#1 | ||||
![]() Join Date: Jun 2006
My 95 SL2 won't start if the engine is warm. I have to hold the pedal to the floor and only then will it start. Suggestions?
Thanks 1995 SL2 auto a/c
#2 | ||||
I have that problem, though not as bad. I don't have to give it gas, just have to crank it longer. A search of the forums has indicated that the ECTS may be the culprit, though that particular sensor seems to be the cause of many problems.
... 1997 Saturn SC2 (Donated) 2007 Jeep Grand Cherokee 4x4 Limited HEMI 2008 MINI Cooper S
#3 | ||||
Perhaps it is the CPS (Crank Position Sensor)?!
... R.I.P. - My 1996 Saturn SL2, "Psycho" - 7/95-2/17/06 R.I.P. - My 2000 Saturn SL2, "Sexy" - 11/24/99-8/05/08 If you're a car begging for your life, wouldn't you want someone to add fluids?
#4 | ||||
![]() ![]() Join Date: Jan 2006
2002 SC1
Putting the pdeal to the floor doesn't do squat in a Fuel Injected car.
Well actually it turns the injectors off in case the engine has been flooded. No start while hot is usually a bad CPS, or the early signs of a fuel pump on it's last legs. And just as a precautionary measure check out the ECTS, but that normally won't cause a no-start, it just screws everything else up. Make sure yours is brass.... Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
#5 | ||||
In what order should I proceed?
CPS, fuel pump, ECTS? Thanks
#6 | |||||
2002 SC1
#2 CPS. It's a cheap, relatively easy part to fix. #3 hopefully it's not your fuel pump, that's in the tank. ... Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
#7 | ||||
I have to agree with Uzzy. To replace the CPS and ECTS, you're going to spend maybe $50 if you need a new connector and an hour of your time. The fuel pump's around $200 and a lot of work.
... There is nothing more frightening than ignorance in action.
#8 | ||||
You can turn your key to run/on (don't actually crank the car), also make sure you have the radio off, you should hear a buzzing noise, if you do, that's good, that is the fuel pump priming itself. Try this when the car is warm, like when you try to start it and usually have problems starting it. I'm thinking if the fuel pump were the problem you wouldn't hear it prime. Am I correct?! But I know the CPS is notorious for causing the car not to start when warm....so I think that is your main problem. However, you still need to check the ECTS, just to avoid ECTS problems. Those darn ECTS's cause alot of problems, but I highly doubt that is the cause of this problem.
| Thread Tools | |
| Display Modes | |
| Quick start cold/ slow start warm 1st try, 2nd try quick start | SWDude | S-Series Tech | 3 | 12-05-2009 09:27 PM |
| Won't start when warm. | hit_n_run | S-Series General | 20 | 10-09-2009 05:43 PM |
| 96 SL1 won't start when warm | 1andonly | S-Series Tech | 18 | 05-12-2009 10:51 PM |
| Cold start fine, warm start takes a couple of tries | FredM | S-Series Tech | 5 | 09-05-2008 04:03 PM |
| Two or Three tries to start when warm? | Monroe44 | S-Series Tech | 17 | 09-23-2005 09:44 AM |
