Old 09-28-2006, 07:55 AM   #1
hattrick11
hattrick11 is on a distinguished road
2001 L-Series 2.2L Sedan
Default 2001 L200 Will not start sometimes
Ok, here is the problem. Every once in a while, like maybe every 2 months or so, I go to start my car and it will not start. I have read from others that have had this problem, but have not found a solution. What happens is that I turn the key and the engine will turn, but it will just not start. Now, I have had the battery checked and it was fine. If it only happened every once in a while I could deal with it, but it has now happened twice in the last 2 weeks. Normally when this occurs I can get a jump, and the car will turn over, immediately after I turn the key. Last week I could not find anyone to jump me right away, so after 10 minutes I tried it again and it started with no problems. Any ideas? It seems lie a battery issue, but it was odd that it started after 10 minutes last week without getting jumped. Also, when the car does not start, itís not like the battery sounds worn down or anything. It will let me crank and crank. Thank you for any help you might be able to give me.
Add to hattrick11's Reputation
Rate the quality of this post and help hattrick11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hattrick11 is offline   Reply With Quote
Old 09-28-2006, 12:00 PM   #2
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Re: 2001 L200 Will not start sometimes
Do a search on "passlock."
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 10-07-2006, 05:17 PM   #3
Chriscnl
Chriscnl is on a distinguished road
Chriscnl's Avatar
either the passlock is on or the Crank sensor is no good.
Add to Chriscnl's Reputation
Rate the quality of this post and help Chriscnl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chriscnl is offline   Reply With Quote
2001 L200 won't start Cerberus L-Series Tech 10 08-14-2010 11:12 PM
2001 L200 4CY Intermittent Start Problem hmuller L-Series Tech 5 06-22-2008 01:57 PM
Grinding noise on start after 2 days [2001 L200] taosd L-Series Tech 8 01-28-2007 07:00 PM
2001 L200 RWynneNY Classifieds 0 12-21-2004 01:03 PM
2001 L200 thedeputy L-Series General 9 08-19-2000 09:34 PM
