what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Mods
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 10-21-2006, 06:48 PM   #1
madpowa
madpowa is on a distinguished road
Default speed mods
hi guyz, i'm new here. i got my car for my birthday about 2 months ago and want to make it go faster. i alrady have some mods for it but i'm already acking for more speed. if you have any ideas for me. also i want a cool body kit or something. mabye like some altezza tail likghts?
93 SL1
Glasspack, Underseat neons, Durabrand sub and amp, rear reflector, APC shifter knob and pedal covers
Add to madpowa's Reputation
Rate the quality of this post and help madpowa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
madpowa is offline   Reply With Quote
Old 10-21-2006, 07:14 PM   #2
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
1991 SL
Default Re: speed mods
yup well 93 sohc is slow thats for sure... twin cam swap is ur best bet. auto or manual? manual is quite a bit faster. the engine being tbi insted of fi means that u cant even get an air intake for it.
there are body kits out there
no tail lights tho
mods i still need to do:
struts that can handle H&R race springs
rear sway bar
stiffer fstb (maybe)
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 10-21-2006, 07:39 PM   #3
S3aturnR
S3aturnR will become famous soon enough
S3aturnR's Avatar
1999 SL1
that car will never be fast. best mod would be a for sale sign. don't mean to hurt your feelings, but the truth sometimes hurts. plus, if you add a body kit, it will go even slower. how about a giant wing???
s3aturnr
Add to S3aturnR's Reputation
Old 10-21-2006, 08:18 PM   #4
quiksc2
quiksc2 is on a distinguished road
quiksc2's Avatar
Just keep it as a daily driver. Save up for the DOHC engine swap. Go from there.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 10-21-2006, 08:19 PM   #5
quiksc2
quiksc2's Avatar
Just keep it as a daily driver. Save up for the DOHC engine swap. Go from there. Unfortunately, the SOHC is not mod-friendly.
DCS
Old 10-21-2006, 08:44 PM   #6
madpowa
i have an auto right now in my car. i think it's ok because i can get a pretty fast start if i rev it in N and then pop it in to D. I have won against some of my friends with cavaliers and neons and things. what do you mean swap to DOHC? I can't get more than 1 car. and how much would a wing help with traction? I have heard different things from people about that but I did see them at checker for pretty cheap
93 SL1
Old 10-22-2006, 05:25 PM   #7
S3aturnR
S3aturnR's Avatar
1999 SL1
i was kidding about the wing. anything you add to that car to make it look cool will inevitably make it slower. a wing won't help with traction at the speeds that car is capable of. keep up on regular maintenance and use it as a daily driver. and STOP with the neutral slams!
s3aturnr
Old 10-22-2006, 06:10 PM   #8
eRic 02sc2
eRic 02sc2 will become famous soon enougheRic 02sc2 will become famous soon enough
eRic 02sc2's Avatar
Location: Professional Driver on a Closed Course: Do Not Attempt.
don't bother with an engine swap. swap the SL1-a for an SL2-m. it's easier and less expensive and less of a hassle.
keep doing the neutral slams and put the SL1 out of it's misery sooner.
eRic 02sc2 fka eRic 96sc2
Detroit SCCA Solo 2001,2002 1st DSP
Waterford Hills 2007 Fun Run 1st
Detroit SCCA 2008 Triathalon 1st PF
Detroit SCCA Solo 2009 2nd ST
Old 10-22-2006, 06:38 PM   #9
SL2sleeper
SL2sleeper is on a distinguished road
SL2sleeper's Avatar
This is the very worst thing you can do to your transmission!!!
Doing a neutral drop forces the transmission to work over time!! The clutch packs inside will eventually give/burn out and your trans will be shot. This is to say if your Diff pin retainer does not fail first allowing the Diff pin to bust through the transmission housing. So stop doing neutral drops just to beat your friends!! This is of course unless you want a bill of around $1300 to replace the transmission. Then I say go right ahead and keep on doing it but I don’t recommend it nor does any other member here. Saturn’s do not like wheel spin unless you prepare them for it first. There are two ways one is better than the other IMO.
Watch this trans blow up.
http://videos.streetfire.net/categor...64770f1045.htm
read this here.
http://www.saturnfans.com/forums/sho...=diff+pin+fail
Here is one thread about the DOHC swap after I used the "search" feature in the forum.
http://www.saturnfans.com/forums/sho...ight=dohc+swap
ER OUT
No traction control but no need it is a 5 speed
In the end ride quality means nothing performance is everything!
Add to SL2sleeper's Reputation
Rate the quality of this post and help SL2sleeper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2sleeper is offline   Reply With Quote
Old 10-22-2006, 07:20 PM   #10
amazinghl
amazinghl is on a distinguished road
amazinghl's Avatar
Your car will not last 2 months if you continue to treat it this way.
