View Poll Results: Do you have engine\electrical problems?
yes 5 26.32%
no 12 63.16%
all the time 2 10.53%
some times 2 10.53%
when hot 1 5.26%
when cold 2 10.53%
Multiple Choice Poll. Voters: 19. You may not vote on this poll
Old 11-05-2006, 05:17 PM   #1
dearan
dearan is on a distinguished road
2001 L-Series 2.2L Sedan
Thumbs Down urrggg... 2001 saturn L200
Hi all,
I own a 2001 saturn L200, and have had many problems over the last year;
Had passenger stabelizer like replaced twice,
Pass lock sensor replaced,
O2 sensor replaced,
2 new batteries
brakes twice in less than 2 years
now having electrical problems
wont start when cold, jump started it starts right away
AC not working, Heater core leaks,
heater won't stay on in high speed
at around 80,000 km engine went, due to a bolt not torqued to proper torque, caused the timing chain to break, and many other problems in the engine. was a few days over the warranty, and saturn in toronto said i would have to pay. called GM Customer care, and complained, they called saturn and got them to fix it. the final bill for repair was around 4000 bucks.
when the repairs were done, my car had only 42,000 km on it??? when it went in with like 81,500km. No one had a clue as to what had happened.
Had the same problem in my previous saturn (98 sl1)
My newest problem is now that it doesn't start when the temp drops below 5 degrees celsius. big problem since it is now winter. have to jump start to get it running.
any one have any ideas on how to remedy this?
Saturn said replace the crank position sensor. tried... didn't work
will i buy another saturn???
NO... probably not even another GM vehicle
2 Saturns.... 2 Strikes.... not going to strike out with a 3rd..
Darren McCarthy
Add to dearan's Reputation
Rate the quality of this post and help dearan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dearan is offline   Reply With Quote
Old 11-05-2006, 11:06 PM   #2
silverblueL200
silverblueL200 is on a distinguished road
silverblueL200's Avatar
Default Re: urrggg... 2001 saturn L200
Are you replacing the battery with the same POS Delco battery's?
- 2003 Saab 9-3 Arc
Hello, mother. I come bearing a gift. I'll give you a hint. It's in my diaper and it's not a toaster. -Stewie Griffin
Add to silverblueL200's Reputation
Rate the quality of this post and help silverblueL200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblueL200 is offline   Reply With Quote
Old 11-05-2006, 11:09 PM   #3
GB1
GB1 is on a distinguished road
Originally Posted by dearan
Hi all,
O2 sensor replaced,
2 new batteries
Darren McCarthy
That's a lot of stuff, dearan... I can completely understand your frustration and I think I'd be more upset. I own a 2003 L300 and now have 61K miles and it hasn't had anywhere near that many problems. But I live in a very moderate climate and keep it in a garage. I believe that can really extend the life of a car.
Why two batteries? What happened? Note that Saturn doesnt make the battery, and if it failed within that short of time you should have gotten some rebate. Heater cores can be $ to change. I also have a 92 Isuzu Amigo and it was $1000 to replace it
Tell them if it only has 41K then it is still under warranty and all repairs should have been free
I owned a 1998 SC2 and it ran like a champ btw. When I gave it away with 134,000 miles, it had only had minor repairs. I did replace the O2 sensor on it once when I got a check engine light. My parents now own it and they did have to change the crankshaft position sensor once. That thing is a time bomb waiting to strand someone.
GB
Add to GB1's Reputation
Rate the quality of this post and help GB1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GB1 is offline   Reply With Quote
Old 11-07-2006, 06:17 AM   #4
dearan
no, its an eliminator battery, replaced the second time under battery warranty. it was replaced to rule out that that was the problem.
im not to worried about the heater core, auxilary heater will do for this winter.
2001 Saturn L200 4 cylinder Blower Not Working Varagon L-Series Tech 23 06-25-2016 05:59 PM
2001 Saturn L200 Leo Ladzinske L-Series Tech 0 10-18-2008 02:56 PM
Where is Crankshaft Position Sensor on Saturn 2001 L200 (2.2L)? idlesatire L-Series Tech 4 09-09-2007 12:24 AM
need a user manual for a 2001 Saturn L200 Tippy L-Series General 2 08-15-2006 12:03 AM
Saturn L200 2001 Driverside Window won't roll back up? techwizz78 L-Series General 5 07-07-2006 10:02 AM
