Old 12-06-2006, 02:53 AM   #1
xraytec1
xraytec1 is on a distinguished road
xraytec1's Avatar
2006 ION-3 Quad Coupe
Attention cruise control not working
Not sure why may cruise control well not work. This happend a few months ago, but for some reason started working again until now.
Well the orange light works, but when I push the set button nothing happends. Oh I have 06 Ion 3 QC with 19,000 miles on it and tried using on the highway.
Thanks for any help
Add to xraytec1's Reputation
Rate the quality of this post and help xraytec1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xraytec1 is offline   Reply With Quote
Old 12-06-2006, 10:37 AM   #2
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Default Re: cruise control not working
what button are you pressing to "set"? the - or the + button?
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 12-06-2006, 05:23 PM   #3
THX712517
THX712517 is on a distinguished road
THX712517's Avatar
That's what's always caught me with the GM cruise control systems, you gotta push the "-" button to set it, and then you can hti "+". Doesn't seem like it makes sense, you know? But if you've got a 2006, it's under warranty. So, rather than dilly dallying around on here, take the car in and make use of your warranty. That's what you're paying for!
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
Add to THX712517's Reputation
Rate the quality of this post and help THX712517 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
THX712517 is offline   Reply With Quote
Old 12-06-2006, 10:01 PM   #4
Crawdaddy
Crawdaddy is on a distinguished road
Crawdaddy's Avatar
2005 ION-2 Sedan
2003 VUE 2.2L
I had really weird problems with the cruise control. Sometimes it'd just stop working, or not work at all. Turns out, the actual switch board in the steering wheel for the set/resume switch was bad. Dealer replaced it and life is good again. In fact, it's about time for me to get another one... I done wore the switches out...I kind live by cruise
Add to Crawdaddy's Reputation
Rate the quality of this post and help Crawdaddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Crawdaddy is offline   Reply With Quote
Old 12-07-2006, 12:15 AM   #5
xraytec1
xraytec1's Avatar
I plan too. I was just wanted to see if anybody else had or has the same problem.
Old 12-07-2006, 12:17 AM   #6
xraytec1
xraytec1's Avatar
I'm pressing the set button +
Old 12-07-2006, 03:43 AM   #7
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
To set it, you need to press the "-" button, then use the "+" button to raise the speed, or to resume the speed you were at.
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-17-2007, 01:10 PM   #8
strangebrew
strangebrew will become famous soon enough
I just had the same problem. It didn't work on my way to work, then on the way home it worked again...and yes, I know how to set my cruise.
Add to strangebrew's Reputation
Rate the quality of this post and help strangebrew reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strangebrew is offline   Reply With Quote
Old 06-17-2007, 02:55 PM   #9
bigfatdave
bigfatdave is on a distinguished road
bigfatdave's Avatar
2006 ION-2 Quad Coupe
2001 SL2
Mine won't engage if the car has been in the sun all day. The dealership and I are going to be having a talk about it in the next week or two.
Election 08
Leave no non-performing incumbent employed!
If they haven't delivered on their campaign promises yet, do you think they will in yet ANOTHER term?
Add to bigfatdave's Reputation
Rate the quality of this post and help bigfatdave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigfatdave is offline   Reply With Quote
Old 06-18-2007, 11:22 PM   #10
my05ion
my05ion is on a distinguished road
2005 ION-2 Sedan
I have an 05 with a manual trans. I had problems, took it in several times but each time I did it would work for them. There were also no codes.
Turns out there's a linkage on the clutch which disconnects the cruise. It was just barely out of alignment, to where the cruise would work for weeks then not work. And of course because everything (from the computer's perspective) was operating normally there were no codes stored.
Oh, and the orange light on the steering wheel went on like normal.
It took a while to get figured out, but once they adjusted it no problems since.
Add to my05ion's Reputation
Rate the quality of this post and help my05ion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
my05ion is offline   Reply With Quote
Old 05-27-2015, 09:14 AM   #11
w0eaj
w0eaj is on a distinguished road
2002 L-Series 2.2L Wagon
Default Cruise intermittant or inop after shutdown
AhHA. Perhaps that's why my '02 LW-200 sometimes won't reengage the cruise, after I've disengaged it & the car is warm. Makes perfect sense that the clutch-sensor or switch would be the problem - ahhh, back to the garage.
