Old 12-12-2006, 03:20 PM   #1
captsam
captsam is on a distinguished road
captsam's Avatar
1997 SW2
Default Timing Belt? Rattle on the Passenger Side.
I recently bought a used 1997 Saturn SW2 with 81K Miles on it. It's a manual transmission. I've noticed a hard rattle on the passenger side of the engine. I already replaced the top axis mount, but the noise has not changed. It only rattles between 1000 and 1100 RPM. Above and below those revs, no noise at all. I haven't replaced the bottom engine mount, (the one just behind the front passenger-side tire).
I've owned a 94 and 92 SL1 in the past, so I'm not too keen on the Twin Cam S Series. Perhaps someone could share their insight.
I've known that Twin Cam Saturns tend to have timing chain problems at roughly 100K to 120K (my impression from reading news forums)... Could this be the problem?
Any advice would be appreciated.
Thanks,
Sam
Add to captsam's Reputation
Rate the quality of this post and help captsam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
captsam is offline   Reply With Quote
Old 12-12-2006, 03:44 PM   #2
Default Re: Timing Belt? Rattle on the Passenger Side.
First, rule out (or in) any "external" cause on that side. Remove the serpentine belt and run the engine for a few seconds. Just rev it up through that RPM band you mention. Of course, if the noise has gone away, the suspect is one of your belt-driven components, or the belt itself.
After you replaced the top mount, did you follow this procedure to remove preload? Doubt it would cause the degree of noise you're hearing, but again, best to rule it out.
Add to madpogue's Reputation
Old 12-12-2006, 04:49 PM   #3
eljefino
eljefino's Avatar
1995 SW1
Does it sound like this?
Add to eljefino's Reputation
Old 12-13-2006, 12:50 AM   #4
captsam
captsam's Avatar
1997 SW2
Nope... I guess it doesn't sound like a bad timing chain. My old 1992 SL1 (still running the original chain) at 185K doesn't even sound like that. Good grief. Thanks for the FLV file though, very enlightening. The sound is a bit subtler, but still vibrates the dash a bit. I did not follow the Strut-bracket-to-cradle nuts procedure. I guess I'll have to jack up the car again. It'll be good anyway, I should have checked the lower mount anyway... this way I'll have a good look at it.
Thanks for all the help so far.
Sam
Old 12-13-2006, 03:15 AM   #5
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
I would suggest removing the belt and seeing if the problem goes away. A lot of times, when water pumps begin to fail, they will make a loud metallic noise, due to play from the shaft.
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-13-2006, 04:49 AM   #6
eljefino
eljefino's Avatar
1995 SW1
I like the idea of a belt-driven acc going out too. As RPM specific as you say it is it could be a resonance thing.
Old 12-13-2006, 07:21 AM   #7
10W30
10W30 is on a distinguished road
10W30's Avatar
Taking off the belt is a good idea to rule out if it's a timing chain noise. Just don't do it too long, you'll overheat the engine.
My best guess is that maybe one of the components that the belt is on. The Crank, Altenator, Water Pump, AC Compressor, Power Steering pulley, and Idler pulley might be loose. If they were loose from a loose/missing bolt.... it would rattle.
First take the belt off and grab each component and wiggle them to see if there is any play.
Then check the power steering bolts behind the pulley ( I think there are 3). A bolt might of worked it's way a little bit and the pulley is hitting the top of the bolt.
Then check all the other bolts holding each component.
Add to 10W30's Reputation
Rate the quality of this post and help 10W30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
10W30 is offline   Reply With Quote
Old 12-13-2006, 12:01 PM   #8
Sky King
Sky King's Avatar
Thanks,
Sam
I agree with the advice already given about trouble shooting your problem. However I think what may give people the impression that these chains start to fail around the 100K mark is that a lot of people will go ahead and change them as a precaution IF they are already doing work that has them in there anyway.
These chains are intended to last the life of the car, HOWEVER most problems arise as a result of not maintaining the proper oil level and doing regular oil changes.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-13-2006, 06:34 PM   #9
captsam
captsam's Avatar
1997 SW2
Thanks for all of the advice so far. I'll have to tinker with the car my next day off. Most of my speculation about the timing chain going out at 100-120K dates back to days when I used to read rec.autos.makers.saturn on USEnet. I'm sure many of you guys used to hang out there (or perhaps still do). I'm starting to think it's more the water pump. I do remember a few years back my old 1994 SL1 had some weird resonating noises before the pump ate it. Anyway, thanks again. I'll keep you posted on my findings.
Sam
Old 12-13-2006, 10:05 PM   #10
DOHC Brown
DOHC Brown is on a distinguished road
DOHC Brown's Avatar
2004 ION-1 Sedan
Originally Posted by eljefino View Post
My used motor has sounded like that for the past 20k miles. What's the deal exactly. If it's not a "problem" i'll just leave it be.
edit: I can plainly see it says timing chain in the video. But I wan't to know why.
Add to DOHC Brown's Reputation
Rate the quality of this post and help DOHC Brown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DOHC Brown is offline   Reply With Quote
Old 12-14-2006, 10:09 AM   #11
eljefino
eljefino's Avatar
1995 SW1
Here's the deal... slack in the chain. Look at the black thing between the two cam sprockets, that is a guide and supposed to be touching the chain. (I tweaked one cam against valve spring pressure to test for slack-- and found it)
After I shot that video and took this picture, I replaced the chain and tensioner (and I think the guides too... I forget... but highly recommend changing everything.)
