Old 09-24-2006, 04:20 PM   #1
MSgtEgress
MSgtEgress is on a distinguished road
MSgtEgress's Avatar
Question Input shaft nut step-by-step procedure
Hi all, First thanks in advance for your assistance! My first time to the forum and I have the infamous input shaft nut problem on my 95 SC2 with 110K. I have searched the forum for threads with a step-by-step procedure for this to little success. I found TedL's thread which is a help for parts and actually torquing the nut but I'm looking for the procedure for removing the cover to access the input shaft.(which I understand is tricky) I found the whole procedure on Turbosaturns.net Forum a few weeks ago but for some reason the forum has been down for several days. I know the left spindle and fender well need to come off but I dont want to screw anything up getting the cover off. Your help is greatly appreciated.
Tim (aka MSgtEgress)
"In the year of our Lord 1314, Patroits of Scotland, starving and outnumbered, charged the fields of Bannockburn. They fought like warrior poets, they fought like Scotsman and won their freedom"
Add to MSgtEgress's Reputation
Rate the quality of this post and help MSgtEgress reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MSgtEgress is offline   Reply With Quote
Old 09-24-2006, 06:07 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Input shaft nut step-by-step procedure
Manual Transaxle Assembly
Saturn Coupes/Sedans/Wagons 1991-1998 Repair Guide
http://www.autozone.com/servlet/UiBr...3d8019a8cb.jsp
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-25-2006, 07:05 PM   #3
MSgtEgress
MSgtEgress's Avatar
Thanks but that is manual transaxle removal. I just need to take the end cover off of the auto transaxle.
Anybody else ??
Old 09-25-2006, 09:41 PM   #4
Straight from the service manual for 98. Should be no differences between 98 and 95.
End Cover Replacement
Tools Required
SA9132S Lower Control Arm Ball Stud Separator
Removal Procedure
Caution: Refer to Battery Disconnect Caution in Cautions and Notices.
Raise the vehicle on a hoist. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the left front wheel and tire assembly.
Remove the left wheelhouse splash shield.
Drain the transaxle fluid.
Remove the cotter pin from the lower ball joint and discard ti. Loosen the nut and back it off until the top of nut is even with the top of threads.
Notice: On ABS equipped vehicles, the outer CV joint has a speed sensor ring. Using the incorrect tool or procedure to separate the control arm from the knuckle can damage the ring, resulting in a loss of ABS operation.
Notice: Do not attempt to separate the joint using a wedge-type tool because seal may be damaged.
Separate the ball joint from the steering knuckle using the SA9132S and remove the nut.
Remove the bolt retaining the brake line bracket to the inner fender and position the brake line to avoid interference.
Remove the transaxle mount-to-frame fastener.
Place a screw type jack stand under the transaxle casing use a block of wood between the stand and casing to unload the transaxle lower mount.
Remove the 2 mount-to-transaxle fasteners.
Loosen and back off on the 2 frame-to-body bolts. Do not remove the bolts.
Raise the powertrain enough to remove the mount from the vehicle.
Lower the jack.
Remove the end cover bolts.
Notice: Use care when removing end cover as the tubes can bend easily.
Remove the end cover. 1st design shown, 2nd design similar.
If replacing the end cover, refer to Transaxle Disassemble and Transaxle Assemble .
If replacing the 1st gear assembly, refer to 1st Clutch, 1st Drive Gear and 1st Driven Gear Replacement (On-Vehicle) .
Installation Procedure
Clean the gasket surfaces and install the gasket on to the end cover dowel pins. Install the end cover to the transaxle case. Insert the input and output shaft tubes into the ends of the shafts and install cover. If the cover does not seat, rotate the axle to help align the tubes with the bushings in the shafts. 1st design shown, 2nd design similar.
Notice: Refer to Fastener Notice in Cautions and Notices.
Important: Clean and lubricate the fasteners with Saturn Transaxle Fluid. Wipe off excess fluid.
Install the end cover to case bolts and tighten using the tightening sequence.
Tighten
Tighten the end cover-to-case bolts to 28 Nm (21 lb ft).
Install the bolt into the brake line bracket and tighten.
Tighten
Tighten the brake line bracket-to-transaxle bolt to 5 Nm (44 lb in).
Raise the powertrain up and install the transaxle mount.
Install the 2 lower mount-to-transaxle fasteners.
Tighten
Tighten the lower mount-to-transaxle bolts to 32 Nm (24 lb in).
Tighten the 2 frame-to-body bolts.
Tighten
Tighten the frame-to-body bolts to 210 Nm (155 lb in).
Lower the powertrain completely.
Install the transaxle lower mount-to-frame fastener.
Tighten
Tighten the lower mount-to-frame nut to 48 Nm (35 lb in).
Install the left wheelhouse splash shield.
Clean and lubricate the ball joint threads.
Notice: Take care not to damage rubber boot when installing ball joint to knuckle.
Position the ball joint into the steering knuckle.
Install the nut to the lower ball joint and tighten.
Tighten
Tighten the lower ball joint-to-steering knuckle nut to 75 Nm (55 lb in).
If necessary, after tightening, tighten the nut additionally to align the slot in the nut with the cotterpin hole in the ball joint, and install the cotter pin and bend the ends.
Notice: Before installing wheels, remove rust or corrosion from wheel mounting surfaces and brake rotors/drums. Failure to do so can cause wheel nuts to loosen in service.
Position the wheel onto the hub.
Install the wheel nuts and tighten them in a crisscross pattern. Repeat the tightening pattern to be sure torque is correct.
Tighten
Tighten the wheel lug nuts to 104 Nm (103 lb in).
Lower the vehicle from hoist.
Fill the transaxle with fluid.
Install the transaxle strut-to-midrail bracket fastener.
Tighten
Tighten the transaxle strut-to-midrail bracket bolt to 70 Nm (52 lb in).
Install the air cleaner and duct assembly. Refer to Air Cleaner Housing and Duct Assembly Replacement .
Verify the fluid level. Refer to Transmission Fluid Checking Procedure .
Add to ssicarman's Reputation
Old 09-26-2006, 05:36 PM   #5
MSgtEgress
MSgtEgress's Avatar
Thumbs Up Re: Input shaft nut step-by-step procedure
Thanks ssicarman!
Step-By-Step - 3.5L Throttle Body Coolant Bypass (with pictures) burnout Vue Mods 14 01-21-2010 03:12 PM
how to jam input shaft for input shaft nut replacement. anisbet S-Series Tech 2 04-20-2009 11:54 AM
Need help with Input Shaft Nut procedure d_rock S-Series Tech 25 06-29-2008 03:57 PM
Is there a "step-by-step" how to" procedure to change the ATF fluid? kim_lombard Vue Tech 0 07-25-2007 10:24 PM
