Old 12-16-2006, 03:25 PM   #1
fatimaknapp
fatimaknapp is on a distinguished road
Mad Problem with engine turning on then turning off, everything is on radio, lights, air
I have a 2003 saturn ion that i have had for almost 2 years it has 54,500 miles on it. I have never had any problems with it before. The other day i smelled gasoline smell when i got into my car late at night after work, it kinda worried me but i thought nothing of it. 2 weeks later i ran some errands with my boyfriend we went to 3 stops keeping the car running (me staying in it) while he ran inside to do what he had to do, we drove 15 miles to my postoffice where we finally turned the car off so we could both go in. We came back to the car and my car's engine would not start everything would be on like air raido lights, ect but the engine would not run. We let it sit 2 mins tried it again engine stared then turned right off. We let it sit 5 more mins tried again and the car started. we drove back home and later that night i tired starting it again and it did. I have not tried it again today. The service vehicle words apperaed in the odometer, when my car would not come on. I so scared to drive it now =( any idea what could be going on? thanks
Add to fatimaknapp's Reputation
Rate the quality of this post and help fatimaknapp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fatimaknapp is offline   Reply With Quote
Old 12-16-2006, 04:57 PM   #2
dlczrx
dlczrx is on a distinguished road
dlczrx's Avatar
Default Re: Problem with engine turning on then turning off, everything is on radio, lights,
[QUOTE=fatimaknapp;961996]I have a 2003 saturn ion that i have had for almost 2 years it has 54,500 miles on it.
Did the car turn over?
If it did not turn over it sounds like the same thing I had going on and turned out to be a faulty ignition switch. There are other threads with sort of the same thing going on as well.
Add to dlczrx's Reputation
Rate the quality of this post and help dlczrx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dlczrx is offline   Reply With Quote
Old 12-18-2006, 10:49 AM   #3
Lynz03coupe
Lynz03coupe is on a distinguished road
Lynz03coupe's Avatar
2003 ION-2 Quad Coupe
Ok this is kinda crazy, but Im sitting at the saturn dealership right now getting my ignition switched replaced and i have to pay for it! Is there anyway to get this covered? Cuz my car has been doing this for months......Maybe a recall or a bulletin?? My factory warrenty is up, but i have an extended one......
03 Ion-QC
Lynz
03 Black Ion QC.....21,000miles
Be Jealous...
Add to Lynz03coupe's Reputation
Rate the quality of this post and help Lynz03coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lynz03coupe is offline   Reply With Quote
Old 12-18-2006, 07:26 PM   #4
harsha
harsha is on a distinguished road
harsha's Avatar
2006
03 Ion-QC
Lynz
SERVICE BULLETIN:040845005 NHTSA ITEM NUMBER:10007431
MFG Bulletin Date: 20060301
Component: ELECTRICAL SYSTEM:IGNITION:SWITCH
Bulletin Summary: NO CRANK, NO START WHEN AMBIENT TEMPERATURES IS COLD - DIAGNOSTIC TROUBLE CODES (DTCS) B2960 AND OR B3033 ARE SET. *TT
http://www.mycarstats.com/safetystat...#SafetyStation
Add to harsha's Reputation
Rate the quality of this post and help harsha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harsha is offline   Reply With Quote
Old 12-19-2006, 01:02 AM   #5
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
It is a bulletin, not a recall.
If you have an extended warranty, it should be covered, unless it is a really cheap/ shotty warranty....
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-20-2006, 02:59 PM   #6
Crawdaddy
Crawdaddy is on a distinguished road
Crawdaddy's Avatar
2005 ION-2 Sedan
2003 VUE 2.2L
the extended warranty I was sold with my ION 2 does not cover ignition cylinders and a few other oddball things...well what do you know, my key got stuck in the ignition one night and I couldn't turn the car off...long story short, they had to replace the ignition cylinder cap or something like that and it was not covered under my extended warranty. Meh, 90 bucks later and a couple hours and it was fixed and I haven't had the problem again so far...
Add to Crawdaddy's Reputation
Rate the quality of this post and help Crawdaddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Crawdaddy is offline   Reply With Quote
Old 12-28-2006, 03:02 PM   #7
gmporter
gmporter is on a distinguished road
Crawdaddy::::
Your Saturn ION is a 2005. How many miles? Did the 36k mile marker pass. This type of repair should be covered under the GM factory warranty. Unless of course they deemed it to be because of maintenance.
Is your extended warranty on your Saturn a GMPP provided by GM?
Add to gmporter's Reputation
Rate the quality of this post and help gmporter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gmporter is offline   Reply With Quote
DRLs/Turning Lights jignha Ion Tech 20 05-28-2010 06:20 PM
Radio not turning off--04 Vue. redkees@msn.com Vue Tech 7 06-17-2008 08:02 PM
radio turning off irondiezl3 S-Series Tech 2 11-18-2007 01:41 PM
Daytime lights not turning on bjthedj S-Series Tech 3 01-13-2006 08:48 PM
Odd engine dying problem while turning?! nps-98SW2 S-Series Tech 14 08-05-2002 08:08 AM