Add to w0eaj's Reputation
Rate the quality of this post and help w0eaj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
w0eaj is offline   Reply With Quote
Old 05-27-2015, 08:21 PM   #12
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
There's no real fix-all for this as there are several switches that can go bad and make it not work - the switch in the steering wheel, the one that makes it disengage when you brake, and, if you have a manual trans, the one that disengages it when you press the clutch. I had 2 different switches go bad (under warranty, thankfully) some years back.
These days mine likes to stop working for awhile, only to come back a month or so later and be fine for months. It may have something to do with the switch getting dirty if it hasn't been used for awhile.
Add to daver's Reputation
Rate the quality of this post and help daver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daver is offline   Reply With Quote
Old 05-28-2015, 09:54 AM   #13
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
make sure you don't have any burnt brake lights also.
also, if you are using LEDs for all brake lights, including the center high ones, then thet will cause it to now work without adding resistors.
as for switches, as previously noted, theres the one on the brakes that controls the brake lights, and also the one on the clutch (if manual) that has to be pressed for the car to start.
if the brakes light up when the pedal is pressed, then that switch is working.
if manual, if you can start your car when flooring the clutch, then that switch would be good also.
the buttons in the steering wheel are simple to replace.
they just pop out, and have one connecter plugged in.
there is a cruise control module in the early ions, but im not sure about the newer ones.
Also, check fuses. there is one for cruise control.
Also, do wipers, headlights, and horn work?
if not, then there is a clock spring inside the steering wheel/column thatll need to be checked and/or changed.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-11-2018, 10:52 PM   #14
HighwayVagabond
HighwayVagabond is on a distinguished road
HighwayVagabond's Avatar
Dizzy Re: cruise control not working
2004 saturn vue 2.2 ltr 4 cyl manual trans cc will not enguage:
2amp fuse is good, passenger side compartment center console
thus far i have probed the steering wheel switches and replaced the right side pos/neg set / resume switch $65.00 toggle
i replaced the 1st switch from the seat because it was about $7.00
both speed input and output sensors are good
neutral safety switch is good
orange light comes on when you turn the pwr button (lft side of steering wheel) on
now, what i found tonight is that i have one more plunger style switch (non adjustable) at the top of the brake pedal arm. As i mentioned from the seat i replace the 1st plunger style part. What is the 2nd plunger part at the top of the brake pedal arm ? That is going to be my next replacement just to try before i go to the shop.
HIGHWAYVAGABOND
Add to HighwayVagabond's Reputation
Rate the quality of this post and help HighwayVagabond reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HighwayVagabond is offline   Reply With Quote
Old 01-19-2018, 04:43 PM   #15
gbfanken
gbfanken is on a distinguished road
I have a 2004 Vue, Automatic, AWD. The cruise control just stopped working. Checked fuse, Good. Yellow light comes on but nothing happens. My heater blower quit working, so I took it in to have a connector that goes to the blower replaced. The original blower cable somehow, 'burned' out! Heater and blower works great here in cold Wisconsin. BUT NOW the cruise control doesn't work!
I don't know 'IF' somehow the cruise control circuit got disconnected? I called the repair shop that fixed the heater blower and asked if they disconnected other cables to repair the blower? They said no.
I am pretty sure the brake lights work only when the brake pedal is pushed, that should make that plunger switch okay?
Any suggestions, short of paying again to get it fixed. I love the Saturn cruise WHEN it works. Thanks. Ken
Add to gbfanken's Reputation
Rate the quality of this post and help gbfanken reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gbfanken is offline   Reply With Quote
Cruise control no longer working SL1Guy S-Series Tech 3 10-01-2009 07:21 PM
Cruise control, A/C not working Scout238 S-Series Tech 8 08-20-2008 10:42 PM
Cruise Control not working gfreek1 S-Series Tech 7 06-29-2007 11:07 AM
Cruise control upgrade - now AC is not working kodok S-Series Tech 7 07-18-2006 08:22 AM
Cruise Control Is Working!!! BarnOwl S-Series Tech 2 11-10-2005 10:43 AM
