Old 10-14-2006, 04:06 PM   #1
dmc
dmc is on a distinguished road
2000 SL2
Default How to replace tail lights on S-series
This how-to covers replacement of brake lights, rear turn signals, and reverse lights on the S-series. I did this on a 3rd gen SL2, but the instructions are probably applicable to most models and years.
You will need the following:
* A T-15 Torx screwdriver
This is a quick operation. I was able to do it in five minutes in a parking lot.
First, find out which light(s) are burned out. The easiest way is to have a helper hit the brakes/turn signal/reverse while you stand behind the car. If you can't find a helper, you can just park so your car's rear-end faces the side of a shiny car, and you should be able to see which lights are coming on in the rear view mirror.
Next, go to the auto parts store and get the proper bulbs. I used Sylvania Long Life bulbs. Don't bother with OEM bulbs, they're needlessly expensive. You can also pick up special grease to coat the bulb socket if you like (it's sold in a little packet at the counter of most auto parts stores).
Pop your trunk, and you'll see two Torx screws on the side of the tail light assembly. Use your T-15 screwdriver on these.
The tail light assembly should easily slide out at this point. You'll see four connectors: a wiring harness, reverse light, turn signal, and brake light. Disconnect the proper connector, and you'll see the burned-out bulb. Give it a yank, and it will pop right out.
Coat the new bulb's base with dielectric grease (optional), and insert the new bulb. It will go in with a satisfying snap.
Slide the tail light assembly into the body of the car, and screw the two Torx screws back in.
You probably got a 2-pack of bulbs, so go ahead and replace the same bulb on the other side of the car! It will most likely burn out soon anyway.
Add to dmc's Reputation
Rate the quality of this post and help dmc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmc is offline   Reply With Quote
Old 10-15-2006, 05:40 AM   #2
Tiger
Tiger is on a distinguished road
Tiger's Avatar
Default Re: How to replace tail lights on S-series
You just reminded me of something on my "To Do" list. One bulb was replaced when I bought new tires. Years ago I was pulled over when a bulb had burned out on my Sentra brake lights. Just to hard to monitor unless you have a helper.
Add to Tiger's Reputation
Old 10-15-2006, 10:17 AM   #3
eRic 02sc2
eRic 02sc2's Avatar
I use a SKY umbrella that I got from the Detroit Auto Show to press the brake pedal while I'm in back of my Saturn checking the bulbs. wedge it between the drivers seat and the door sill. lamp bulb replacement instructions are in the Saturn Owner's Handbook.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 10-17-2006, 05:22 PM   #4
David 93 SL2m
David 93 SL2m will become famous soon enoughDavid 93 SL2m will become famous soon enough
David 93 SL2m's Avatar
1993 SL2
2004 VUE 2.2L
Happy Re: How to replace tail lights on S-series
Typically we turn a vehicle's bulb connector 1/6 of a turn to remove and reinstall it. Sometimes we have to press a tab while turning it for removal. Also sometimes the connectors are "keyed" meaning the notches are not equally sized and not equally spaced, so look at the connector before reinstalling so you don't force it and perhaps break something along the way.
Some bulbs slide in and out, others need to be turned slightly before pulling out or pushing in. Again, some bulbs are "keyed" and not completely symmetrical, so look at the base of the bulb before reinstalling so you don't force it...
Dielectric grease is a good idea. It helps to seal out moisture and prevent rust, it helps dissipate heat, and it helps the bulbs come out easily the next time they need to be replaced.
As of 28 Apr 2013
∙ 1993 silver/gray SL2 5-speed, 203,190 miles
∙ 1996 medium-blue SC2 auto, 117,318 miles
∙ 2001 red SC2 auto, 140,138 miles
∙ 2004 silver VUE 5-speed, 88,272 miles
David 93 SL2m is offline   Reply With Quote
Old 01-10-2010, 11:24 AM   #5
Radar011
Radar011 is on a distinguished road
I opened my trunk and I cannot locate the two Torx screws on the side of the tail light assembly.
Add to Radar011's Reputation
Rate the quality of this post and help Radar011 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Radar011 is offline   Reply With Quote
Old 01-10-2010, 11:26 AM   #6
Radar011
I opened my trunk and I could not locate the Torx screws that are on the side of the tail light assembly. Are they hidden behind any type of covering?
Old 01-10-2010, 09:52 PM   #7
Tiger
Tiger's Avatar
No, not hidden. Just had to replace my brake light bulb for the 4th time. Mine torx screws are black in color, so you may need good light to see them. They are pretty flush, so they do not stick out a lot. They are on the edge of the assemble that faces the trunk. Once removed the assembly pivots out. Just make sure to hook in back in/line it up so it is secure. I did not do that all the time.
I ordered some LED bulbs on Ebay since mine keep going out. I believe the key is the grease they talked about. Put some on the bottom of the bulb. I believe that has been one of my problems. Too much heat. Once reason I am going to LED bulbs. Could be other problems though (hope not).
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 5 05-08-2009 12:51 PM
HELP HELP HELP!!!! NO TAIL LIGHTS OR DASH LIGHTS..... PROBATION IN three HOURS!!! RBrown20 S-Series Tech 15 02-04-2009 03:04 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 02:08 PM
S-series 2nd gen tail lights CKyAlliance07 S-Series General 11 09-27-2006 08:42 PM
2003 Ion Tail Lights & Cluster Lights Out ticklescat Ion General 3 12-31-2005 04:13 PM
