Old 11-06-2006, 08:13 PM   #1
dildog
dildog is on a distinguished road
dildog's Avatar
Default Transmission cooler line replacement?
Well in the sense of whatever can go wrong will go wrong came true on a simple radiator swap on the 1996 SL2. The auto transaxle cooler lines could not be removed from the radiator, no vice grip, heat or just about anything else would free them. So now I have to replace the lines.
It looks like a pain, any hints on the the removal of the old lines and the connection of the new lines to the transmission? I take it the filter will have to be removed, as well as some sensor in close proximity to them. Any other hints to get these lines replaced?
Where to get the lines on-line? Couldn't find them on SaturnParts.
Please help..
Reference thread: http://www.saturnfans.com/forums/showthread.php?t=88335
dildog is offline   Reply With Quote
Old 11-06-2006, 10:02 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: Transmission cooler line replacement?
Part numbers for those two lines are:
Upper line: 21030568
Lower line: 21030707
Just e-mail them at saturnparts.net with the part number and description and they'll get you a price.
Do not throw you old lines away yet, you'll need to remove the plastic quick connects from them an put them on the new lines. Also get the correct tool to install the new lines onto the radiator. You'll need a tool called a flare nut wrench. A regular wrench or vice grips will damage the nut.
Pick up a metric set of these.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 11-06-2006, 10:30 PM   #3
dildog
dildog's Avatar
Thanks.. Can you elaborate more on these quick connects? nothing on the radiator side is going to salvageable. Can the lines be quick disconnected from the transaxle? I could cut the metal part of the line so I could just use a sock on them, at least that would ensure no damage to the transaxle whilst removing them.
Old 11-06-2006, 11:01 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
There are quick disconnects on the transmision side. You pinch the tabs and the line slides off.
Mike
-1991 Turbo SL2.
Old 11-07-2006, 09:18 AM   #5
dildog
dildog's Avatar
WOW! I had no idea. Any reason to replace those quick connects if they don't appear to be leaking? The car is 10 years old w/ 100k miles.
Thanks for posting that image, very helpful!
Old 11-07-2006, 11:07 AM   #6
dildog
dildog's Avatar
Here's the parts I ordered since the car is in pieces I might as well replace all these parts in search of that elusive 33MPG.
1. ECTS (engine coolant temp sensor)
2. AIT (air intake temperature)
3. TTS (transmission temp sensor)
4. upper transaxle cooling line
5. lower transaxle cooling line
6. Saturn Automatic transmission fluid filter
Old 11-07-2006, 01:19 PM   #7
Am I the only one who finds it ironic that they didn't put the quick-dis's on the RADIATOR end of those lines? Given that you're MUCH more likely to have to R&R the radiator than the tranny....
(Or, garsh, they might even have q-d'ed BOTH ends....)
Old 11-07-2006, 01:31 PM   #8
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Yeah I've always wondered the same thing. But then again, with the correct tools, its really not that hard to do. Just remove the radiator with the lines attached, then use a flare nut wrench and remove the lines with the radiator out of the car.
Actually now that I think of it, My 2001 Suburban has quick disconnects on the radiator side too.
Mike
-1991 Turbo SL2.
Old 11-07-2006, 01:41 PM   #9
dildog
dildog's Avatar
After talking to the techs here @ Chevrolet and Saturn it seems it's not uncommon to have to replace the fluid lines after 10 years, many times they just won't budge when removing the radiator. Luckily the new ones are only $11/each and a new QD for the transmission side is only $6. I guess it's not all that bad to replace them, I need to clean up the front of the transmission anyways.
Old 11-07-2006, 02:36 PM   #10
Luke
Luke's Avatar
> Low Saturn <
> Mike <
Are they similar to the "quick disconnects" that is part of the fuel line which is connected to the fuel rail
Luke is offline   Reply With Quote
Old 11-07-2006, 02:46 PM   #11
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Originally Posted by Luke
> Mike <
Exactly.
Mike
-1991 Turbo SL2.
