Old 12-06-2006, 10:44 AM   #1
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default 2000 LS1 Power Window Problem
Have a problem with the window. Goes down fine but is hard to get the window up. Would this just be a switch? If so how hard to replace? Easy DIY
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline   Reply With Quote
Old 12-06-2006, 12:38 PM   #2
ricksLS1
ricksLS1's Avatar
Default Re: 2000 LS1 Power Window Problem
I figured how to get the switch out. If a tech can help me out if this is most likely what needs to be changed. The part is about $27.00. Looks like you can just pry it out but found it easier to pop up around the shift and then push it out
Old 12-06-2006, 01:39 PM   #3
ricksLS1
ricksLS1's Avatar
Should have searched. Either regulator or switch. Guess I'll tey a new switch for $27.
Old 12-07-2006, 12:19 AM   #4
If you are able to get the window up by playing with the switch then it is more than likely the switch. A bad motor would tend to not do anything at all.
Add to ssicarman's Reputation
Old 12-09-2006, 08:38 PM   #5
ricksLS1
ricksLS1's Avatar
Hi SSICARMAN!
Thanks .. I'm waiting for the switch. SHould be in on the 14th. I ordered from Saturnparts.com. If I keep hitting the switch it moves up. I think the wife spilled some coffee on the swiches
Old 01-04-2007, 08:46 PM   #6
ricksLS1
ricksLS1's Avatar
Switch is was. Works fine now. Be careful when you order switches and make sure you get the right color
2000 saturn ls1 transmission problem strumfetica L-Series Tech 4 10-15-2009 10:44 AM
Turn Signal Problem on 2000 LS1 Kenk L-Series Tech 7 03-12-2008 02:34 PM
WTB:2000 LS1 Window switch and regulator nyczbubba Classifieds 0 08-26-2006 01:01 AM
2000 LS2 DS,R Power Window Rolls Down, Not Up striker1211 L-Series General 3 03-08-2006 09:47 AM
Problem with 2000 LS1 A/C on hot days Kurt_97SL2m L-Series Tech 9 09-24-2001 12:32 PM
