Old 10-22-2006, 08:13 PM   #1
Yoda
Yoda is on a distinguished road
Default Changing quill bearing, 97 SL2
Has anyone actually changed their own quill bearing on 5 speed? I'm tearing mine down now. Are the special tools required, or is there a work around? How much does the quill bearing run, and is it a dealer item only?
I'm in deep, discovered the leak while replacing the engine. Won't put it back together with a leak there. Got a factory DOHC engine from Saturn.
Add to Yoda's Reputation
Rate the quality of this post and help Yoda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Yoda is offline   Reply With Quote
Old 10-22-2006, 11:13 PM   #2
Default Re: Changing quill bearing, 97 SL2
There are special tools needed to press the quill out and in. If you are inovative enough you could probably make something up to get by. One of the special tools though is a case support to stop the case from cracking while pressing the quill out.
If you are able to get the trans to a Saturn store it may be worth while to see how much they would charge you to do the quill if you brought the trans in loose or even just the front case half and got them to change the quill.
Add to ssicarman's Reputation
Old 10-23-2006, 06:07 AM   #3
BarnOwl
BarnOwl's Avatar
To get to the quill bearing you pretty much have to disassemble the transaxle. There's some good info on that here. While you're at it, you should get the diff pin welded as well.
Add to BarnOwl's Reputation
Old 10-23-2006, 07:27 AM   #4
Yoda
Yeah, I know everything has to come out of the trans before the quill is accessable.
Old 10-23-2006, 07:53 AM   #5
Yoda
I do have a mig welder at work. I'll see what the diff looks like.
Old 10-24-2006, 01:49 PM   #6
Yoda
quill bearing Part # 21120405 ($25)
Bought some pipe fittings to make tools to remove/install ($6)
Old 10-24-2006, 09:44 PM   #7
Greg1
Greg1 is on a distinguished road
Greg1's Avatar
1997 SW2
Could you post a photo of your setup?
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999 SW2 Quill Bearing ... cfg83 S-Series General 26 01-05-2012 09:04 PM
Change quill bearing 97 SL2 Yoda L-Series Tech 0 10-22-2006 08:06 PM
Quill Bearing? bobke1 S-Series Tech 4 02-04-2006 12:30 PM
Could the Quill Bearing burn out the Clutch? Longos S-Series Tech 3 10-14-2005 12:17 PM
What's a Quill Bearing? clemsonsaturn S-Series Tech 14 08-08-2005 10:44 PM
