle it myself with a couple of friends.
Does anyone know where I can get instructions on how to replace the radiator, or is it pretty straightforward?
oh and, by the way, it's an automatic four cylinder, if that makes any difference.
Add to mtown's Reputation
Rate the quality of this post and help mtown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mtown is offline   Reply With Quote
Old 12-22-2006, 06:40 PM   #2
ottmwz_finest
ottmwz_finest is on a distinguished road
ottmwz_finest's Avatar
2004 ION-2 Sedan
Thumbs Down Re: 2003 Ion Radiator Replacement
that sucks i did the same thing not too long ago...i got RAPED on my repairs though. my estimate was 1,327 for the radiator and the condenser and a crapload of seals and tubing, oh and like 8 hrs labor. sorry i dont know specifics of installation. ugh! good luck i hope for your sake it is just your radiator and not your condenser as well. the racoon i hit i swear was like a freakin bear cub.
hundred miles an hour switching lanes like WHOA
Add to ottmwz_finest's Reputation
Rate the quality of this post and help ottmwz_finest reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ottmwz_finest is offline   Reply With Quote
Old 12-22-2006, 07:46 PM   #3
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Default Re: 2003 Ion Radiator Replacement
It isnt a hard job. Get in there and take a look. It will come to you. Nothing really complicated. Pretty much just remove the bottom holders, disconnect the condenser from the radiator, remove the shroud, and waalaa... You will see what I mean.
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-22-2006, 09:44 PM   #4
SpeedyIon
SpeedyIon is on a distinguished road
SpeedyIon's Avatar
2004 ION-2 Quad Coupe
To Remove:
  1. Drain the cooling system.
  2. Lower the vehicle.
  3. If vehicle is equipped with the 2.2L (L61) engine, remove the air cleaner outlet resonator.
  4. Reposition the radiator inlet hose clamp at the radiator using special tool SA9111E.
  5. Remove the radiator inlet hose from the radiator.
  6. Reposition the radiator outlet hose clamp at the radiator using special tool SA9111E.
  7. Remove the radiator outlet hose from the radiator.
  8. If equipped with an automatic transaxle, clean the upper transmission oil cooler line connection point and remove the line from the radiator.
  9. If equipped with an automatic transaxle, remove the left front wheelhouse liner.
  10. If equipped with an automatic transaxle, remove the left engine splash shield.
  11. If equipped with an automatic transaxle, clean the lower transmission oil cooler line connection point and remove the line from the radiator.
  12. Remove the cooling fan assembly from the radiator by pushing up on the fan shroud to unsnap the retaining features. Position the cooling fan assembly away from the radiator and support the cooling fan assembly.
  13. Remove the air dam push-in retainer.
  14. Remove the air dam.
  15. If equipped with air conditioning, remove the condenser bolts.
  16. Slide the condenser down to disengage the upper mounting tabs from the radiator.
  17. Position the condenser away from the radiator and support the condenser.
  18. Remove the right and left radiator side baffles.
  19. Remove the right engine splash shield to radiator mount push-in retainer.
  20. If equipped with a manual transaxle, remove the left engine splash shield to radiator mount push-in retainer.
  21. Remove the lower radiator mounts, brackets, and bolts.
  22. Tilt the condenser forward in the vehicle. Remove the radiator assembly from the vehicle.
  23. Remove the upper radiator air baffle.
To Install:
  1. Verify that the upper radiator mounts are installed in the vehicle.
  2. Install the upper radiator air baffle.
  3. Tilt the condenser forward in the vehicle. Install the radiator assembly into the vehicle.
  4. Verify that the upper radiator mount pins align with the upper radiator mounts.
  5. Install the lower radiator mounts, brackets, and bolts, and tighten the bolts to 18 ft. lbs. (25 Nm).
  6. Install the right engine splash shield to radiator mount push-in retainer.
  7. If equipped with a manual transaxle, install the left engine splash shield to radiator mount push-in retainer.
  8. If equipped with air conditioning, install the right and left radiator side baffles.
  9. Slide the condenser up to engage the upper mounting tabs into the radiator.
  10. Install the condenser bolts, and tighten the bolts to 89 inch lbs.(10 Nm).
  11. Install the air dam and push-in retainers.
  12. Align the cooling fan shroud retaining features to the radiator. Pull down on the cooling fan assembly to snap the fan shroud onto the radiator.
  13. If equipped with an automatic transaxle, install the lower transmission oil cooler line and seal the radiator. Tighten the transmission oil cooler line to 15 ft. lbs. (20 Nm).
  14. If equipped with an automatic transaxle, install the left engine splash shield.
  15. If equipped with an automatic transaxle, install the left front wheelhouse liner.
  16. Lower the vehicle.
  17. If equipped with an automatic transaxle, install the upper transmission oil cooler line and seal to the radiator. Tighten the transmission oil cooler line to 15 ft. lbs. (20 Nm).
  18. Install the radiator outlet hose to the radiator.
  19. Reposition the hose clamp to secure the hose using special tool SA9111E.
  20. Install the radiator inlet hose to the radiator.
  21. Reposition the hose clamp to secure the hose using special tool SA9111E.
  22. If equipped with 2.2L (L61) engine, install the air cleaner outlet resonator.
  23. Fill the cooling system.
  24. If equipped with an automatic transaxle, add fluid to the transmission as necessary.
2004 Saturn Ion-2 QC
www.ionforums.net - Forum For Saturn Ion Owners
Add to SpeedyIon's Reputation
Rate the quality of this post and help SpeedyIon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpeedyIon is offline   Reply With Quote
Old 12-22-2006, 10:02 PM   #5
SpeedyIon
SpeedyIon's Avatar
Pictures for the steps:
These are pictures for the removal.
Radiator Cooling Fan 2003 Ion Tips and Trics aismvm Ion Tech 3 09-19-2009 07:44 PM
Radiator Replacement on 2003 Vue? grwilli2 Vue Tech 2 12-22-2007 06:09 PM
Ion 2003 side mirror replacement sgb Ion Tech 1 07-07-2007 12:35 PM
2003 Ion Brake shoe replacement NickK3 Ion Tech 1 03-09-2007 12:02 AM
2003 Ion Replacement Parts Cyanne Ion General 6 09-16-2003 10:25 PM