If your chain sounds this bad, it's flapping around and eating away at metal that holds you motor oil in. If you actually wore a hole it could fail catastrophically. Also if your plastic guide has a crack in it it too could blow up and take a lot of stuff out with it.
Old 12-16-2006, 10:04 PM   #12
DOHC Brown
DOHC Brown's Avatar
2004 ION-1 Sedan
How much to DIY it?
I plan on keeping it at least a few more months, and I really don't need it to fail right now seeing as how I haven't been at my job THAT long..don't wanna be late..EVER.
Old 12-19-2006, 08:40 AM   #13
BarnOwl
BarnOwl's Avatar
The timing chain kit and a cam cover gasket will run you about $200. It'll be good to have a Chilton's or Haynes manual for the pictures of where the colored links on the timing chain go and for the procedures with the crankshaft. This is an interference engine. So, if the timing chain breaks or jumps a link and the engine turns over at all afterwards, you'll at a minimum bend some valves.
I'm sure this will be in the Chilton's or Haynes but, it's important, so I'll highlight it. The procedure is to put the key on the crankshaft at 3:00 o'clock past TDC. This will put the pistons in the center of their travel away from the valves. Leave the crankshaft in this position while you are removing all the parts. When you are ready to install the chain, put the valves at TDC then rotate the crankshaft back to TDC. Following this procedure will save you a bent valve.
The place that most people get stuck is getting the bolt out of the end of the crankshaft. Here's a link to a thread that has a variety of ways to do that.
Add to BarnOwl's Reputation
Old 12-19-2006, 10:52 AM   #14
97coupe
97coupe is on a distinguished road
Hey I like that. Nice touch!
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Old 12-19-2006, 05:51 PM   #15
eljefino
eljefino's Avatar
1995 SW1
Heres another video but this time of how I get the crank pulley off.
Just set up a breaker bar on the pavement under the front bumper and hit the starter a few times.
This job is all swearing and not much thinking. Use the best 6 point 10mm socket you've got and have lots of bandaids and beer for the bloody knuckled aftermath.
It's pretty easy for the cams to find 3 o'clock, take the spark plugs out then the valve spring pressure will force them all to either 3 or 9 o'clock. I counted how many teeth were off from "top" and rotated the bottom to match then rotated through a couple times when I put the chain back on to make sure I got it. You want to make sure the forward side is taut as you test since the tensioner takes up the slack in the rear.
Old 12-21-2006, 12:58 AM   #16
DOHC Brown
DOHC Brown's Avatar
2004 ION-1 Sedan
Thanks for all the input people. I do have a Chiltons manual for the car, so I'll go about reading it on this section to get ready. Already bought the parts from my local stealership. Wish me luck, hehe. I've done all the other repairs myself, i'm sure it will turn out good.
Old 01-08-2007, 10:00 PM   #17
captsam
captsam's Avatar
1997 SW2
Sorry to bring back an old topic, but I finally got around to crawling under the car. I removed the splash guard from the passenger side front wheel. I redid the top engine mount and this time did the Strut-bracket-to-cradle nuts procedure. After doing this, I realized you can do the loosening and tightening of the two nuts without removing the splash guard. All the loosening does is remove pressure from the lower engine mount (I did not realize this).
We sort of strayed from the original topic of the thread... but I did take the belt off and run it... definitely not engine noise. I moved all the parts in the path of the serpentine drive belt. The tensioner was solid (didn't wiggle), but the idler pulley wheel and the wheel of the power steering pump did wiggle slightly. I'm not certain if this is enough to make the noise/vibration I hear/feel between 1000 and 1100 RPM. I'm starting to suspect the power steering pump, as the noise/vibration does go away when the steering wheel is turned while I'm idling at a stop. However, this is not scientific... as the RPMs also drop with the turn of the steering wheel (I'm guessing the power steering pump is changing the RPM). So, it's difficult to me to pinpoint the exact problem. I guess I'll need to get one of those mechanic's stethoscopes.
All advice is welcome.
Thanks,
Sam
Old 01-08-2007, 10:22 PM   #18
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
Forgot who suggested it,but you can use a piece of heater hose. Working man's stethoscope.
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
Old 01-09-2007, 09:22 AM   #19
BarnOwl
BarnOwl's Avatar
I'd replace the bearings on the idler pulley first. I don't have the parts number but, someone will post it. You can get them at NAPA for about $6. It's a lot cheaper and less hassle than messing with the PS.
Old 01-09-2007, 12:14 PM   #20
Luke
Luke's Avatar
Default Rattle on the Passenger Side.
Fm Capt Sam
Simple, isn't it... But, important
Fm Barn Owl
# 6203 ...
Add to Luke's Reputation
Luke is offline   Reply With Quote
Belt side rattle Phredawgy S-Series Tech 27 01-24-2008 08:23 AM
Passenger side rattle when cold john95SW2 Vue Tech 2 01-03-2008 04:49 PM
Front suspension noise/rattle over bumps passenger side Cessna S-Series Tech 1 11-21-2007 02:14 PM
Solution Found:!!!! for Passenger Side Windshield Wind Noise/Rattle dtm1962 Ion General 3 10-04-2005 06:38 AM
L300 Front Passenger Side Rattle AArmstrong L-Series General 7 10-17-2004 05:41 PM
