Old 12-01-2006, 08:54 AM   #1
solidusjoe
solidusjoe is on a distinguished road
Sad Dashboard Warning Light
Well I've goine through about 60 websites looking for an answer and I am hoping that I'll be able to figure this out here. I have a 1993 Saturn SL1 and when I got the car it didn't come with an owner's manual or anything. I can't seem to get my scanner to work so I'll try to draw it with photoshop:
This light flashes on and off every once in a while but it did like 5 times yesterday so I need to find out what it means. Can anyone tell me?
Add to solidusjoe's Reputation
Rate the quality of this post and help solidusjoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
solidusjoe is offline   Reply With Quote
Old 12-01-2006, 09:04 AM   #2
96GSL1
96GSL1 is on a distinguished road
96GSL1's Avatar
1996 SL1
Default Re: Dashboard Warning Light
Check your coolant level.
96 SL1 202k
98 Windstar 123k
Add to 96GSL1's Reputation
Rate the quality of this post and help 96GSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
96GSL1 is offline   Reply With Quote
Old 12-01-2006, 09:13 AM   #3
S3aturnR
S3aturnR's Avatar
1999 SL1
+1. your coolant's low...
s3aturnr
Add to S3aturnR's Reputation
Old 12-01-2006, 09:23 AM   #4
eljefino
eljefino's Avatar
1995 SW1
That is totally the best drawing of the elusive blinking light I've ever seen.
Most people post, and say, I saw a light, it went away, it was red...
Add to eljefino's Reputation
Old 12-01-2006, 09:34 AM   #5
WingsOfSaturn
WingsOfSaturn's Avatar
It means that your coolant is low. If the coolant level is good, than the sensor built into the bottom of the tank has gummed up. Solution to a gummed sensor is to remove the tank and give it a good cleaning.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 12-01-2006, 10:31 AM   #6
DonP
And if the coolent is low (and it need not be low by much to give the flashing light) the next step is to figure out where it is going.
Add to DonP's Reputation
Old 12-01-2006, 04:58 PM   #7
The next step after that is to visit eBay and get an owner's manual.
Add to madpogue's Reputation
Old 12-01-2006, 05:11 PM   #8
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
If i remember correctly, If both are flashing at the same time, its usually a transmission code. Is it an automatic transmission car? Both were flashing simultaneously in my car, but its a manual...
The first one is Coolant Low. The second one is Coolant Overheat
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 12-01-2006, 05:40 PM   #9
IT'S ONE LIGHT!!!! Always has been. ONE bulb back there.
FLASHING means low coolant LEVEL.
STEADY means a disparity between the ECTS and TTS (automatic only) readings.
Old 12-01-2006, 10:14 PM   #10
DiabloDan
DiabloDan is on a distinguished road
s3aturnr
ohhh...thats the coolant light?..
snap.
I thought It meant I was low on oil.....
arggg...
It keep flashing every other day or so..i keep checking my oil...wow Im retarded...
Add to DiabloDan's Reputation
Rate the quality of this post and help DiabloDan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DiabloDan is offline   Reply With Quote
Old 12-02-2006, 10:11 PM   #11
SaturnManiac
SaturnManiac's Avatar
Exactly. Check your coolant level. Also, if the temperature warning light is coming on, that's not good....that means it's overheating.....maybe because there is low/no coolant. Also, make sure it's a 50/50 mix....50% antifreeze, 50% water.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-02-2006, 11:27 PM   #12
Which part of "IT'S ONE LIGHT" is not clear? Folks, on manual-equipped cars, there is NO temperature warning light. On manual-equipped cars, that ONE light will ONLY come on BLINKING, and ONLY when the coolant LEVEL is low. Now, it's possible that if you're overheating, the coolant is boiling up enough in the reservoir to trip the level sensor, but that's not the same thing.
Isn't this precious? Saturn could have spent probably a dollar more, wiring the TTS/ECTS logic to a separate light, and only on the automatic cars, but no, that's a dollar too much. And that little bit of cheapness has obviously led to endless confusion.
