Old 11-25-2006, 09:45 PM   #1
HeroHog
HeroHog is on a distinguished road
HeroHog's Avatar
2007 ION-3 Quad Coupe
Checkered Flag Car Math. Calculate anything!
If ya ever wanted to caluclate ANYTHING from gearing to Wheel HP, check out SmokeEmUp.com!
Here are some of the calculations you can do on-line there:
Air Flow / Fuel Flow - This calculation will determine the amount of air and fuel flow for a specified RPM. You can use this calculation to determine carburetor sizing if you enter the maximum RPM.
Fuel Injector Sizing - This calculation determines injector size based on max horsepower and number of cylinders
Fuel Injector Sizing 2 - This calculation determines the amount of horsepower an injector will support.
Fuel Injector Flow Pressure Change - This calculation determines the amount of flow a fuel injector will change with a change in fuel pressure.
Intercooler Efficiency - This calculator will determine your intercooler efficiency. You'll need to know the ambient air temperature, Intercooler Inlet Air Temp, and Intercooler Outlet Air Temp. The result will be the efficiency of the intercooler.
Engine Building
Cam Timing Events - This calculation will determine the valve events for a camshaft based on published camshaft duration specifications. Inputs are camshaft duration @ 0.05" lift or advertised duration, lobe separation, and intake centerline.
Calculate Advertised Intake Valve Closing ABDC - This calculation will determine the advertised intake valve closing point needed for calculating dynamic compression ratio, DCR. Sometimes cam companies only publish 0.050" valve timing events. The Intake valve closing event ABDC is crucial in determining DCR for your engine.
Compression Ratio - This calculation will determine your engine's compression ratio. You need to know the bore, stroke, cylinder head volume, deck height, head gasket bore, head gasket thickness, and piston dish volume. The result is a very accurate compression ratio calculation.
Dynamic Compression Ratio - This calculation will determine your engine's dynamic compression ratio. This calculation has all the information from the previous compression calculation but includes cam timing. This will allow you to determine the dynamic compression ratio based on the intake valve timing.
Pressure Ratio - This calculation will determine your engine's pressure ratio. You need to have tested your engine's compression with a compression tester and the barometric test pressure. The result will be the pressure ratio of your engine. This can be compared to the actual compression ratio of your engine.
Compression Tester Gauge Reading - This calculation will determine a "ballpark" reading for your compression tester based on your engine's compression ratio. You need to know the compression ratio of the engine and barometric test pressure and the calculation will return a number your engine should read on a compression tester gauge.
Cylinder Head Volume - Trying to figure out which cylinder head volume will give the right compression ratio for your motor. Use this calculation to determine the chamber volume of a cylinder head by entering your desired compression ratio, bore, stroke, deck height, head gasket bore, head gasket thickness, and piston dish volume.
Piston Volume - Use this calculator to compute the piston dish / dome volume. Enter the the cylinder bore, depth of the piston in the bore, and the measured volume. The result is a very accurate piston volume measurement.
Piston Speed - Use this calculator to compute the average piston speed and the maximum acceleration of the piston. Enter the engine stroke and connecting rod length.
Engine Displacement - This calculation will determine the displacement of your motor in cubic inches and in liters. Just enter the bore, stroke, and number of cylinders.
Effective Compression Ratio - This calculation will determine the effective compression ratio from the static compression ratio and the amount of boost from your supercharger or turbocharger.
Gearing
Rear End Gear Ratio - Not sure what rear end gear ratio you have in your car? Try this calculation and it should give you an idea of your gear ratio in the rear end. You need to know the rpm's of the motor at a certain speed as indicated by your speedometer.
Speed for RPM range - This formula will calculate the speed of the vehicle at a RPM. You enter your tire diameter and your rear end gear ratio and it will display vehicle speed an RPM range from 1000 - 8000 RPM.
Speed for RPM range comparing rear gears - This calculation will display two tables with mph vs rpm range for two different gear ratios. It's handy for comparing different speeds for two different gear ratios. In other words how will changing my stock 2.73 gears to 4.11's effect my cruising speed. Same as Speed for RPM range below except with an additional gear ratio input.
