Old 08-16-2006, 08:37 PM   #1
Jeff K
Jeff K is on a distinguished road
Jeff K's Avatar
1992 SC2
Default What do these have in common?
I still have that electrical problem with my car. I momentarily lose all power as far as I can tell except the firing to the engine I think because there is no missfire. What happens is I'll be driving along and all of a sudden my radio resets the time and memory, the tach and speedometer drop, then the door chimes go off and the radio restarts and loses its time. The strange thing is I don't even notice a thing from the engine no miss everything seems fine. Someone said it could be the ignition switch but the raio memory doesn't travel through this? What else electrically could these all share that wouldn't misfire the engine? The battery? But if the batt was shorting internally wouldn't the engine misfire? Do all these share a common ground? If so where is it hiding? Both batt connections are tight along with the connection to the junction box. If anyone has any ideas they would be appreciated. Thanks!
Add to Jeff K's Reputation
Rate the quality of this post and help Jeff K reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeff K is offline   Reply With Quote
Old 08-16-2006, 09:21 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: What do these haver in common?
pretty much just a battery cable that'll do this. Remove to inspect, don't just look at 'em.
Add to eljefino's Reputation
Old 08-17-2006, 12:06 AM   #3
When the engine is running, the accessories run off the alternator, so a bad positive battery cable won't do what you describe. I would look at grounds in the passenger compartment, and the big green 30A fusible links under the hood.
Add to madpogue's Reputation
Old 08-17-2006, 06:13 AM   #4
BarnOwl
BarnOwl's Avatar
madpogue's probably got it, but run by a parts store and have your battery and charging system checked. They'll do it for free at Autozone or Advance.
Add to BarnOwl's Reputation
Old 08-17-2006, 01:17 PM   #5
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
I second the grounds - remove the cables from the battery, clean them. Clean the two major grounds going to the tranny/block. Clean the grounds going to the frame next to the fuse box.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 08-17-2006, 06:47 PM   #6
amazinghl
Batter/alterantor/grounds/The wire that connect the starter to alterantor. Check them all.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 08-17-2006, 08:05 PM   #7
Jeff K
Jeff K's Avatar
1992 SC2
Are all the grounds under the hood or are any inside the vehicle. I cleaned most of the grounds under the hood when I bought the car 7 months ago. Except the one on the block, it would almost take a lose connection to cause this wouldn't it? I'll check the car further over the weekend.
Old 08-26-2006, 10:44 AM   #8
bobcolvin
bobcolvin is on a distinguished road
I just had the same thing with occasional "no start" problems. The instrument fuse block melted on the center console. $219 + labor
Add to bobcolvin's Reputation
Rate the quality of this post and help bobcolvin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobcolvin is offline   Reply With Quote
Old 08-26-2006, 11:19 AM   #9
eRic 02sc2
eRic 02sc2's Avatar
something similar happened to my 92 SC once. it was the battery cable. the end of the negative cable pulled loose from the ground on the transaxle case and it would cut off and on when the engine rocked back and forth.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
What is the most common cause for code 26 saturncrzy S-Series Tech 2 04-09-2009 04:27 PM
Parts common to the different models? gaurdien Vue Tech 0 05-13-2007 06:47 PM
Is this common practice? fullhart S-Series Tech 11 04-24-2007 10:30 AM
Is this noise common? striker1211 L-Series Tech 11 04-02-2007 11:15 AM
Common Practice??? Xanadu S-Series General 8 07-15-2006 01:39 AM