Old 12-03-2006, 12:16 AM   #13
Steven62387
Steven62387 is on a distinguished road
Steven62387's Avatar
Haha yea, it seems like they would have, they probably thought not spending a dollar or so on every car produced would save them something, but in the end there already making money off the cars. But precious indeed lol
Add to Steven62387's Reputation
Rate the quality of this post and help Steven62387 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steven62387 is offline   Reply With Quote
Old 12-03-2006, 12:46 AM   #14
KCW
KCW is on a distinguished road
2004 VUE 2.2L
I would have guessed it means you have music floating around in the bottom of your battery!
Why oh why cant it be like the old days, when dashboards said things like OIL, or CHECK ENGINE
BTW, the '94 manual says:
Blinking: low coolant level
Steady on: engine over temp or automatic transmission overtemp
Add to KCW's Reputation
Rate the quality of this post and help KCW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KCW is offline   Reply With Quote
Old 12-03-2006, 11:06 AM   #15
96GSL1
96GSL1's Avatar
1996 SL1
I would like to add to:
I wish I could draw like that, even on a PC!
96 SL1 202k
98 Windstar 123k
Old 12-03-2006, 11:14 AM   #16
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: Dashboard Warning Light
check your coolant. get a Saturn Owner's Handbook from your Saturn retailer or from www.saturn-publications.com
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-03-2006, 02:26 PM   #17
GreenSC2
GreenSC2 is on a distinguished road
GreenSC2's Avatar
Check/refill your coolant ONLY with it stone cold.
It's not easy being Green(SC2). (IntelliTXT SUCKS)
I refuse to be a Lemming!!
Add to GreenSC2's Reputation
Rate the quality of this post and help GreenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GreenSC2 is offline   Reply With Quote
Old 12-03-2006, 06:52 PM   #18
Well, you can add coolant to a hot engine; it's def'ly better, if you find yourself in the field with low coolant, to add coolant than to drive it when it's low. However, if you do, when subsequently park the car, REMOVE the filler cap, and LEAVE IT OFF until the engine cools. The key is that if the engine cools with the cap on, it creates vacuum within the cooling system; this can cause problems such as the infamous cracked radiator tank.
Old 12-10-2006, 01:31 PM   #19
solidusjoe
Well that was a great response everyone thank you very much for the info.
Is there a specific brand/type of coolant I should use for this particular make/model? I know there is a wide variety and that it's usually best to use the same kind that was already in there. I'm sure that the previous owner(s) used whatever came with the car initially. I was told I should call up a saturn dealer but I figure I might as well ask here first.
Once agauin thanks for the response, I searched forever for that silly light.
Old 12-10-2006, 07:14 PM   #20
eljefino
eljefino's Avatar
1995 SW1
93s take old school green silicated antifreeze. Skip peak if you can, it has phosphates and saturn for whatever reason shuns phosphates. "Turbo Power" made by a company that stamps "recochem" in the bottom of the jugs is good.
If you can't find that stuff, the 5 year "all makes" stuff by prestone or the store brands will do. This runs on OAT technology and has neither silicates nor phosphates.
Cut it 50/50 with clean water if you don't buy premixed... it'll tell you on the bottle. Premixed is probably better if you only need a little bit, so you won't have all this extra chemistry in storage.
Mileage Light on Dashboard is unlit LoganSan S-Series General 6 11-30-2009 09:48 AM
Dashboard -Oil/wrench- warning light-?? cool912 Vue Tech 6 05-19-2008 10:36 PM
Brake Light on dashboard--stays on and goes off... 2NDSOUT S-Series Tech 2 06-25-2007 09:26 AM
The DRL light on the dashboard is out, have a few questions! SaturnSl1owner S-Series General 10 03-26-2007 12:00 AM
Dashboard and Dome Light OllieSC Mods and Performance 3 08-20-2002 06:40 PM