Old 11-07-2006, 11:50 PM   #12
Cars are not built for the ease of future repairs. They are built for the ease, speed and cost of assembly on the factory line. Easy to install threaded in lines to the rad before it hits the factory floor. Not so easy or fast to thread things into the trans on the moving line. Pushing in the line until it clicks in place is easy.
Old 05-17-2012, 02:28 PM   #13
99 SL2
99 SL2 is on a distinguished road
I'm doing a radiator replacement on a 99 SL2 and figure I'll run into this problem. What size flare nut wrench do I need to get the cooler lines off the radiator?
99 SL2 is offline   Reply With Quote
Old 05-17-2012, 09:26 PM   #14
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
I believe that the flare nut wrenches are overrated, and that vise grips are the way to go IF you can "vise" them hard enough (eg, you have strong hands) and if you can get them into whatever space you have available. In the case of the radiator, disconnect hoses at the transmission and deal with the connections at the radiator after you remove the radiator from the car.
Baron5867 is offline   Reply With Quote
Old 05-17-2012, 09:43 PM   #15
off-track
off-track's Avatar
If you read the many old threads (like this one), the cooler lines are notorious for being nearly impossible to remove 99. I'd just play it safe and order two new ones.
Purchased 114k 10/07
Added OEM CC
Old 05-17-2012, 10:03 PM   #16
Baron5867
1994 SC1
Yes, by all means. My reply above was not meant to imply that there is a way to guarantee to remove the cooler lines intact. I always advise having new ones on hand. Assume they will be destroyed when removed.
Old 05-17-2012, 10:25 PM   #17
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Wrench Re: Transmission cooler line replacement?
The size needed is 1/2 inch. I know, nearly all the sizes for things on our Saturns is in the metric system but this is one of the few exceptions.
13mm is close; slightly larger than 1/2 inch - but I'd suggest 1/2 inch instead of 13mm.
As others have pointed out, the nuts for the compression fittings on these automatic transmission cooler lines are extremely difficult to loosen and remove from the radiator without breaking something, and when replacing the radiator it is best to plan on replacing the automatic transmission cooler lines as well rather than reusing them.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
Old 05-17-2012, 10:39 PM   #18
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
The few times I have replaced the radiator on a S-series, I have only had to replace the bottom cooler line. That being said, I would have both on hand just in case. I found OEM (Delphi) cooler lines at Rockauto.com for less than the dealer. About $12 each plus shipping IIRC. I also got an OEM (Delphi) radiator from Rockauto.com for around $80.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
blackeagle1 is offline   Reply With Quote
Old 05-17-2012, 11:00 PM   #19
ddeuces22
ddeuces22 is on a distinguished road
I just had a smiliar problem. The nuts moved fine but the bottom line snapped at the metal part. I just cut the rubber line and purchased a double flared steel line with the right size adapter. Used a grinder to cut the steel line, slid it into the hose and double clamped it. Voila the line was good as new
96 sl2 stage 1 midpenn cams,91/92 header,2.25 ss exhaust, ported and polished head, groundpounder, sda bones, pimped tranny mount, .40 o/s pistons, .25 u/s rods, .25 u/s crank,19mm progress swaybar
ddeuces22 is offline   Reply With Quote
Old 03-02-2014, 10:14 PM   #20
m0topilot
m0topilot is on a distinguished road
Running into this problem and I cannot get the upper cooler line off. With the disconnects, can I just simply disconnect and reconnect the new line? Do I have to mess with the nuts when reconnecting?
Thanks,
Matt
m0topilot is offline   Reply With Quote
Oil cooler line o-rings? pupilot007 L-Series Tech 13 01-29-2009 11:19 PM
Transmission Oil Cooler Line Seal Repair Eazy340 Vue Tech 1 09-10-2008 04:51 PM
Trans cooler line tsbelle1 S-Series Tech 2 08-22-2008 08:58 PM
S-Series Radiator replacement w/ Transmission Cooler Luke S-Series Tech 14 12-22-2006 01:12 PM
oil cooler line in LW's saxman L-Series General 58 12-03-2005 02:37 PM
