what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 04-25-2002, 09:38 PM   #1
larrinorth
larrinorth is on a distinguished road
Default Galvanized frame VUE
Thinking of buying a Vue. if they get around to making a VTi. I live in Ottawa, Canada - big time salt and winter climate. Acording to the brochures the frame and steel panels are galvanized. Does anyone know if this is one or two sided galvanizing? Sure an outer galvanizing will keep rust away, at least if it doesn't get scraped off. However serious rust almost always starts from the inside out - thus one sided galvanizing has little advantage. The prudent thing is always to have the cavities sprayed with oil waxes such as Krown but the cost of this adds up over the years. A two sided galvanizing would be great. Who knows for certain? Thanks.
Add to larrinorth's Reputation
Rate the quality of this post and help larrinorth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
larrinorth is offline
Old 04-26-2002, 12:21 PM   #2
Qlara
Qlara's Avatar
Idea
Don't worry much, Saturn's rust warranty is still 5 yrs/100k cover.....besides the VUE is wrapped by Polymer all around with 8" of ground clearance (easier to clear out water).
Add to Qlara's Reputation
Qlara is offline
Old 01-05-2005, 10:41 PM   #3
David Harleyson
David Harleyson is on a distinguished road
David Harleyson's Avatar
Default Re: Galvanized frame VUE
From what I understand, all current GM frames are galvanized on all sides (in and out) and then are dipped in a thick (relatively speaking) waxy coating to further "seal" out water. Body pannels (steel) are two side galvanized EXCEPT the roof. It is galv. on the outside only. This is the way GM trucks are built, I am assuming the Vue is built in a similar fashion.
'05 Vue 3.5 167543 miles
'08 Chevy Silverado LT 1500
'98 Crown Vic PI
'95 HD Sportster 1200
'94 Kawasaki ZX9R
'07 Suzuki GSF1250s
Add to David Harleyson's Reputation
Rate the quality of this post and help David Harleyson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David Harleyson is offline
Old 09-01-2005, 08:18 AM   #4
scotydoc
scotydoc is on a distinguished road
2009 Astra XE
Heart Re: Galvanized frame VUE
The spaceframe is galvanized on all sides. The sheetsteel comes into Body Systems as galvanized sheet stock. After forming and assembly the entier spaceframs is dipped and sprayed in an electronic coating (E-coat). Hand sealing and caulking completes the porcess.
Body Systems Saturn Retired
Add to scotydoc's Reputation
Rate the quality of this post and help scotydoc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scotydoc is offline
frame rot?? xhammerx S-Series General 1 05-08-2005 11:52 PM
SC2 Sub-frame tobes484 S-Series General 6 04-26-2005 08:54 AM
Bent Sub Frame Dipsetct22 S-Series General 8 07-05-2004 08:55 PM
Straightening the Frame diestrutionomeg S-Series Tech 3 10-01-2003 11:29 AM
Frame repair ? bryan_johnson S-Series Tech 7 02-21-2003 10:55 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