Tire diameter - This formula will calculate the tire diameter from the tread width, series, and wheel diameter. In other words the stamping on the tire, example 275 60R15.
Horsepower
HP from 1/4 mi ET - This formula will calculate HP using the elapsed time (ET) from a 1/4 mi time slip.
HP from 1/4 mi MPH - This formula will calculate HP using the MPH from a 1/4 mi time slip.
HP from 1/8 mi MPH - Don't have a 1/4 mi dragstrip in your area but have 1/8 mi timeslips. Then use this formula to calculate HP using the MPH from a 1/8 mi time slip.
Trap speed & ET from Wheel HP - If you know the weight of your car (with you in it) and know the peak wheel HP as measured by a chassis dyno this calculation will estimate the trap speed in MPH and the Elapsed Time (ET) in the quarter mile.
Wind drag HP - Determine the amount of HP is required to over come the wind drag for a certain speed. All you need to know is the front area and drag coefficient of your car.
Launch G Force - This calculation will tell you how many G's your pulling off the line and your speed at 60'. All you need is a timeslip with a 60' time.
Weather
Calculate Density Altitude 1 - The density of air changes which in turn affects the HP generated by an internal combustion engine. Density altitude is defined as: The altitude in the international standard atmosphere at which the air density would be equal to the actual air density at the place of observation. "Density Altitude" is the pressure altitude adjusted for non-standard temperature. Both increase in temperature and increase in humidity cause a reduction in air density. Thus in hot and humid conditions the density altitude at a particular location may be significantly higher than the geometric altitude.
Calculate Density Altitude 2 - Density altitude calculated from Altimeter setting, temperature, altitude, and dew point.
Correct 1/4 mi. Timeslip to Sea Level - The density of air changes which in turn affects the HP generated by an internal combustion engine. Use this calculator to correct your timeslips based on the density altitude (DA) to sea level.
Correct 1/4 mi. Timeslip to New Density Altitude - Correct a timeslip from one density altitude to another density altitude. Very handy when comparing timeslips.
Correct 1/4 mi. Timeslip with Density Altitude Auto Lookup - To use this calculator enter the date, time, select dragstrip, ET, and trap speed. This calculator will look up the weather information for the date you entered from the closest airport to the dragstrip you select. Based on these weather conditions the calculator will calculate the density altitude and correct the timeslip to sea level.
NHRA Correction Factors - This is not a calculation but a table you can use to correct your timeslips to sea level if you run at a track where the air is thin.
Hero Hog
07 Ion QC 3 2.2L
Add to HeroHog's Reputation
Rate the quality of this post and help HeroHog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HeroHog is offline   Reply With Quote
Old 11-25-2006, 09:59 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Car Math. Calculate anything!
thanks but you forgot this
Paid Subscription Required for all calculators.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-25-2006, 10:02 PM   #3
HeroHog
HeroHog's Avatar
CRUD! I didn't see that. Jussa sec... I know site that IS free... BRB.
Hero Hog
07 Ion QC 3 2.2L
Old 11-25-2006, 10:16 PM   #4
HeroHog
HeroHog's Avatar
Checkered Flag Re: Car Math. Calculate anything!
