Old 09-27-2006, 08:31 PM   #1
jcono
jcono is on a distinguished road
Default help please- brake lights not working
My wife was pulled over a few hours ago in our "03 vue to be told that only the top brake light was functioning. I checked the fuse and it's OK. Then I realized that the tail lights work, but they don't get brighter when the brake is depressed.
Is there a relay fuse or something I am missing? Any help would be greatly appreciated so my wife won't get rear-ended!
thanks again,
J.
Add to jcono's Reputation
Rate the quality of this post and help jcono reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcono is offline   Reply With Quote
Old 09-27-2006, 09:25 PM   #2
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default Re: help please- brake lights not working
Are the bulbs good?
Add to BobbyP's Reputation
Old 09-27-2006, 09:56 PM   #3
jcono
Yes- I believe there are 3 lights in the tail light assembly- top 2 are red and bottom one is the clear backup light. the 2 red lights illuminate when headlights are turned on but when the brake pedal is depressed, one of those bulbs should get brighter. that doesn't happen.
Old 09-27-2006, 10:22 PM   #4
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
If both sides don't lite up when you depress the brake pedal, it is probably a fuse or switch...check the fuses!! Interior by passenger footwell and under hood by battery....I blew one screwing around with turn light signal install...oops. I later found out I missed it, as there seems to be a million fuses for the same thing....
'Silven'
K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues
Add to mellissam's Reputation
Rate the quality of this post and help mellissam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mellissam is offline   Reply With Quote
Old 09-27-2006, 11:26 PM   #5
Originally Posted by BobbyP
Are the bulbs good?
As mentioned^^^^^
Are the bulbs any good? The tail lamps can still work but that does not mean that the brake filament is not bad. Double filament bulbs.
I have seen both side brake bulbs not work at the same time.
Add to ssicarman's Reputation
Old 09-28-2006, 02:13 AM   #6
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Originally Posted by ssicarman
As mentioned^^^^^
I have chased my tail on that one before.... didnt test bulbs first.... started jumpering switches and what not.... replaced the bulb and whattaknow...
Never thought both would go out at roughly the same time.... but stranger things happen....
I learned that lesson and will never forget it....
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-28-2006, 06:30 AM   #7
jcono
I didn;t know about the double filaments- as soon as I can I'll check them out!
Many thanks again!
Jan
Old 09-28-2006, 07:46 AM   #8
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
If it's not the bulbs, check the brake light switch. It's most likely up under the dash board connected to the brake pedal. The switch on my Mountaineer somehow got really hot and melted enough of the switch case plastic to interferre with making a complete circuit. Same thing happened to a friend's VW Jetta. Kinda scary really. I just cleaned up the switch with a razor blade and didn't have any problems with it for the remaining year that I owned it.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 09-28-2006, 01:57 PM   #9
Bigdaddy94sc2
2006 ION-2 Sedan
If it were the brake light switch, the high mount bulbs wouldnt light up.... all 3 are on the same circuit.
Old 09-28-2006, 02:36 PM   #10
Puppetmaster
Puppetmaster is on a distinguished road
Puppetmaster's Avatar
2002 VUE 3.0L
Really? I was always told the third brake light was on a different circuit in case of situations like this.hmmmmm
2002 Black Silver Metallic Vue
Current mods: Kenwood KDC-MP232 Head unit :: TYC Carbon Fiber taillights:: 18" Alloy Technologies AT-690 wheels w/Pirelli P6 225/55r18 tires
Add to Puppetmaster's Reputation
Rate the quality of this post and help Puppetmaster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Puppetmaster is offline   Reply With Quote
Old 09-28-2006, 05:37 PM   #11
Sounds just like how I found out.
Old 09-28-2006, 09:43 PM   #12
jcono
Default Re: help please- brake lights not working RESOLVED
Well, I replaced the bulbs and that did the trick. The doulbe filament thing is what threw me-
thanks again, folks!
J-
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 03:33 PM
2000 LS1 brake lights aren't working sirtwist2 L-Series Tech 7 06-20-2011 01:28 PM
Brake lights arnt working????? jcurrieirocz S-Series General 9 03-14-2005 11:17 PM
Brake lights working intermittently silverblueL200 L-Series Tech 6 11-26-2004 11:08 AM
tail/stop/brake lights stop working? (QUICK FIX INSIDE) BLUEION2 Ion General 17 06-21-2004 07:04 PM