85 GLH
89 Daytona Shelby
93 SL2
94 855
Add to amazinghl's Reputation
Old 10-22-2006, 07:26 PM   #11
madpowa
ok well thnx for helpin me out. i don't want to switch to doch because that sounds like a lot of work. 1300 sounds liek a lot for a new transmision. I can't realy buy a new car, bc i don't have that much cash. so what else can I do that would add speed to my car. nos mabye? i don't know much about nos what are my options there?
93 SL1
Old 10-22-2006, 07:50 PM   #12
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
i dont mean to get you down, but in a year's time, you'll re-read this post and wonder what you were thinking. The only thing you can do is sell the car and buy another cheap saturn. Clean the car up really nice, and place a for sale sign on it for $1500. Then, look for another car to buy, hopefully one with a DOHC. The 86hp SOHC engines are not worth it, so why bother?
The only way to get your car faster is to go turbo, which will entitle way more money and time than an engine swap. For now, strip down the interior for weight reduction, get 1994-1995 Saturn Sawtooth alloy wheels (they're the lightest) and keep up with the maintenance.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 10-22-2006, 08:30 PM   #13
xupthree60
xupthree60's Avatar
1991 SL
i swear to god this one has to be someone messing with us
(i cant seem to find the smiley where the smiley shoots itself in the head)
rear sway bar
Old 10-22-2006, 08:35 PM   #14
spencerforhire
spencerforhire is on a distinguished road
spencerforhire's Avatar
1996 SC1
I think this "madpowa" is someone yanking our collective chains! He's pushed all the "hot" buttons- looking for mods for an early automatic SL1, and talk of neon and wings- I don't buy it.
I now have 10 Saturns, am I nuts or what??
95 SL1(parked)
96 SC1(son's)
00 SW2(wife's)
96 SW2(daughter's)
95 SW2(parts)
94 SL2 "
95 SW1 "
96 SL2 "
98 SL2 "
97 SW2(for me!)
Add to spencerforhire's Reputation
Rate the quality of this post and help spencerforhire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerforhire is offline   Reply With Quote
Old 10-22-2006, 11:16 PM   #15
madpowa
no i just want to show my friends that my saturn isnt just a chic car. i was hoping you guys could tell me some ways to help me show off that saturns can go fast. and when did i talk about neons?
93 SL1
Old 10-22-2006, 11:59 PM   #16
amazinghl
amazinghl's Avatar
You don't need to prove anything.
Just drive the car normally or else very soon, you WILL have a broken car.
FAST, CHEAP, RELIABLE.
You can pick two.
85 GLH
89 Daytona Shelby
93 SL2
94 855
Old 10-23-2006, 12:16 AM   #17
quiksc2
quiksc2's Avatar
Unfortunately, your saturn is a chic car. It doesn't go fast. It is a mild-mannered economy car. Make it look nice, sell it, and buy a DOHC with a manual transmission. You might break even, considering autos go for more than manuals. Trust me on this. If you don't believe me, go down to the local dealership. Test drive a close year car with the manual and the DOHC. You will know what we are talking about.
DCS
Old 10-23-2006, 12:30 AM   #18
xupthree60
xupthree60's Avatar
1991 SL
Ban ?
rear sway bar
Old 10-23-2006, 01:00 AM   #19
bigfatdave
bigfatdave is on a distinguished road
bigfatdave's Avatar
2006 ION-2 Quad Coupe
2001 SL2
Thumbs Up Re: speed mods
s3aturnr
Just had to agree. Stop watching F&F, you can't do that stuff in that car.
Happy birthday, now stop abusing your gift
Election 08
Leave no non-performing incumbent employed!
If they haven't delivered on their campaign promises yet, do you think they will in yet ANOTHER term?
Add to bigfatdave's Reputation
Rate the quality of this post and help bigfatdave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigfatdave is offline   Reply With Quote
Old 10-23-2006, 06:55 AM   #20
spencerforhire
1996 SC1
UNDERSEAT neon, not Dodge Neons... If your car is neither "Fast" nor "Furious", putting lights under the seats will not make it so. By the way I still don't buy it....
95 SL1(parked)
96 SC1(son's)
00 SW2(wife's)
96 SW2(daughter's)
95 SW2(parts)
94 SL2 "
95 SW1 "
96 SL2 "
98 SL2 "
97 SW2(for me!)
More Six-Speed Automatics Coming as GM Announces Plan to Close 4-Speed Transmission P Charlie General Saturn Discussion 1 05-13-2008 08:49 AM
Any reason to upgrade to the 2.4 w\6 speed over the current 4 speed? Aratech Aura General 5 05-10-2008 04:15 PM
'01 Speed Chip and Speed Boost? (from eBay) Disturbed_One S-Series Mods 46 02-23-2008 12:11 PM
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? 2k3L300HID L-Series General 64 03-10-2005 10:53 PM
Speed and mods? DD_Drummer44 S-Series General 6 08-25-2004 08:23 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
