Old 11-18-2006, 09:10 PM   #1
jbrink
jbrink is on a distinguished road
Default 96 SL2 Alignment Questions
I have a few questions about my alignment. I recently took my car to a local shop for a front end alignment for $60. The guy told me I need a 4 wheel alignment which is only $10 more. He then tells me that I need some aftermarket camber kits for the rear wheels and he needs to remove my strut to elongate the holes to fix the caster on the driver front wheel. Total bill now is $300. Is this normal stuff or is he trying to take me for a ride? Here are the alignment readings he gave me.
Left Front Right Front
Camber -0.4 -0.5
Caster 2.7 2.5
Toe 0.04 0.07
Left Rear Right Rear
Camber -1.4 -1.2
Toe 0.17 0.25
Any help would be greatly appreciated.
Add to jbrink's Reputation
Rate the quality of this post and help jbrink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jbrink is offline   Reply With Quote
Old 11-18-2006, 09:32 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: 96 SL2 Alignment Questions
he's riding you. $300 is insane. You don't need a camber kit. The holes in the struts can be ground to provide more camber adjustment. more or less caster involves the holes on top of the strut towers so yes they would need to lower the struts to grind the three holes. a 4-wheel alignment normally costs like $89 at a Saturn store. I got a coupon from my Saturn retailer for $59.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-18-2006, 09:55 PM   #3
jbrink
Do you think it's gonna cost more for them to do the grinding and stuff or should that be part of the alignment? I've never had to have any of this done. Normally I just get a front end alignment.
Thanks,
Jbrink
Old 11-18-2006, 09:58 PM   #4
eRic 02sc2
eRic 02sc2's Avatar
with labor it might be $150 tops. always get a 4-wheel alignment on your Saturn since the front and rear are adjustable. 2-wheel (front) alignments are for cars and trucks with solid rear axles.
eRic 02sc2
Old 11-18-2006, 10:09 PM   #5
jbrink
thanks alot, i knew not to just shell out $300 but i wasn't sure where to go from there. i'll be getting that done asap
thank again,
jbrink
Old 11-18-2006, 10:15 PM   #6
amazinghl
Rear camber nubmers are fine.
Just have them set the toes.
But definately a different store, and yes to 4 wheel alignment.
00 Insight 72mpg
Add to amazinghl's Reputation
Alignment issues/ questions YourMainParadox Vue Tech 4 07-21-2009 10:09 PM
Alignment Questions WV6Z Ion Tech 6 06-07-2009 11:41 AM
'92 SL2 wheel alignment EnglishSL2 S-Series General 6 03-04-2005 12:44 PM
front end alignment questions? 1993 S-Series Tech 5 01-04-2005 10:04 PM
Alignment/suspension questions Heartbeat - '95 SL2 Miscellaneous Tech 4 08-01-2001 02:37 AM
