Old 10-11-2006, 08:46 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default What would cause my car to have no heat?
On my 92 SL2 when the car is running at normal operating temp, I turn on the heat and the temperature selector is all the way to the right in the red..It just blows out cold no heat at all..What would cause my car not to have any heat?? I know a heater core and thermostat could be the cause but what else?
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 10-11-2006, 08:51 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: What would cause my car to have no heat?
If a flapper door in the heater core box isn't letting air through, that's bad news. If you have AC there are many more flappers and confusion and tightness in there. As you move the selector lever do you hear thumping?
The thermostat is probably fine as long as you run a steady middle operating temp.
Add to eljefino's Reputation
Old 10-11-2006, 08:55 PM   #3
mkuz13
mkuz13 is on a distinguished road
2009 AURA XE
Temperature cable come disconnected from HVAC controls or HVAC blend door cable
Blend door broken inside heater case
Want more gun control? Then use both hands.
Add to mkuz13's Reputation
Rate the quality of this post and help mkuz13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkuz13 is offline   Reply With Quote
Old 10-11-2006, 08:59 PM   #4
harsha
harsha is on a distinguished road
harsha's Avatar
2006
If worse comes to worse, possible water pump failure??? Do you have any cooling system problems??
Add to harsha's Reputation
Rate the quality of this post and help harsha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harsha is offline   Reply With Quote
Old 10-11-2006, 09:06 PM   #5
mkuz13
2009 AURA XE
If you want to eliminate the heater core as the problem do this:
Warm up your car to normal temp
Find the hoses going to your heater core and touch them with your hand but dont keep your hand on them too long
Both hoses should be hot
If one hose is cold or semi-warm,then your heater core is plugged
no heat/lack of heat problem mr18436572 S-Series Tech 7 04-16-2015 10:01 PM
Heat shield between exhaust pipe and car is making a lot of noise - Suggestions? 2002SaturnMan S-Series Tech 8 03-01-2013 12:24 PM
Changed thermostat twice-car doesn't get heat Driver23 S-Series Tech 4 12-18-2008 04:55 PM
No Heat fycoif S-Series General 4 01-21-2008 09:34 AM
Heat DHOOP S-Series Tech 3 11-06-2004 11:54 AM
