Old 10-05-2006, 03:02 PM   #1
1994Saturn
1994Saturn's Avatar
1994 SL1
Attention Help! Cant remove brake line!
Hi, well i have having trouble removing the brake line at the right front wheel. Any one know how it do it? Thank you. Here is some pictures. Circled in red is what i need to remove.
Thank you all!!
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-05-2006, 03:13 PM   #2
WingsOfSaturn
WingsOfSaturn's Avatar
Default Re: Help! Cant remove brake line!
Try soaking it with some PB Blaster for a day or so. Then put on a good pair of vise grips since it is already bad. I think you could also take that bracket off and put it all in a vise for more leverage.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 10-05-2006, 03:44 PM   #3
eljefino
eljefino's Avatar
1995 SW1
Now that you have the brake line off you can get a nice deep 6 point socket on there. Don't be suprised if it's SAE and not metric, brake parts are funny that way. You'll want to back that bracket up with the vise grips as it'll flex hard-core when you put serious torque on the nut. Romzek is right about the pb blaster too.
Don't be suprised if you need a new rubber hose and bracket too, it is frustrating but sometimes for the best to go all-new.
Add to eljefino's Reputation
Old 10-05-2006, 04:10 PM   #4
First, PB Blaster is your friend. Act like you own stock in the stuff.
Since you've cut the line, your best hope is a SIX-POINT socket of the appropriate size. You might even wanna cut off more of the line, so you can fit a standard depth (rather than deep-well) socket on there.
Heat might help, too.
Add to madpogue's Reputation
Old 10-05-2006, 04:34 PM   #5
DanB98TJ
DanB98TJ is on a distinguished road
1997 SW1
If the socket doesn't work, and that is your best shot, you're going to need to use vice grips. You'll need to clamp them on what is left of the nut VERY TIGHTLY before you try to turn it!
Are you replacing the hard line or are you going to try to reflare the end (looks to me to be the hard line that runs from the master cylinder to the flex line that is cut/broken)?
1997 Saturn SW1, auto trans, 121k miles
Add to DanB98TJ's Reputation
Rate the quality of this post and help DanB98TJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DanB98TJ is offline   Reply With Quote
Old 10-05-2006, 04:36 PM   #6
dcp
dcp is on a distinguished road
dcp's Avatar
Heat will do wonders.A pair of vicegrips with pb blaster like madpogue said
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 10-05-2006, 06:38 PM   #7
1994Saturn
1994Saturn's Avatar
1994 SL1
Hi Guys!, Thank you for your help.. I did get it off. Now i have a new brake line. Thanks again!
Current:
Past:
94 SL1 Sold @134K.
Old 10-08-2006, 12:30 AM   #8
Psywar
Psywar is on a distinguished road
1999 SW2
quick question related to this post.
I see how he cut the brake line, is their a way to add new brake line with out replacing the whole thing?
just courious!
Thanks
Add to Psywar's Reputation
Rate the quality of this post and help Psywar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Psywar is offline   Reply With Quote
Old 10-08-2006, 01:23 AM   #9
amazinghl
New metal line or rubber line?
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
Old 10-08-2006, 07:52 AM   #10
eljefino
eljefino's Avatar
1995 SW1
you can splice metal brake line if you get a double flare tool. Little doodad that you put the nut on first (as it won't go on later) then make the end of the line bulge and then you can put a joiner on.
New line is so silly cheap though unless you're splicing onto something that you know is much better than what you're replacing you might as well go all new from the master cylinder on down.
Old 10-08-2006, 09:41 AM   #11
Psywar
1999 SW2
How long, and how complicated/hard do you think it would be to replace all the brake lines to the SS Brake Hose?
Not an issue I have to deal with right now, but living in Michigan, I know Its going to happen eventually.
Thanks
Old 10-08-2006, 10:48 AM   #12
dp97sc2
dp97sc2 is on a distinguished road
ditto what the last poster said....How costly and difficult are stainless steel brake lines?
Add to dp97sc2's Reputation
Rate the quality of this post and help dp97sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dp97sc2 is offline   Reply With Quote
Old 10-08-2006, 01:44 PM   #13
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
the rear ones were easy. the metal line nuts came off easily. The front ones were a headache though.. same thing happened with me (nut wouldnt budge and line broke).
its simply bolt off bolt on and bleed the brakes.. its just getting the front two lines off that is a pain.
1996 SC1
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline   Reply With Quote
97 SL1 SOHC - Brake Booster Hose - How to Remove? SaturnStick S-Series Tech 2 05-24-2009 08:42 PM
easy way to remove carpet while replacing parking brake cable? microsat S-Series General 9 03-13-2009 03:24 PM
How do you remove Brake Drum? jackl S-Series Tech 9 06-04-2007 09:59 AM
cannot remove brake light bulb MN97SL2 S-Series General 5 11-26-2006 08:13 PM
What is the best way to flush out and remove the old brake fluid? turbobuick33 S-Series General 15 11-02-2005 10:48 PM
