Old 11-05-2006, 01:57 PM   #1
fretese
fretese is on a distinguished road
Roll Eyes Saturn 2002 SL1 - Bad Interior Water LEAK!!
The driver side front & rear carpet get damp as soon as start raining. So far I had been looking around fire wall without luck. It does not seem to be thru the doors. Any ideas highly appreciated. Thanks, Edgar
Add to fretese's Reputation
Rate the quality of this post and help fretese reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fretese is offline   Reply With Quote
Old 11-07-2006, 08:55 PM   #2
fretese
Default Re: Saturn 2002 SL1 - Bad Interior Water LEAK!!
I guess I am the only one with this problem......mmmmmmm
Old 11-07-2006, 09:23 PM   #3
austin71184
austin71184 is on a distinguished road
2000 SL2
I have a 2000 sl2 that leaked really bad when i bought it. After scratching my head for awhile I pulled the headliner down to check the downspouts for the sunroof. I then found out that the hose wasn't even connected. The front passenger carpet would just get soaked after a rain.
If you have a car with a sunroof it woulnd't be a bad idea to take a look at those drains, probably unlikely but in my case.................
Good Luck !!!!!!!
Austin
Add to austin71184's Reputation
Rate the quality of this post and help austin71184 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
austin71184 is offline   Reply With Quote
Old 11-08-2006, 11:29 AM   #4
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
If it has a sunroof, it has clogged/disconnected drainage tubes. Do a search for how to clear them.
If not, try the "Dollar Bill test". Close the front doors on a dollar bill (near the top of the window). If you can then pull the bill out easily, you need to bend the top of the door. Do a search for "Dollar test" for more detailed information.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 11-08-2006, 11:22 PM   #5
fretese
I did the dollar bill probe and it passed with honors......for those who ask, i am sorry to tell you that i do not have sunroof. Still scratching my head.....I will find that leak eventually. It had been raining lately and that probably will help to find. Thanks to everybody......Edgar
Old 11-09-2006, 09:43 AM   #6
RangerRover
1999 SW2
You may need to go extreme - remove the carpet in the car and have someone spray a hose all over the car while you look for where the water is coming in. No carpet makes it easy to spot where water is coming in.
Old 11-09-2006, 02:32 PM   #7
lisaNmike
lisaNmike is on a distinguished road
1997 SC1
Yes...this is a repeat of what I posted to other leaking car but I thought that you might appreciate the humor too!
You are really bumming me out...we could we seal off the dreaded sunroof with tape on my daughter's SC2 and it still could leak?!
Hmm...it's a good thing that Saturn doesn't make boats too otherwise they would all be at the bottom of the sea with all this leaking.
I never knew Saturn was the WATER PLANET.
I just figured out where the names of these cars come from...
SC = Soaked Car
SL = Saturns Leak
Okay, I've finished with my jokes but it's better than crying...we've had enough of leaks!
Add to lisaNmike's Reputation
Rate the quality of this post and help lisaNmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lisaNmike is offline   Reply With Quote
Old 12-21-2011, 10:16 AM   #8
marybeth61
marybeth61 is on a distinguished road
2002
I have the same problem, with my Saturn 2002 Sedan. It's only started happening, about 4 times. The carpet gets wet on the rear driver side first. I've taken it to the mechanic twice, with no luck. My friend took the molding off on the floor near the doors. Still no luck of where it is coming from.
Have you had any luck in finding the problems source?
Add to marybeth61's Reputation
Rate the quality of this post and help marybeth61 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marybeth61 is offline   Reply With Quote
Old 12-21-2011, 09:58 PM   #9
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Sure that's rain water? Check your coolant level. Failed heater core could do that. Inspect all seals then try the "friend with a hose test".
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 12-21-2011, 11:03 PM   #10
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
In that case, should be able to smell it.
Add to Baron5867's Reputation
Rate the quality of this post and help Baron5867 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Baron5867 is offline   Reply With Quote
Old 12-23-2011, 01:30 AM   #11
TwinRevver
TwinRevver is on a distinguished road
it could be the black trim along the roof edge that the door edge seals touch when closed it runs the entire roof line front to back... caulked mine up with hi tech .....
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
2002 SL1 Oil Leak dplemmons S-Series Tech 5 11-05-2009 12:25 PM
Major interior water leak...HELP!!! duanejen Vue Tech 10 11-04-2009 11:49 AM
SL1 FAST water leak - passenger side shibbard1675 S-Series Tech 3 07-31-2008 08:52 AM
Wierd (but bad) water leak. UForgotten S-Series Tech 1 01-07-2007 12:13 AM
Help with BAD tranny leak 1995 saturn SL1 atilla S-Series Tech 10 12-05-2005 04:37 AM
