Old 12-13-2006, 09:39 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Whats an interference and non interference engine?
I was wondering whats an interference engine? And a non interference engine?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 12-13-2006, 09:46 PM   #2
mkuz13
mkuz13 is on a distinguished road
2009 AURA XE
Default Re: Whats an interference and non interference engine?
Interference engines: when the timing chain/belt breaks,the pistons WILL hit the valves and bend them.
Non-interference engines: when the timing chain/belt breaks,the pistons WILL NOT hit the valves and bend them.
Want more gun control? Then use both hands.
Add to mkuz13's Reputation
Rate the quality of this post and help mkuz13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkuz13 is offline   Reply With Quote
Old 12-13-2006, 09:49 PM   #3
10W30
10W30 is on a distinguished road
10W30's Avatar
The difference is replacing your engine when the timingchain/belt breaks.
Add to 10W30's Reputation
Rate the quality of this post and help 10W30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
10W30 is offline   Reply With Quote
Old 12-13-2006, 10:14 PM   #4
Low Saturn
Low Saturn's Avatar
2008 AURA XE
An Interference engine is a type of internal combustion engine where in the event of a serious valve train failure, or a 180 degree timing error, could lead the valves and pistons to strike each other. The most common cause of this a broken timing belt, but a catastrophic timing chain failure can also bring about this situation.
The reason for this is that for an engine to work properly, the actions of the pistons and valves must be precisely harmonized. This is accomplished in three ways. In racing engines, gears may connect the camshaft and crankshaft. In street engines, that task is accomplished by a timing chain or belt. When the chain or belt is installed, the camshaft and crank must be turned so that the number one cylinder is at Top Dead Center, or when it is at the maximum of its stroke. Generally, there are timing marks on the timing gears. or pulleys to aid in this, and the gears themselves are usually keyed to prevent misalignment. However, some people do screw it up.
If the belt or chain breaks, then this relationship is destroyed, and the valves and pistons move independently. In most automobile engines, this does no serious damage. The motor simply stops running until the belt/chain is replaced and the engine retimed. Even when the valves and pistons are at full extension, a small gap remains between them. We call this a non-interference engine. But such designs are not ubiquitous, and designers seeking a small combustion chamber may produce an interference design.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
Old 12-13-2006, 10:52 PM   #5
SonnyD
SonnyD is on a distinguished road
SonnyD's Avatar
1999 SC1
Hmm, how many different ways can we say this?
I like 10W30's answer the Best
Regards Sonny
I LOVE MY SATURN!!!!
99 SC1 "Marvin"
2007 Harley FLHX "Street Glide"
Fender 50's Strat...The Guitar That Put the "Rock" in Rock&Roll
Add to SonnyD's Reputation
Rate the quality of this post and help SonnyD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SonnyD is offline   Reply With Quote
Old 12-14-2006, 12:39 AM   #6
I guess that makes the 2.5L Iron Duke in my friend Kelly's old money-pit Citation a "racing engine" .
Add to madpogue's Reputation
Old 12-14-2006, 07:49 PM   #7
mkuz13
2009 AURA XE
Or my friends old 73 Mercury Capri (2.6L) & my old 78 Mustang II (2.8L) "racing engines".
My friends 73 Capri did run 12.79 in a 1/4 mile so I cant get too sarcastic with this quote
the answers to the topic are in post 2,3,&4
post #2 good explanation
post #3 straight to the point
post #4 detailed explanation
Old 12-14-2006, 08:14 PM   #8
acman
acman has a spectacular aura aboutacman has a spectacular aura aboutacman has a spectacular aura about
1999 SC1
Is the Saturn DOHC engine interference or non?
Add to acman's Reputation
Rate the quality of this post and help acman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acman is offline   Reply With Quote
Old 12-14-2006, 08:17 PM   #9
'98GoldSL1
'98GoldSL1 is on a distinguished road
'98GoldSL1's Avatar
1998 SL1
ALL Saturn S-Series engines from '91 to '02 are interference engines. Both single and twin cam.
Valve crushing goodness!
SL1 256,000kms and counting...
2001 Yellow SC2 comin out soon
Add to '98GoldSL1's Reputation
Rate the quality of this post and help '98GoldSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
'98GoldSL1 is offline   Reply With Quote
Old 12-14-2006, 08:28 PM   #10
turbobuick33
1992 SL2
What engines would be non interference?
92 SL2, 5 speed
91 Lx 5.0
Old 12-14-2006, 08:55 PM   #11
Uzzy
Uzzy's Avatar
2002 SC1
Luckily for me a Chrysler 2.2L engine is non-interferance. At least the 80's version.
Mine skipped a tooth on the timing belt. One year after the guy that did the head gasket told me the timing belt was fine, and didn't need to be replaced at that time, even though the engine was sitting on his bench in pieces when I suggested it. And I drove it for like 5 months out of that year.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 12-14-2006, 09:05 PM   #12
mkuz13
2009 AURA XE
86-01 Ford Escort 1.9L SOHC
Most stock over-head valve V-6 & V-8
Ford 2.3L & 2.5L SOHC
Just a few off of the top of my head
Do you have an spacific engine that you are asking about?
Old 12-15-2006, 12:25 AM   #13
turbobuick33
1992 SL2
I was just curious..thats all
92 SL2, 5 speed
91 Lx 5.0
02 v6 interference engine? doox00 Vue Tech 8 05-03-2009 02:34 PM
INterference sl2clone S-Series Tech 9 02-04-2007 11:25 AM
HONDA 3.5 V6 - Interference Or Non-Interference Valve Design shenb Vue General 20 11-30-2006 06:21 AM
Radio interference luckydamdog S-Series Tech 7 09-05-2006 07:12 AM
1.9L SOHC Interference Engine? TurboTuna L-Series Tech 4 04-13-2005 12:24 PM
