Old 09-27-2006, 12:36 AM   #1
Jarryn
Jarryn is on a distinguished road
Default Drum Brakes or Disc??
Hiya, my friend is to cocky to ask.. lol does his car have drum or disc brakes on his 1998 Saturn SL2, and if so how hard would it be to change to disc?
Add to Jarryn's Reputation
Rate the quality of this post and help Jarryn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jarryn is offline   Reply With Quote
Old 09-27-2006, 04:54 AM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: Drum Brakes or Disc??
If he can't tell by looking I wouldn't trust him to do the work safely.
Maybe he should get those hubcaps at walmart with the fake cross drilled rotors visible.
Add to eljefino's Reputation
Old 09-27-2006, 06:33 AM   #3
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
It would have disc up front and either disc or drum in the rear. It's not hard to change to disc in the back, but I agree that if he can't tell by looking then I wouldn't trust him to do anything more than put gas in the car.
Old 09-27-2006, 08:47 AM   #4
S3aturnR
S3aturnR's Avatar
1999 SL1
if he has abs, he's got rear discs. if he doesn't, he's got drums.
both work equally well in almost all situations. the discs excel when it comes time to maintenance them, tho. if you're racing, you will change brakes often and it's WAY easier with discs. if you're not, don't bother swapping (unless you're going for the show car look) because you won't get any performance gains...
s3aturnr
edit: i REALLY hope you were just talking about the rear brakes. drums haven't been used on front brakes for passenger cars in over 30 years...
Add to S3aturnR's Reputation
Old 09-27-2006, 11:56 AM   #5
Jarryn
Thank you much he has ABS and yes i was talking about just rear... lol and he was to lazy to look to see lol thank you much
Old 09-27-2006, 03:28 PM   #6
Another reason not to trust him to wrench on your car, esp. your brakes.
Add to madpogue's Reputation
Old 09-27-2006, 04:46 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: Drum Brakes or Disc??
I can't tell from here
You can look under the car inside the rear wheels to see if there are rear disc's there or drums. The front brakes are disc's for sure. You can swap the rear drums for disc's. SPS has a kit with all the parts needed http://www.spswebpage.com/store/inde...5196a761eb16c5
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-27-2006, 04:58 PM   #8
BarnOwl
BarnOwl's Avatar
Educate me here. Was this statement true just for certain years? My 2000 SW2 has ABS and rear drum brakes.
Add to BarnOwl's Reputation
Old 09-27-2006, 05:05 PM   #9
Certain years and models. Only the sedans and coupes had rear discs with ABS. And only, IIRC, up to about '98 or '99.
Old 09-27-2006, 05:09 PM   #10
Nowhere Man
Nowhere Man is on a distinguished road
Nowhere Man's Avatar
1995 SW2
My wagon has ABS as well and drums in the rear. But it stops well enough so I haven't bothered to do a rear disk conversion.
95' SW2
131,000 Miles
32-MPG avg.
Add to Nowhere Man's Reputation
Rate the quality of this post and help Nowhere Man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nowhere Man is offline   Reply With Quote
Old 09-28-2006, 04:10 PM   #11
S3aturnR
S3aturnR's Avatar
1999 SL1
you're absolutely correct. after 98 or 99, the abs system was built with rear drums. not sure what year was the first, tho.
i KNEW the 98s with abs had rear discs because i almost traded mine back in the day for one when the 98s first came out...
s3aturnr
Old 09-28-2006, 04:11 PM   #12
S3aturnR
S3aturnR's Avatar
1999 SL1
never heard of it before 99 model year before, but i guess anything's possible. can you post pics of your master cylinder and rear drums? i'd like to have a peek...
s3aturnr
Old 09-28-2006, 04:29 PM   #13
The wagons always had rear drums. I've got the ramps out (new catalytic coming soon), so if the brain cells storing the reminder don't die between now and this evening, I'll take a pic or two. AFAIK, the rear reluctors are on the hubs, which (again, AFAIK) are common between rear disc and drum.
Old 09-28-2006, 05:01 PM   #14
Nowhere Man
1995 SW2
s3aturnr
Certainly, here are a few pictures. My mom was the original owner of the car and she ordered it custom from spring hill. From what she told me, you could only get rear disks if you did not order ABS. If you ordered ABS in the wagon you could only get rear drums, I know its strange since you could get it in the sedan. Anyway, being Florida the ABS has saved my butt a few times while doing a panic stop in the rain. So I'm glad I have the ABS regardless.
95' SW2
131,000 Miles
32-MPG avg.
Drum to Disc conversion Pyrate Ion Mods 30 01-26-2006 03:32 PM
converting from rear drum to disc brakes tonyb S-Series Tech 1 03-21-2003 10:16 PM
Disc vs. Drum Brakes DualCamCoupe S-Series Tech 22 03-20-2003 05:30 PM
ION Rear Brakes - will it be disc or drum? VTHokie00SL2 Ion General 30 03-17-2002 03:16 PM
drum to disc evilSL1 S-Series Mods 2 03-28-2001 05:11 PM
