Old 08-29-2006, 07:29 PM   #1
hammand
hammand is on a distinguished road
Default No Tach, speedo or engine temp
Can anybody tell me which fuse controls these items ?
Which fuse box ?
1995 sc2, just completed auto to manual swap.
Add to hammand's Reputation
Rate the quality of this post and help hammand reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hammand is offline   Reply With Quote
Old 08-29-2006, 10:08 PM   #2
Default Re: No Tach, speedo or engine temp
Um, all fuses in both fuse boxes are marked, and the owner's manual provides more detail. Anyway, check the IGN 1 fuse in the IP box.
Add to madpogue's Reputation
Old 08-29-2006, 10:33 PM   #3
dave.sl
dave.sl has a spectacular aura aboutdave.sl has a spectacular aura about
I can't recall the fuse data, but as posted above it is all in the manual. I had the same issue last year on my 98SL and it ended up being a bad instrument cluster. Had it replaced with a used one and it has been fine. My fuses all checked out good. A few of the cluster lights went out too, but I don't remember which ones.
Add to dave.sl's Reputation
Rate the quality of this post and help dave.sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dave.sl is offline   Reply With Quote
Old 08-29-2006, 10:37 PM   #4
hammand
Thanks, worked like a charm.
Old 09-05-2006, 06:37 PM   #5
charcoal
charcoal is on a distinguished road
1993 SC2
I have the same problem on my '93 SC2.
Ok, so its the I/P...so what shorts?
anybody got a pinout or schematic?
It seems to me that the four D'Arsonval type meters on the I/P are just simple meters and that the odometers (trip and total accumulation) are watch-motor type actuated and I would suspect them to be more prone to short than a meter movement.
Can anybody shed more light on this?
Thanks in advance!
MAD works!
Add to charcoal's Reputation
Rate the quality of this post and help charcoal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
charcoal is offline   Reply With Quote
Speedo/Tach issues Keeter S-Series Tech 1 10-11-2009 05:11 PM
has anyone swapped the speedo with the tach Tom S2 Astra General 8 06-27-2009 09:17 PM
Speedo & Tach "Strange" behaviour? surprisinguy S-Series Tech 0 06-15-2009 10:04 AM
Information Center (DIC) Engine temp or Coolant Temp ? Astrafirstsatur Astra Tech 10 02-16-2009 08:10 AM
HELP!!! Tach / Engine Problems!!! Still need someone to help!!! Lizzy S-Series Tech 10 05-02-2006 09:15 PM
