Old 10-02-2006, 12:19 AM   #1
shagdrum
shagdrum is on a distinguished road
Default Dome Light Fuse
I have a 1995 SL2 and the dome light is out. I replaced the bulb but it is still out. I need to know what fuses to check (in the cab and/or underhood) for this. I don't have a owners manuel so I don't have a diagram of the fuses. Any help would be appriciated. Thanks.
shagdrum is offline   Reply With Quote
Old 10-02-2006, 02:04 AM   #2
Default Re: Dome Light Fuse
There are diagrams of the fuses on the insides of the panels that cover each of the fuse boxes. It's most likely a fuse in the instrument panel box (IPJB); if it were an under-hood fuse, most likely more things would be out. Owner's manuals are readily available for very cheap on eBay.
Welcome. Replace your ECTS. CHECK YOUR DAMN OIL! (Our standard "welcome message".)
Old 10-02-2006, 11:48 AM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Does your trunk light and/or rear defroster still work?
-Check the body fuse on the interior fuse box. Kinda in the middle towards the bottom if I remember correctly.
-Or it could be the chime module.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 10-02-2006, 04:25 PM   #4
I broke the housing for the dome light when I replaced the sunroof and I didn't feel like making it work (It came on before I broke the housing). Would the light not being connected stop the defroster from working?
The chime works (goes nuts on me when I leave the lights on and open the door with the car off) and the trunk light has not worked since I owned the car.
2007 Dome Light (Switched Power Fuse) da_beaver Ion Tech 1 07-24-2009 12:35 AM
dome light bone86daddy S-Series General 12 10-12-2008 09:35 PM
Dome Light Fuse HCSaturnGuy2 Ion Mods 1 05-06-2008 12:18 AM
Dome light fuse HCSaturnGuy2 Ion Tech 0 05-04-2008 04:45 PM
Dome/Rear Interior Lamps. Where is fuse? Kaylas Miscellaneous Tech 3 04-06-2003 10:07 PM