Here, this should make up for that:
1/4 mile ET = 1/8 mile ET x 1.5832
1/8 mile ET = 1/4 mile ET / 1.5832
1/4 mile ET = ((Weight / HP)^.333) * 5.825
1/4 mile MPH = ((HP / Weight)^.333) * 234
HP = (Weight / ((ET/5.825)^3))
HP = (((MPH / 234)^3) * Weight)
NOTE: pi/4 = 0.7853982
cylinder volume = pi/4 x bore^2 x stroke
stroke = displacement / (pi/4 x bore^2 x number of cylinders)
compression ratio = (CylVolume + ChamberVolume) / ChamberVolume
chamber volume = cylinder volume / compression ratio - 1.0
displacement ratio = cylinder volume / chamber volume
amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
piston speed in fpm = stroke in inches x rpm / 6
rpm = piston speed in fpm x 6 / stroke in inches
horsepower = rpm x torque / 5252
torque = 5252 x horsepower / rpm
theoretical cfm = rpm x displacement / 3456
volumetric efficiency = actual cfm / theoretical cfm x 100
street carb cfm = rpm x displacement / 3456 x 0.85
racing carb cfm = rpm x displacement / 3456 x 1.1
effective ratio = (old tire diameter / new tire diameter) x original ratio
actual mph = (new tire diameter / old tire diameter) x actual mph
drive wheel torque = flywheel torque x first gear x final drive x 0.85
wheel thrust = drive wheel torque / rolling radius
g = wheel thrust / weight
weight transfer = weight x cg height / wheelbase x g
lateral acceleration = 1.227 x raduis / time^2
lateral weight transfer = weight x cg height / wheel track x g
centrufugal force = weight x g
rpm after shift = ratio shift into / ratio shift from x rpm before shift
driveshaft torque = flywheel torque x transmission ratio
actual mph = 3600 / seconds per mile
speedometer error percent = difference between actual and indicated speed / actual speed x 100
indicated distance = odometer reading at finish - odometer reading at start
odometer error percent = difference between actual and indicated distances / actual distance x 100
mph = (rpm x tire diameter) / (gear ratio x 336)
rpm = (mph x gear ratio x 336) / tire daimeter
gear ratio = (rpm x tire diameter) / (mph x 336)
tire diameter = (mph x gear ratio x 336) / rpm
percent of weight on wheels = weight on wheels / overweight x 100
increased weight on wheels = [ distance of cg from wheels / wheelbase x weight ] + weight
center of gravity behind front wheels = rear wheel weights / overall weight x wheelbase
center of gravity off-center to heavy side = track / 2 - [ weight on light side / overall weight ] x track
cg height = [ level wheelbase x raised wheelbase x added weight on scale / distance raised ] x overall weight
Hero Hog
07 Ion QC 3 2.2L
Old 11-26-2006, 07:04 PM   #5
SaturnManiac
SaturnManiac's Avatar
That's nice, but please state what all abbreviations mean.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-26-2006, 08:13 PM   #6
HeroHog
HeroHog's Avatar
ET = Elapsed Time
HP = Horse Power
pi = 3.1416
fpm = feet per minute
rpm = revolutions per minute
cfm = cubic feet per minute
mph = miles per hour
g = the force of gravity
cg = center of gravity
Anything else?
Hero Hog
07 Ion QC 3 2.2L
Old 11-26-2006, 09:52 PM   #7
HeroHog
HeroHog's Avatar
There are some more good stuff at http://www.73-87.com/convers_calcus/equation1.htm and http://www.csgnetwork.com/automotiveconverters.html that are useful.
Hero Hog
07 Ion QC 3 2.2L
Old 04-11-2007, 10:29 PM   #8
RealHippy
RealHippy is on a distinguished road
you forgot crankshaft angles
Add to RealHippy's Reputation
Rate the quality of this post and help RealHippy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RealHippy is offline   Reply With Quote
Old 05-15-2016, 03:16 PM   #9
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
cool!
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 03-23-2017, 04:00 AM   #10
robertpro07
robertpro07 is on a distinguished road
SmokeEmup.com is a really good website to calculate anything. I just checked it and liked.
Instant download of manuals. Check it out at http://fjs66.tradebit.com
Add to robertpro07's Reputation
Rate the quality of this post and help robertpro07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robertpro07 is offline   Reply With Quote
Old 11-26-2017, 07:43 AM   #11
Stapler
Stapler is on a distinguished road
That looks amazing. I don't even care if there's a subscription if it's a decent website like that.
Add to Stapler's Reputation
Rate the quality of this post and help Stapler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Stapler is offline   Reply With Quote
How to Calculate Tire/Wheel Info scsomike How-To Library 2 10-11-2012 04:41 AM
Saturn Math Asterixx S-Series General 37 06-23-2009 07:46 AM
GMs fuzzy math mpg walt General Saturn Discussion 22 05-20-2005 03:17 PM
Need math help! elvinrodr S-Series General 12 09-09-2004 04:33 PM
e-bay SC 2 - check the math out. piney S-Series General 15 06-15-2004 03:36 PM
