Old 08-24-2006, 08:41 PM   #1
Micky2191
Micky2191 is on a distinguished road
1997 SL1
Question Steering Clicking Noise ... Please Help!!!
Hi, first of all I've looked at a lot of threads on here, and there seem to be lots of similar problems, but not identical...so here it is!!
My 97 SL1 has a very loud clicking sound somewhere near the power steering pump. This occurs when I am in gear (drive or reverse) and while turning the wheel. It is usually intermittent, but when I reach the extent of the steering wheel in either direction, it gets worse. I have recently replaced the belt tensioner, the passenger side lower control arm, the water pump, belt, and front strut mounts (all over about the last 6 months). I suspect the power steering pump or something in the steering gear assembly (not sure if that is the right term or not). I am slowly becoming a backyard mechanic, but still need laymans terms. Oh yeah, I also just had an alignment done, so I don't think it would be the tie rods. Any help would be great. Thanks.
Add to Micky2191's Reputation
Rate the quality of this post and help Micky2191 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Micky2191 is offline   Reply With Quote
Old 08-25-2006, 05:36 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Steering Clicking Noise ... Please Help!!!
CV joint maybe. Kind of a clackety sound when you make a sharp turn?
Add to BarnOwl's Reputation
Old 08-25-2006, 06:46 AM   #3
Micky2191
1997 SL1
I'm not sure, it's not just on sharp turns. If I turn the wheel slowly in either direction, it still happens but not as pronounced. I'll check the boots though.
Old 08-25-2006, 10:10 AM   #4
Does it happen as you're turning the wheel, even when the car's not moving? Or is it when you're holding the wheel in a turn, and the car is moving?
If it's the former, then I'd say it is something in the rack & pinion unit itself. If it's the latter, that's a classic outer CV joint noise; check both outer joint boots for damage.
Add to madpogue's Reputation
Old 08-25-2006, 11:13 AM   #5
Micky2191
1997 SL1
it's both, but only in gear
Old 08-25-2006, 08:26 PM   #6
Micky2191
1997 SL1
Well, I'm going to go out in the morning and check the CV Boots, is there anything else I should be looking for other than cracks or grease leaking. As I said, I am only beginning to learn a bit about auto maintenance; I have the Haynes Manual, but that's where the extent of my knowledge comes from.
Old 08-25-2006, 09:27 PM   #7
Naw, CV boot inspection is a pretty straightforward visual thing. Just make sure to check the whole circumference of both boots (turn the steering all the way left, inspect what you can, then turn the steering all the way right to complete the inspection). A tear or grease leak should be pretty evident.
Old 08-25-2006, 09:29 PM   #8
Micky2191
1997 SL1
Thanks Madpogue, I'll update tomorrow and see what I find.
Old 08-26-2006, 08:53 AM   #9
Micky2191
1997 SL1
Well, checked the CV boots, and can't find any cracks or leakage. Guess I'll keep poking around.
clicking noise ronca L-Series Tech 1 12-20-2009 12:18 PM
Clicking noise atlas4711 Ion Tech 3 01-10-2009 11:04 AM
Clicking in steering column? dansmith126 Aura General 8 03-11-2008 06:34 PM
clicking noise HookedUpSL2 Miscellaneous Tech 4 05-03-2004 07:31 PM
Steering column clicking pkschul Vue General 1 12-23-2002 06:53 PM
