Old 10-24-2006, 10:43 AM   #1
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Default no heat/lack of heat problem
doing a search i came upon this thread, which describes my problem very closely
http://www.saturnfans.com/forums/sho...highlight=heat
i was thinking either restricted heater core or malfunctioning temperature door (which i have yet to check). then i read a post saying the cores dont really get clogged on these cars. anyone have any ideas? im having the exact same symptoms as the poster in that thread.
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 10-24-2006, 12:35 PM   #2
DonP
Default Re: no heat/lack of heat problem
If the engine is heating up, both lines to the heater core are warm, check the doors/controls for operations per he referenced thread, let us know the results.
Add to DonP's Reputation
Old 10-24-2006, 01:02 PM   #3
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
Follow the instructions in that post - Wolfman's instructions are as good as gold and to be taken like gospel .
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 10-24-2006, 04:52 PM   #4
mr18436572
2000 SL2
disconnected the heater hoses under the hood. shot some air in the core pipes and a bunch of gunk came out. so the heater core is out now which was pretty easy job btw. gotta love these cars. thanks for the help
Old 10-24-2006, 11:09 PM   #5
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
try putting water pressure through both inlet and outlet,and you'll see how much more comes out.I did this on one of my cars,and alot of stuff came out,and boy,is it hot now!
Add to sc2dave's Reputation
Rate the quality of this post and help sc2dave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2dave is offline   Reply With Quote
Old 04-16-2015, 08:08 PM   #6
spectrum88
spectrum88 is on a distinguished road
2002 VUE 3.0L
i have a 2002 saturn vue with a 3.0l awd auto. i just did a major tune up on it, i put in the following; water pump, thermostat, valve cover gaskets, timing belt and tentionors spark plugs. my issue is that it over heats with the engine fan running along with blower fan running but its cold. not sure what could be the cause of it. any clues? possabilty of a defect in the heater core. there is no oil in the coolant, nor smoking. not using any coolant at all. checked all fluids they are fine. thanks
Add to spectrum88's Reputation
Rate the quality of this post and help spectrum88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spectrum88 is offline   Reply With Quote
Old 04-16-2015, 09:57 PM   #7
While the topic is about a heating problem, your Vue is a little different from the S-series cars. Vues use more automation controls than the S-series hvac system along with other sensors for the your system. Coupled with a different engine and its set of sensors changes troubleshooting one model from the other. Apples and oranges. You might be better served posting again but in the Vue tech forums.
Old 04-16-2015, 10:01 PM   #8
Mr. Bill
Mr. Bill is on a distinguished road
Did it overheat before the thermostat change? Is it the same temperature thermostat?
Add to Mr. Bill's Reputation
Rate the quality of this post and help Mr. Bill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr. Bill is offline   Reply With Quote
Heat or lack of martin71a S-Series Tech 27 12-06-2009 12:12 PM
No Heat ... Not a problem anymore! mberry S-Series General 2 10-21-2009 12:22 PM
Lack of heat...Thermostat? hd071502 Vue Tech 14 02-24-2008 08:59 AM
Heat problem arunsam3000 S-Series General 7 01-18-2006 09:00 PM
Heat/ AC Problem HeatherIon1 Ion General 18 05-15-2003 08:37 AM
